Question about Hitachi 60V715 60" Rear Projection HDTV-Ready Television
YELLOW CIRCLE WE HAVE A BIG YELLOW CIRCLE IN THE MIDDLE OF THE SCREEN CAUSING THE COLOR TO BE DARK AND DISTORTED.
  • 4caster Jun 17, 2008
    I have the same problem of the yellowish green area in the center of the picture. Could it be the that the lamp is about to expire? Does the lamo fail gradually like this, or is it a case of here one minute and gone the next? The lamp is supposed to be user serviceable. How do I gain access to it?
  • 50 Answers
SOUNDS LIKE YOUR LIGHT ENGINE
Posted on Feb 11, 2008
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
Color red,green and blue is making a circle on the screen
Hello, please replace the PTC resistor. It is positioned at the primary side of mains converter. Best regards, Arpi
Aug 23, 2007 | Zenith B27A11Z 27" TV
How to fix the big dark circle in the middle of the screen
I think you may be having a problem with the projection bulb.
Jun 09, 2014 | Sony VPL-ES1 Multimedia Projector
I have a big yellow circle in the middle of my projected video. Can this be reset?
no you cannot remove, you have to change the screen inside the monitor. the spot cause burn on the screen picture.
Aug 29, 2011 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Big red circle in the middle of the picture
Your light engine is bad and needs replaced. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 30, 2010 | Hitachi 51F59 51" HDTV Projection...
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
Yellow circle in the middle of the screen. It has
Not sure if this will help...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba 42H83 42" Rear Projection...
Image has big yellow
Hi Zenmast
This is a burnt LCD that will need replacement. If the circle is yellow on a white screen , then it is your blue LCD that will need replacement.
Apr 22, 2008 | SharpVision XV-Z1U Multimedia Projector
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
Colour distortion
Your screen mask may have become magnetized. This will require that you have the CRT degaussed. This is done with the use of a degaussing coil. you have to stand about 10 feet from the TV with the coil held vertically and moving it in a circular pattern as you walk towards the tv. Once you are about 1-2 inches from the TV stop and continue the circular pattern for about a three count then backup from the tv still using the circular motion once you are about 10 feet from the tv turn the coil to a horizontal plane and move it away quickly and turn it off. This should degauss the TV and remove the color distortion.
You will need a degaussing coil to perform this task.
Thank you,
Shuttle83
Nov 27, 2007 | Televison & Video
Televison & Video Logo
416 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
