Whirlpool spin problems
Clothes sometimes spin correctly sometimes come out soaking wet .... tried smaller loads ... down to one item .... tried less detergent ... checked drain hoses for blockage .... no luck .... any suggestions .... machine is about 7 years old .... thanx
  • francis rivero May 11, 2010
    what is the model number of the washing machine please?
  • 958 Answers
I'll try that link tech 17... tnx...
Posted on Feb 12, 2008
    President:
  • 1,314 Answers
Hey dr cool i thing this customer is looking for you but didnt know how to respond try here http://www.fixya.com/support/t391466-spin_problems
Posted on Feb 11, 2008
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
Clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Feb 21, 2010 | Whirlpool LSB6200KQ Top Load Washer
After the spin cycle runs the clothes are still soaking wet
I had that problem at one time with my old washer and what it ended up being was the Washer Dog Agitators were broken and causing the it to slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
moz-screenshot-2.jpgLet me know if there is anything else I can do.
May 25, 2009 | Washing Machines
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Dec 21, 2007 | Washing Machines
Clothes come out soaked
You water is not being pumped out when the spin is on; this is due to the outlet filter being blocked. Find out where this is from your users'manual and clean it out. This is to be done periodically according to your usage.
Jun 18, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
