Question about Sony KP-65XBR10W 65" Rear Projection Television
Looking for How can I get back in touch with Techman who was helping me a few days ago?
    President:
  • 3,130 Answers
I AM RIGHT HERE!
Posted on Feb 11, 2008
2002 ford escape about two weeks ago started having trouble starting would turn over but would not start you had to turn it over 3 or 4 times before it would start then no more trouble the rest of the...
depending on your knowledge of the vehicle check the crankshaft sensor, and the fuel pump relay. see in you are getting spark to the plugs.
Sep 29, 2010 | 2002 Ford Escape
I have a Hitachi Ultravision 51'' I just replaced the light engine and it worked great for the last few weeks. But 2 days ago we started to see a yellow tinge in the middle of the screen. I wanted to know...
sorry to tell you that you probally got a bad new one . contact who you got it from asap to get an replacement. when you replaced it did you clean all the fans and vent areas up ? for this can cause a light engine failure due to over heating. thanks....techman
Mar 31, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
My internet explorer will not open up on my htc touch pro2. it was working fine a few days ago.
Try restart your phone. It is advised to switch off the phone (especially WinMo) once every 3-4 days.
Oct 13, 2009 | HTC Touch Pro Smartphone
When i plug in device in to a usb port my computer freezes up
have you tried a different USB port because theres two types of usb port & one on the back has pin's inside it check that these arnt bent or touching you should use the side ports for your basic everyday external devices.
Aug 12, 2009 | Computers & Internet
Pc help
this is your jck problem.
check other head phone or speakers to it.
Nov 15, 2008 | Computers & Internet
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
DM Power on problem - Can I use 35V Caps instead/ (Techman??)
If they fit, sure but If I'm not mistaking, they are too tall. And they really should be the high temp caps, as if you do not use hi temp caps you will be in the same boat down the road. Good Luck
Jul 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
TV wont come on
Most likely cause would be a blown fuse on the power supply if you are getting no lights on the front, no response from the buttons, and no warmth from the back of the set. First check that not only is the power socket in the wall working, but also that the plug on the TV power cord is not faulty or distorted so it doesn't make the circuit when plugged into the wall, also if it has a fused plug, check that. Then if you feel up to taking the cover off, make sure the set is unplugged and leave it for a few minutes first. take off the back cover (usually a few screws around the base of the set, but it should be obvious) follow where the power cord enters the box, and about the first thing it should connect to is likely to have a fuse. Probably a couple of metal spring clips with a glass tube type fuse sitting in them. The fuse should have a rating stamped on it and you should be able to get a replacement at most hardware stores, but make sure you get the same type as well as rating. If a replacement fuse doesn't cure the problem then the next thing to suspect would be the transformer and rectifier circuit - the fuse should have protected these, but sometimes it doesn't work that way. If you need help checking these then please ask again, but I suspect the fuse is your problem. Hope this helps you out, please ask again if you need more info :)
Mar 24, 2006 | RCA F32450 32" TV
Sony KP-65XBR10W 65" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
