Question about Motorola Mobility RAZR V3
Motorola V3 - Loose top flip
Is there an easy way to "tighten" the hinge? When my phone is open it is very loose and the top part flops around.
  • BobMac Feb 11, 2008
    "the phone need to be open and fixed" What kind of help does this give me really????????
  • ejayy May 20, 2008
    we have the same problem dude!
  • 93 Answers
The phone need to be open and fixed
Posted on Feb 11, 2008
The cold water handle is flopping around and seems to be in need of tightening but I can't figure out how to tighten it
There is a little allen screw under the handle. It is loose get a little allen wrench that fits use long end and tighten
Hope this helps Mike
Jan 30, 2016 | Plumbing
Tighten minolta 10X40 j-B35
Cloudynights person says it was very difficult to get the cap off the hinge so that he could tighten it. He had to hone small screwdrivers until he could pop off that hinge (it is so well sealed for the WR rating, I suppose). Then he could get to the bolt that tightened the hinge so the binos stopped flopping about. I still don't know how he got that cap off, though.
Mar 15, 2013 | Minolta Optics
Tighten hinge on presario 700
There are no adjustment available to tighten the hinges on a laptop. They need to be replaced.
These WEB site will assist you in replacing hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/b>Laptop repair infohttp://www.laptoprepair101.com/
Mar 28, 2012 | Compaq Presario 700 470024-192 Notebook
When I close the fridge side the freezer side pops open a little and stays open. The appliance is 5 years old. This started very recently
a couple of problems can cause door problems first open door and check seal for damage [popped off trac or rip-tears]other is hinges worn- bent-loose --if seal is good at top and bottom of door are hinges check for loose if loose tighten -if bushing lookes like a little round washer type is broken or missing replace --needs realignment loosen top hinge and close door and adjust till door is straight and stays closed tighten door hinge done good luck
Jun 28, 2011 | Jenn-Air JCD2389G Side by Side...
The frame around my laptop is comming off !
pull the bezel off see iff you can tighten the hinges down some times the screws come loose.if you have to replace hinges it is a easy fix just have to remove a couple screws.
Jan 08, 2010 | HP Compaq Presario CQ70-120US Laptop
Sun visor won't go back into place
if its flopping around or feels loose you can try tightening the "hinge" that connects it to the roof and tightening the screws on the visor itself. That might align it enough to fit again properly.
May 26, 2009 | 2006 Kia Optima
The door flops open as the rope has broken. I have the replacement part but need a diagram to show how to replace the part. Where can i find the diagram?
Documented in the manual...The plastic part goes on the metal hinge on the door...follow the rope down to the top wheel (clockwise and around) to the bottom wheel (counterclockwise and around), attach to the spring.
Apr 12, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Loose hinge on nintendo DS light
i had the same problem and wat i did was put some plasters around the loose hinge and it worked but i couldend close it down i hade to keep it up.i advise u do the same cause theres no way to tighten it
Feb 18, 2009 | Nintendo DS Lite Console
I have a Whirlpool Model# LSQ7030LQ0 washing machine. The washer is making a lot of noise and the agititator seems loose and is flopping around as it turns. If I grab on to the agitator I can stop it...
This "MAY" be an easy fix,
I have seen the main bolt that fixes the agitator to the drive shaft come loose.
If you can imagine the agitator as a cone, the top point of the agitator is a cap that should pull or clip off. If so, using a long extention shaft and a socket set, you should be able to tighten up the bolt.
Good luck and post back results
Jul 08, 2008 | Washing Machines
Loose hinges
I met this problem almost all brands of laptops. Depending on how the hinges being built (return spring, embedded lock notch, etc.) Some are easy to adjust and some need more precise tightenings due to wear and tear of the lock notch. However you can buy hinges too at ebay just specify the brand and models as well as the LCD screen part no. replacement. Hope this gives you hint.
Best regards,
Rosener
Feb 14, 2008 | Dell Inspiron 4100 Notebook
Motorola Mobility RAZR V3 Logo
186 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
