Question about Procom ML300EBC Heater
Heater runs 2 min. shuts off
Heater runs 2min. & shuts off including pilot heater works fine in manual overide mode
  • rsarver Oct 23, 2008
    same thing except it runs for 30 seconds and then shuts off.
  • surveyor69 Jan 31, 2009
    heater will light and run for two to five min. then shuts down, pilot and all untill I uses the electric ignition to relight it again. just started doing this a few weeks ago. cannot find model number on unit but I know it is a procom and bought it a year ago
Aim the pilot flame harder down the thermocople.
Willis
Posted on Dec 07, 2008
Replaced a H100 Hayward pool heater with a H2101Heater.New heater runs 4 about 5 min. Then shuts off including pilot. Filter is clean .getting plenty of water pressure. Gas line has no leaks. What's the...
check to see if gas pressure is correct sounds like too small a gas line or meter with pilot going out shows you are draining gas line you have doubled your gas usage
Jul 08, 2014 | Pool & Spa
Pilot and heater works for about 2 min and shuts off heater and pilot
check gas pressure if too small a line that will happen or too low gas pressure
Aug 08, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
30,000 btu wall mount reddy heater nat. gas. pilot lights and heater will run for about a min. then i hear a click in the main control and everything shuts down. Is this the double safety i read about...
Yes your pilot light may not be surrounding the thermocouple. Check and see it the pilot is burning blue and surrounds the thermocouple . These units are very sensitive if even a little breeze across the unit. You can clean the pilot with compressed air or maybe even a small wire brush. If this doesn't work you may have to change the thermocouple.
Apr 21, 2011 | Heating & Cooling
Wall furnace shuts off after about 10-20 mins
sounds like its not venting properly...it likely is shutting off on a "Spill switch" or "Vent safety switch"....check the vent/chimney first off.....also the pilot could be dirty..,..a lazy pilot tends to blow out easily....pilot should be blue and sharp,,,big enough to fully envelope the thermocouple
Oct 30, 2009 | Heating & Cooling
Laars Lite 2 Gas-Pilot stays on, but main burner shuts off 10 min
A polit generator produces about 750 MV without a load. Under load it will drop to about 200-250 MV. If the system is working don't worry about it. If the system is not working replace the pilot generator and retest. Pilot generators usually go bad slowly.
Jun 22, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
No able to lite pilot
make sure gas supply is there also clean the thermocouple, if it is fowled or dirty the pilot wont stay lit nor will the main gas valve open
May 24, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot makes wind noise
pilot dirty or to much gas pressure to pilot or problem in venting
Feb 19, 2009 | Reddy Heater RLP100 Portable Forced Air...
Procom ML300EBC Heater Logo
468 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
