Question about Adobe Photoshop 7.0 for Mac
Creating contact sheets in Photoshop 7.0
Hey,
I'm creating a contact sheet at the moment and I want 5 columns and 2 rows, this is all fine except the pictures could be bigger. The margins between the pictures seem very big, how can I make them smaller so that in turn the pictures will be bigger?
  • avinasharma Oct 24, 2008
    i want to create a contact sheet with 6 frames bt the margins betweent each frame is too large. How can I increase the size of pictures and reduce the margin gap.
How much? program install Adobe photoshop
Posted on May 15, 2008
Just click on zoom butten.
Posted on Mar 15, 2008
I’m trying to create a vlookup formula cell F2 that will look up the merchandise code in E2 and display the name using column K and L. Look for wpexact match
create an additional sheet in worksheet at the bottom of worksheet is a +
add a sheet put each merchandise code in each row going down the column worksheet.
in the next row put the name beside the matching code.
then when finished sort on both columns using the merc, code to sort ascending.
code_lookup1-lcxufp0edjxqrfkkn22ib0r3-5-0.jpg notice in the next picture the addition of $ in the row
this is done to allow you to copy down the formula and leave the reference array the same
code_lookup2-lcxufp0edjxqrfkkn22ib0r3-5-2.jpg look at bottom of spread sheet to see additional sheet being used called code to create the array for the look up. With more array rows just modify the formula to say =lookup(a2,codes!$a$1:$b$200)
lookup will give you a text answer where as vloopup will give a numerical value !
May 07, 2018 | The Computers & Internet
How to make a 7 row and a 7 coloum in a spreadsheet
Creating a table in Microsoft Excel 2007 allows you to work with that data independently of the rest of the worksheet. First you must define your table, though, which you can do either from scratch or from data already in the worksheet. The process is a simple one. Read on to learn how to define a table in Excel 2007
  • Start off by doing one of the following: Select the range of cells that you want to make into a table within your worksheet then proceed to Step 2 OR Start immediately with Step 2.
  • Click on the "Insert" tab at the top of the document.
  • Find the "Tables" group, then click on "Table." The "Create Table" dialog box will appear.
  • Type in a range for your table if you did not select a range in Step 1. If you did already select a range then that range will automatically appear in the dialog box.
  • Check the "My Table Has Headers" box if the data set you selected already contains the headers you want to use. If you don't check this box, the table will display default header names, which you can then go in and change.
  • Hit the "OK" button at the bottom of the Create Table dialog box to create your table.
  • Thanks for choosing Fixya............ Sandeep
    Mar 18, 2011 | Computers & Internet
    Creating tables
    this is how to create a table
    1. Click where you want to insert a table.on you work sheet
    2. click On the Insert tab, in the Tables group, click Table,
    3. Replace the data in the template with the data that you want.i.e the number of rows and columns you want
    that is it
    Apr 28, 2010 | Microsoft Office 2003 Basic Edition...
    Creating vacation accrual spreadsheet
    Here is one way to do it:
    1. In column A enter the name
    2. In column B enter their start date in the format day-month-2008 (31-12-2008 for Dec. 31, 2008); if a day is less than 10, put zero in front (03, 04, etc.)
    3. In column C put 31-12-2008 (December 31, 2008, the last day of the year)
    4. In column D, put C1-B1 and format as a number with 2 places after the period (10.25 for example) if you want to track partial days, other format for no zeroes after the period (13)
    5. In column E, put this formula:
    (D2/30)*1.25 (assuming this is line 2)
    You can then copy these lines as many times as you need to, total them, etc.
    Dec 27, 2008 | Microsoft Office Standard for PC
    Need to use the VLOOKUP formula for more then one column
    You probably need to organise your pricelist sheet so that you only have 2 columns, product and price. If this doesn't fix you, please provide the syntax of your vlookup code.
