Question about Samsung LN-S3251D 32 in. LCD HDTV
Vertical over scan
News trailer on "Fox News" displays below bottom bezel with just a bit of the top of the words showing. Is there an adjustment for correction? This condition was present when set was received.
  • 1 more comment
  • nossar Feb 20, 2008
    Help! Tried above steps in quotes without plus signs [none on my remote] but with power button. This shuts set down and when restarted it is normal Pressing menu button brings up the normal menu but nothing to set screen settings. All of this was tried using the Source button to switch to TV input. What am I doing wrong? Nossar
  • nossar Apr 08, 2008
    Thanks, edcarsonjr. Looked at all listings on service menu but could not spot anything about vertical scan with my trifocals. You were right--- there are a lot on "Whatisits" listed on that menu. Recognized very few of the listings. Can you steer me in the right direction? Sorry it took so long to get back to you but have had a lot of downtime with the pc. Ed
  • nossar Jul 26, 2008
    BIG Thanks, edcarsonjr. This worked for access to menu. Problem is," I don't understand ANYTHING that's on it! Guess I'll have to live with oversize picture. nossar
    Problem Solver:
  • 10 Answers
There is a way to adjust your screen size. You need to access the service menu on the set. With your remote, Press "mute+1+8+2+power" to access it. Be very careful doing this,as not to change your other factory settings. Good luck and don't forget to send feedback to fixya. Let me know - edcarsonjr
Posted on Feb 18, 2008
  • ED CARSON
    ED CARSON Feb 20, 2008
    Start with set off,Then press - mute,1,8,2,power
Screen gone half black...tried with different CPU...same problem persist... Please advise what to do...
The effect is called fold-over, where the bottom of the screen is folded over the top half.
If you can get into the menu set up you can try and change scan settings and adjust them so that :-
1. The screen is moved down so that the bottom of the fold-over is at the bottom of the screen and the top of the windows screen is at the top (it is missing on the photo).
2. Adjust the vertical scan rate to resolve the fold-over problem.
Otherwise it needs fixing by a TV engineer that can fix monitors as the adjustments are inside.
Mar 19, 2015 | Computers & Internet
Vertical lines on laptop screen
problem with either display or the display cable...call cust service to diagnose and fix the issue
Mar 15, 2014 | Dell Studio 1555 laptop
How to replace a ccfl backlight bulb on presario cq60-419wm
Whoa!
Let's talk for a minute..........
CCFL = Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little thicker than 1/16th of an Inch.
Or about the width of this capital -> O <-
Average length is almost as long, as the LCD screen is in height.
Just like it's larger 'cousins', it has Mercury in it. A POISON.
Point?
They break VERY easily, and have Mercury inside.
I usually suggest changing the LCD screen itself, to replace a Backlight.
More expensive?
YES
If you are talking about price of LCD screen compared to a CCFL bulb.
SAFER?
YES
There is NO price for a human life.
Okay, moving on..................
1) http://www.insidemylaptop.com/replace-lcd-screen-hp-g62-compaq-presario-cq62-laptop/
2) http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
3) Service Manual:
HP Support > Compaq Presario CQ60-419wm Notebook PC >
Manuals download page, (User Guides)
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3966262&
Scroll down, click on the blue -
Compaq Presario CQ60 Notebook PC HP G60 Notebook PC - Maintenance and Service Guide
[Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
(The PDF file will not show until fully downloaded )
Go to the top left corner, and click on the small square icon -
Toggle Slider.
Becomes two small square icons.
Show Thumbnails on the left, Show Document Outline on the right.
Click on Show Document Outline to see the Bookmarks menu.
The Zoom In icon ( + ) at the Top, increases the view size when you click on it.
The Zoom Our icon ( - ) decreases the view size.
When I refer to a page number, it is for the Adobe Reader page number box at the Top. (To the right of the Down Arrow) ]
The plastic frame in front of the LCD screen is the Display Bezel.
I may be wrong, but I believe the Display Bezel can be removed, WITHOUT having to remove the entire Display Assembly from the laptop.
Makes life a lot easier.
There is a Philips head screw in the Bottom/Left corner, and a Philips head screw in the Bottom/Right corner, to remove from the Display Bezel.
They are under Screw Covers. The Screw Covers are made of synthetic rubber, or plastic. They are held in place by a type of rubber cement.
I take a computer pick, and gently pry up at the base of the Screw Cover.
If you are careful you should be able to reuse the Screw Covers.
If they do not stick anymore, apply a TINY dab of rubber cement to them, with a toothpick.
The Display Bezel has TABS going around the exterior perimeter of it's inside edges.
These snap into matching LATCHES on the Display Cover.
There also may be some sticky tape, at the bottom/inside edge of the Display Bezel. Means CAREFULLY pry the bottom edge of the Display Bezel when removing.
