Indicator Panel on Quasar VCR
The Indicator panel on my Quasar VCR does not light up anymore but I can use my remote control to tape etc....
    Champion:
  • 206 Answers
Well the front panel voltage has died, however to attept to repair this will far exeade the cost of replacing this unit, Whith the cost of VCR's around $25-$45 any repair on a Vcr seem's pointless, So it's time for a new one
Posted on Feb 15, 2008
  • 979 Answers
Display tube is needed...accordianman
WHATS DE CODE NO.
Hello
You are in need for universal remote code for Insignia TV, I assumes and post this solution.
Four digit universal remote codes for Insignia TV are:
0103 0189 0217 0135
0133 0116 0167 0456 0029
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
CODE SEARCH METHOD
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Sep 11, 2011 | Insignia 42" LCD Flat-Panel HDTV
Need code for toshiba flat screen tv
Hello
Three digit universal remote code for Toshiba are:-
013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Four digit universal remote codes for Toshiba are:-
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
NB: Switch OFF and switch ON your TV, with its front panel power control switch each time before trying an other code.
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Mar 13, 2011 | Toshiba Televison & Video
Need the code for insignia tv, so I can watch it thru my cable dvr...can't get the correct code for the remote
Hello
Four digit universal remote code for Insignia TV are:-
0103 0189 0217 0135
................. 0133 0116 0167 0456 0029
Direct Code Entry
[edit] Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK.
Mar 08, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
I need the codes for an emerson tv, I have the ge remote rc24914-E
http://kbase.x10.com/wiki/Universal_Remote_Code_List
you can also manually find it follow your universal remote control user guide If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Manually turn on the device (TV, VCR, etc.) to be controlled. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit. Press and release MUTE to install the code. The indicator light goes off. Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 05, 2011 | Televison & Video
HOW TO PROGRAM THIS TV WITH A UNIVERSAL REMOTE
Here you can find almost all the Universal remote codes
Lost remote-have universal remote
You can use any universal remote for any Electronics device
I need the 4 digit code for my LG 42LD520 in HDTVReady LCD TV to program my Remote. Thanks
Mar 05, 2011 | LG 42LD520 42 in. HD-Ready LCD TV
How can i find remote control codes for my quasar tv
Hello
Three digit universal remote codes for Quasar TV are:
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit univeral remote codes for Quasar TV are:
0171 0148 0054 0170 0062 0374 0381 0003 0070
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. NB: Switch OFF and switch ON your TV, WITH ITS FRONT PANEL POWER CONTROL SWITCH, each time before trying an other code.
OK.
Feb 23, 2011 | Quasar VV-1301 13 in. Combo
What is the TV Code for programming the remote control for Quasar TV model # v v 2018 w ? Thank you.
Hello
Four digit universal remote control codes for Quasar Tv are:-
Three digit universal remote codes for Quasar TV are:-
Direct Code Entry
OK.
Dec 08, 2010 | Quasar Televison & Video
What is the Quasar TV code when using a Direct tv REMOTE?
Hello
There is only one four digit remote code for Quasar TV with me. Here it is. You just try. Proceedings are also given. Ok.
[0716]
Proceedings
Oct 24, 2010 | Quasar SP-3232 32" TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
