Question about Konica Minolta magicolor 2300DL Laser Printer
How to change the drum on 2300 DL
Message that the drum has come to its life end. Can I change it without much technical knowledge?
  • 6 more comments
  • Anonymous Feb 26, 2008
    damn i cant fix it.
    there is no instruction on the box minolta sux ass.
    hoe to change the drum unit?
  • Anonymous Mar 17, 2008
    Were is the drum and how do I get it out? 2300 printer
  • Anonymous Apr 01, 2008
    i tried the suggested methods, but i still don't get it, if possible please show a diagram or picture of the waste box and or of the drum unit
    thanks
    rosa
  • Anonymous May 08, 2008
    I know where the drum is, but can not get it all the way out
  • Faith Man May 18, 2008
    I am having that same exact problem. Please help me change the drum on 2300 DL Thank You!
  • Anonymous Jun 02, 2008
    I need instructions on how to change the drum cartridge. There are none with the new cartridge.
    Please hurry as the old one has expired.
  • Anonymous Oct 17, 2008
    I replaced the Drum, but the print quality is still very poor.
  • ebay-ebay May 17, 2009
    I have changed the drum OK and print quality is now restored, However the machine still reports Drum Low 1% remaining. I can't find the menu that tells the machine I am (or have) changed the drum.
Turn off printer.
Open side door, remove waste toner box.
Lift blue bar (in direction of arrow) to release drum assembly.
Grip tab as shown in small image, press and pull drum assembly out of its slot.
Take NEW drum and slide back into its slot, pressing it into place over the metal guide pin.
Pull yellow tab to remove protective film from drum (discard this).
Lower blue bar to engage drum.
Replace waste toner box, close side door, turn printer back on and let it cycle to start.
That should be all there is to it.
Posted on Oct 08, 2008
  • 4 Answers
Another option is find glass fuse on this drum unit... just change for new one (64mA/F) and you dont need to buy a new one drum unit.
Posted on Oct 17, 2008
Read the best solution above for changing the drum. Perfectly simple that even a girl could do it without any effort. :) Thanks for the hints.
Posted on Mar 18, 2008
IT IS SIMPLE LIKE ABOVE - HOWEVER, IT TOOK A BIT OF MUSCLE TO GET IT OUT
Posted on Mar 04, 2008
    Champion:
  • 214 Answers
Yes, its guite simple, and also there should be instruction, in side the cover and also with new drum, its like changing the toners.
you have to remove the waste toner box, just pull and then there is a lower green what you can bush and pull out. simple
Posted on Feb 12, 2008
Data mb-460 drum life
Yes,
That message indicates the drum is getting close to the end of life. The printer shows the message a bit before the end of life on the drum so you have time to order one before it goes out completely. You can get them from your office supply dealer or from Amazon.com
Apr 04, 2013 | Oki Electric Industry MB460...
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
KUWIT OIL COMPANY IAM FACING PROBLEM IN FAX MACHINE BROTHER 2820 MESSAGE SHOWS 'TONER LIFE END' AFTER CHANGING TONER MESSAGE REMAIN SAME PLEASE GIVE ME SOLUTION. I HAVE AROUND 24 FAX MACHINES BROTHER...
you must have remove the white mylar sheet from the catridge when loading it...if yes! you got to find back the white mylar (plastic sheet) that slot in between the drum and charger roller placed it back ( the position must be accurate) then slot in back the catridge.The white mylar sheet is to reset the drum life counter
Jan 26, 2011 | Brother Office Equipment & Supplies
I change the drum for my fax machine, but it still says Toner Life End... and it is a bran new cartridge?? I tried turning it off and on, and unplugging it... but it still says Toner Life End... how do i...
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Brother IntelliFax-2820 Laser Fax
Does the 'Drum Near End' message for MFC 8460N mean to indicate the toner cartridge needs replaced?
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Dec 17, 2010 | Brother MFC-8660DN All-In-One Laser...
MFC 7340 - I changed the toner cartridge, and cleaned the corona wire as instructed. When I put the drum unit back in, I get the message "Open front cover clean corona wire". I clean the corona...
The drum unit may be at it's end. There is a report you can print that will say "Drum" life at the bottom of the page. I think it's the "User Settings" or something. Though it sounds like you can't print to find this out anyway....Do you recall how many times you've changed the toner without changing the drum? Usually you can expect about 4-5 toners on every drum. Once the drum's photo sensitive coating wears off it is incapable of charging correctly to print. Might just be time for regular maintenance. panderson@cartridgeworldusa.com with questions.
Oct 29, 2010 | Brother MFC-7340 All-In-One Laser Printer
Drum life low replace soon Error Message
I already answered this at some other place here - but just to make sure the word gets out there:
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner assembly - and you can rotate it counterclockwise all the way back. This should reset the drum counter - worked for me!
I hope it also does the trick for you ;-)
Apr 03, 2009 | Panasonic KX-MB781 All-In-One Laser...
Toner life ends
There are two units in the machine, a toner cartridge and a drum unit. The toner clips into the drum and then is inserted in the machine. If you changed the toner and you still get this message, you may have a bad or damaged toner detection sensor.
Jun 30, 2008 | Brother MFC 7420 All-In-One Laser Printer
'DRUM CARTRIDGE END OF LIFE' MESSAGE
The back right of the drum has a small 20mm F80mA fuse that you need to replace to reset the drum counter.
(fuse blows to reset the drum life setting)
May 09, 2008 | Konica Minolta magicolor 2430 DL Laser...
Drum End of Life
Unfortunately the manufacture has you over a barrel.
Have you contacted Minolta?
Ask for technical support sry not much help.
Nov 27, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
725 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