    Dec 10, 2008 | Microsoft Excel for PC
    Excel support
    Cool problem I use this to track stocks for the latest 5 days, 15 days and so on.
    First I have a sheet that is titled "DataRecord" this has my individual data in columns and the days recorded in rows. This is a complete record or all recorded stock activity. This is where all the entrys are made in rows. I freeze window to make the column headings and the left most column(the date) always visible to prevent errors.
    Next I have a sheet that is titled "L5DaysData' I have sevreral rows of data like avg, & what ever. and the latest 5 days data starts on line say 6. a typ. cell ='DataRecord'!B970
    The next cell down has a value of ='DataRecord'!B971 and so and on until B974
    My Graphs are built on these individual "L5 or 15 or 60 or90 day" sheets of data.
    Next I make a macro that translates the last line of data down one row and deletes the row just above the earliest that I want to save on "L5DaysData" so it always shows only the latest 5 days of information.
    All the information shown on that worksheet is the data for graphs or tables refering to the latest 5 days activity.
    The graphs are automatically updated with the data each time the macro is run.
    You can also use a formula to adjust the date column by adding a value of one to a specfic dated cell untill you reach Sat or Sun and add 3 or 2 to that date cell and translate that down a column and use a work sheet that records only the latest 3Mo. with macros that updates the information when you want it to.
    Hope this helps.
    Glad to be of assistance - please rate the solution I can learn from you. Thanks
    Oct 24, 2008 | Microsoft Office 2003 Basic Edition...
    Excel Formulas
    Try using a software called MacroRunner for Excel v1.0.. you can download this from the following link
    http://www.filebuzz.com/fileinfo/21205/MacroRunner_for_Excel.html
    Good luck.
    Feb 05, 2008 | Computers & Internet
    Lookup,s
    If you can move your name column (C) to the first column, you could leverage the VLOOKUP formula pretty easily.
    To do this, do the following:
    1) Move the C Column to be the A Column, shifting all other columns to the right.
    2) (optional) Insert a new row at the top of the sheet (to hold the formula & seach value)
    3) Use A1 as your search field.
    4) In A2, enter the following formula:
    =VLOOKUP($A$1,$A$2:$C$6,3,)
    Describing above parameters, in the formula:
    $A$1 -> the search field (name your looking for).
    $A$2:$C$6 -> The table/grid you wish to search and return values from. The left most column (A) must contain the values to be searched.
    3 -> is the column number (A=1,B=2,C=3, etc) within the table/grid to return.
    If you cannot make the name column your first (A) column, there are more complex ways to do this. For instance, create a new sheet which redisplays the info in the structure easier for this method, and perform the VLOOKUP on that data. Other options might exist in creating a complex formula that would get you what you want.
    Also, if you can sort column A (names) it would find results faster, if your data set is large.
    Feb 03, 2008 | Microsoft Excel for PC
    Duplicacy in excel sheet
    Since you are searching the data by the phone number , first select all the data in the spreadsheet and sort it in ascending order by the phone number.
    Then, assuming you have 5 columns of data A through E, and the phone numbers are in column E, with row 1 occupied by column headings, use the following formula in cell F2=IF(E2=E1,"Duplicate",1)
    Drag this formula down column F till the end of your data
    Select the entire data and do an auto filter
    In column F filter the data by Duplicate and delete all these rows
    What remains should be unique data
    Dec 19, 2007 | Computers & Internet
    Formula required
    at first select the 1st page data and select data-subtotal from the upper menu list.
    then enter the formula as =sum(1stpageSubTotal,2ndpageSubTotal,3rdpageSubTotal) then Press Enter.
    If not solved pls get me that data as to reference.
    thanks
    Dec 04, 2007 | Microsoft Excel for PC
    Adobe Photoshop 7.0 for Mac Logo
    114 people viewed this question
    Top Adobe Computers & Internet Experts
    Alun Cox
    pankaj rautela
    pankaj rautela
    Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