The best method, of removal of the Display Bezel that I have found, is to flex it.
It is made of space-age plastic, and is pretty tough stuff.
(Of course there are those, who could destroy a steel ball bearing with a rubber mallet, in a sandbox)
I cut a piece of thick construction paper, to just fit the inside edges of the Display Bezel.
Display Assembly laid as far back as possible, the thick piece of construction paper will stay in place.
It is used to prevent scratching of the LCD screen, from your fingernails.
Come to the Inside edge (LCD screen side), of the right/middle side of the Display Bezel. Sliding a fingertip of one hand under the bezel to lift up slightly.
Can't get in? Move over a little. You are at a Tab/Latch.
With one fingertip under the bezel, slide another fingertip under from your other hand. By now a Tab/Latch should have released.
SNAP!
Sounds like you're breaking something.
Keeping the bezel slightly up, move along with the fingertips of one hand, and move towards the Top.
Go along the Top popping Tabs/Latches loose.
Then come down the Left side.
As you reach the bottom ease up on one side a little, and wait for the tape to start releasing. Then ease along the bottom until all the tape releases, and the Display Bezel pops off.
Once the Display Bezel is removed, then disconnect the small cable that comes from the Video Cable (Display Cable - HP), TO the screen Inverter board. (Left side of screen Inverter)
(screen Inverter is mounted behind the Display Bezel, and at the bottom of the Screen Frame.
The Screen Frame is the thin metal frame which surrounds the LCD screen assembly)
[The LCD screen is an assembly of layers. The layers are held in the factory set position by the Screen Frame]
Disconnect the small cable that goes TO the screen Inverter, on the Right side of the screen Inverter.
Remove the screen Inverter, and lay aside.
Remove the Philips head screw at EACH top corner. Holds the Screen Frame TO the Display Cover.
Tilt the top of the LCD screen towards you, remove the clear adhesive tape over the Video Cable connector on the back of the LCD screen.
(DO NOT remove the tape all the way. Just carefully peel it back far enough, so that you can get to the Video cable connector, at the back of the LCD screen. This way you should be able to reuse the tape)
Disconnect the Video Cable (Display Cable) from the back of the LCD screen.
Remove JUST the screws which hold the Hinge Brackets TO the Screen Frame.
The Screen Frame can be taken apart. Of course you will need to do this, BUT ONLY after removing the LCD screen assembly.
THREE screws on each side for the Hinge Brackets.
(Display Panel Brackets)
One towards the Top, two down towards the Bottom.
Pages 64 through 80 in Service Manual.
Page 66/ Bottom; shows the Screw Covers, and Screws to remove from Display Bezel.
Page 68/ Bottom; shows disconnecting the screen Inverter.
Page 69 shows screws to remove in order to remove LCD screen.
(Display Panel)
Page 69/ Bottom shows screws to remove for removing Hinge Brackets.
Pages 128 through 133 - Recycling/Display: shows taking the Screen Frame apart, and accessing Backlight.
For additional questions please post in a Comment.
Regards,
joecoolvette
(WEAR gloves -> BE SAFE)
Feb 25, 2013 | Computers & Internet
Picture is to large for 27in
If model indicated here is correct either a problem in the Vertical circuit of the set or an adjustment.
Almost any shop can take the set into the service menu and adjust vertical size a bit to correct if not circuit problem.
Nov 02, 2012 | RCA F27636BC 27" TV
TCL 14175 Vertical adjust
Hello
You have to enter its serive mode options to adjust picture height. Whithout its origianal remote handset, it is impossible.
Mar 07, 2012 | Televison & Video
Picture cramped a little on top and reduced half inch bottom
you need to adjust the display setting in the menu option .reduce little from top and botom
Mar 19, 2010 | Televison & Video
Can't see words displayed at bottom of screen
Check your menu for horozontal and vertical size adjustment to see if you can reduce the size of the image. Or try to change the aspect ratio. Last resort is to do a system reset.
Jan 16, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The vertical green convergence adjustment is broken
Either your convergence ic's are bad or the convergence digital module ( if your model has one ) . I would have it looked at by a service company.
Jan 16, 2010 | Hitachi Televison & Video
Picture adjustment on zenith SM3247MK8
Probablemente tengas problemas en el circuito vertical o los capacitores adyacentes hay que checarlos.
Mar 20, 2008 | Televison & Video
Display adjustment
hi there, bottom adjustmet means a vertical section control adjustment. a vertical size, vertical position control adjustment. do some check up on users control manual adjustment. ty
Dec 29, 2007 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
Samsung LN-S3251D 32 in. LCD HDTV Logo
140 people viewed this question
Jerry Greenberg
Jerry Greenberg
