Question about Philips Magnavox Learning Universal Remote
Samsung TXN3275HF NO Power
When we press the power button on our Samsung TXN3275HF the TV does not turn on...nor when we use the remote. We changed outlets and still nothing. Any suggestions. Could this be something simple that we can fix.
  • 74 Answers
Not likely. It sounds like it needs parts inside..(It is almost never just the fuse on a tv) If it would come on with the tv button or the remote button, then it may be easy. Not coming with either proves that the tv needs parts, since you are sure the tv has power.
Posted on Mar 25, 2008
Can I program a Samsung AR 6052 remote to work television
Press the MODE button to make the TV
indicator on the remote control flash.
2 Press POWER button to turn on the TV.
3 Point the remote control toward the TV.
4 While holding down POWER, enter the code
corresponding to your brand of TV.
• If the code matches the TV's code, the TV will be turned off.
• If there is more than one code listed for your TV in the table,
enter one at a time to determine which code works.
Example: For a Samsung TV
While holding down POWER, use the number buttons to enter 00,
01, 02, 03, 04, and 05.
• You can use the POWER, TV/VIDEO, VOLUME, CHANNEL, and
Numeric buttons (0~9).
5 Pont the remote control toward the TV and press
POWER. If the TV turns off or on, the setting is
complete.
Oct 04, 2015 | Samsung Televison & Video
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
My samsung remote for my blu ray player stopped working for my samsung TV today. i have never had this problem before. it still works on the blu ray player which then turns on the TV like it is supposed...
On blu ray remote control hold down TV Power+01 at the same time. If the TV turns off the controller is programmed. If not, try TV Power+02, +03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
Sep 16, 2010 | Samsung TV Remote Control
I need code for samsung remote code for tv
Automatic Programming
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control (TV, VCR, SAT, DVD) until POWER INDICATOR illuminates. The remote control is in programming mode.
3. Press POWER button on remote and release . The POWER INDICATOR flashes once and stays on indicating the unit is in Power scan mode.
4. Press CHANNEL+ or CHANNEL- repeatedly until the device turns on.
5. When the device turns on, press ok to store the code.
Dec 15, 2009 | Brookstone 538744 Remote Control
Need Vizio TV code for my Samsung HT-X50 home theater remote!
Mine is 5. Press the TV button and let it go. When it quits glowing press the power button and hold it down. Then press a number (1-86) on the keypad while holding the power button down. If the TV turns off, you are done. Press the power button again and the tv should come on. If it does not work. Release the power button for a second and then repeat with a different number until the tv turns off.
Jul 05, 2009 | Samsung HT-Z310T Theater System
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Configuring Sky remote
3. Press tv again
Samsung Code: 0060
Sep 20, 2008 | Samsung AH5900092W Remote Control
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Philips Magnavox Learning Universal Remote Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
