Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
KF60XBR800 ctf1800, I TRIED YOUR PROCEDURE AND GOT CONFUSED BECAUSE I WAS NOT SURE WHAT BUTTON TO PUSH TO MAKE CHANGES. WOULD YOU RECOMMEND I TRY AGAIN OR SHOULD I RESET BACK TO FACTORY SETTINGS AND THEN TRY AGAIN? IF SO HOW DO I RESET BACK TO FACTORY AND WHAT CONTROLS THE CHANGES ON MY REMOTE? THANKS MY E-MAIL rr@suddenlinkmail.com
    President:
  • 4,402 Answers
You should just turn it off and it will reset to where it was, i recommend getting a service tech to look at it.
Posted on Feb 11, 2008
I have an emerson sensi thermostat. Recently Not able to turn mode to "cool". "Heat" and "off" work fine.
Please explain. It's the mode button that you push in and it changes on the screen correct? It does not actually move left and right?? I'm confused.
Jun 25, 2017 | Emerson Heating & Cooling
Sony kf60xbr800 red ghost
See if you can download the manual from here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KF60XBR800
Also, if you haven't been here already:
http://esupport.sony.com/US/perl/model-home.pl?mdl=KF60XBR800&LOC=3
Hope that helps!
Feb 05, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
How to restart my tablet without turning it on because I forgot my password?
Look in your tablet instruction book for a procedure called 'hard reset' or a location for a small hole on the edge or back of the tablet where you can push in something non-conductive, like a toothpick to press a hidden reset switch. Without having a make and model for your tablet, it is hard to determine what exactly to do because each make and model is different. You talk about pressing the power and low volume buttons- are you holding them both in simultaneously for 10 seconds? This might be the reset procedure for your tablet, but that is not clear. One last thing to try is to hold in the power button for 10 seconds and see if you get a power off screen. If you get this, try powering off the tablet and then restarting. Also make sure the keyboard isn't on caps lock when you type your password.
Jan 03, 2015 | Tagital Taital TM 7" Android 4.0 4B MID...
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How do we get the picture back to normal? The picture seems to be stuck in a zoom mode. The wide button does not fix this.
its probably a zoom setting on your cable or sat box.
sat - push the format button at the top or bottom of the remote to switch modes
cable -
go in to the cablebox menu, go to video settings, make sure its set to 1080i and 480i for 4:3 over ride, not stretch or zoom
Jun 07, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Resetting the mileage readout for changing oil, brakes, etc.
if this is a 2006 or old sprinter....turn the key on...push the button that changes the reading from odometer to trip to sevice interval ....til interval shows...turn key off...push button and hold it....while holding button turn key back on....hold it til interval resets
Sep 09, 2008 | 2006 Dodge Sprinter
60xbr800
do you have an email address?
Feb 08, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
