Question about Canon XL1S Mini DV Digital Camcorder
Problem with Canon XL1S lens
Hi.
When i turned on my camera on a display was written Lens check, or something like that. Now the zoom is working just when i turned on my camera for about 4 seconds. Is there any solution for this problem?
New lens? ;-)
  • Anonymous Apr 24, 2008
    Hi, I have the same problem. After waiting about 4 seconds i got the "lens check" label on the display and the zoom and iris does not work at all.
    Someone can tell me something to do with this
    Scholar:
  • 48 Answers
Another thing would be to remove the lens, check the contacts [little gold thingys on the mounting end] give them a GENTLE cleaning on both the lens & the camera, then re-attach the lens & try it. Sometimes its the little simple thing like this that will create the biggest problems.
Posted on Jun 17, 2009
    Sergeant:
    Champion:
  • 317 Answers
Definitely sounds like there is a problem with the lens. You might be able to get a new one, from canon, considering they have a lifetime warranty on all of their Lenses. Otherwise, it seems that you will have to spend some money.
Posted on Feb 11, 2008
I accidentally pushed my lens in while taking a picture so now when the camera thinks it at no zoom it has a 24 zoom (number on lens) How do I fix?
Hi and welcome to FixYa!
This problem does occur. As a first course of action I strongly suggest that you remove the battery of the camera and turn the switch on for 10secs. while the battery is removed. After 10secs. insert the battery then turn the camera on. This should reset the system and may get your camera back to it's normal operation.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 15, 2011 | Canon PowerShot SX30 IS Digital Camera
Lens does not zoom in
This is not a common error on canon digital. This is caused due to possible short in zoom control circuit (main pcb). At normal use, if the lens does not retract due to mechanical jam, when the zoom control button is pressed, lens error 18 message supposed to be displayed. Since control circuit is shorted and faulty, error 18 message was not displayed. The remedy for this problem probably requires a replacement of a main pcb. Replacing a main circuit board may run around $100-140. -James
Mar 29, 2009 | Canon PowerShot A640 Digital Camera
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
CANON XL LENS CAP FOR 16X ZOOM LENS
According to its specifications, this lens can use a 72mm filter. So you should be able to get the type lens cap that clips into a 72mm filter to work. Such as the one shown here. I'd recommend you go to a local camera store and try one to make sure it works.
Feb 11, 2009 | Canon XL1S Mini DV Digital Camcorder
Zoom not working at all
You have a one year warranty with Canon, you should have all the information about shipping it to them in your original box.
Dec 17, 2007 | Canon PowerShot S3 IS Digital Camera
Canon lens not functioning properly?
All those contacts are cleaned?
New battery, not old and charged, right?
atdlee@netzero.com
Dec 15, 2007 | Canon XL1S Mini DV Digital Camcorder
Lens failing to function properly
Yes, this is a strange issue. Have you dropped the unit, or maybe 'bumped' it or anything similar. I know alot of times, people like to 'hit' their unit, to get it to do things (like eject tape). What people don't realize, is that these machines are prone to damage when hit hard enough (just like anything else).
In any event, this is not an misconfiguration issue, and you won't be able to fix it. You would need to bring it in to a qualified service center for an estimate. Be sure to shop around to find the best price and service. Since parts for these are not cheap, and they are labor intensive.
Good luck.
Hope this helps some.
TWEAK A/V LAB
Nov 09, 2007 | Canon XL1S Mini DV Digital Camcorder
Canon error code 99
Your camera performs a quick 'integrity' check before each shot and goes into error 99 mode if the lens in incompatible or has a diaphragm problem. ( it will also display e99 if the shutter or flash unit is not ok but this does not apply here ). This is how you can check whether the diaphragm mechanism is ok : attach lens to your old camera and set camera to AV and set F stop to 16 . open back and release shutter and look through the back to see if your lens is closing to F 16. If it is closing fine then the lens is ok but is not compatible with your D400.
Sep 10, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Possibility is two. 1. If the lens contact to the body is not good so make sure the contacts are clean and position is locked completely. 2. 90% of the solution comes from repair on Main circuit in the lens. Good Luck. For further assistance go to www.camerarepairjapan.com James.
Aug 26, 2007 | Canon XL1S Mini DV Digital Camcorder
Zoom lens problem
Most often these problems occur because of shocks received by the camera. The zoom mechanism in the lens assembly gets knocked out of place. Sometimes this happens just like that, without any clear reason. The lens assembly is a delicate mechanism if one small part gets out of the place it will damage or jam the whole mechanism. A service center can check for that. There is no way for the end user to proper realign the lens mechanism because it is sooo small. It requires specialised tools and hardware. Also, when you take the camera to a service, ask them an estimate of the repair, you will know if it is worth it. Repairs vary form a simple lens adjustment to the need of having the whole lens assembly replaced
Mar 15, 2007 | Canon PowerShot SD700 IS Digital ELPH /...
Canon XL1S Mini DV Digital Camcorder Logo
317 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
