Hi, I bought a new Philishave HQ 481 razor last year from Boots,chemists.The shaving heads lost there cutting edge very quickly and are now completly blunt.I have been trying to get new heads but cannot get them anywhere.Can you advise me where to go and the cost of 2 shaving heads. Many thanks, Graham Lewin.
SOURCE: shaving head check indicator still flashing after installing new heads
Apparently you need to change the heads within two weeks after the red LED first starts to flash, otherwise the memory chip inside needs resetting. This also poses a further question. How does the unit know the heads have been changed or not ?
Posted on Feb 09, 2008
SOURCE: Dad's favourite razor needs new battery
Found a serice center nearby
Posted on Nov 25, 2008
brector3
  • 1612 Answers
SOURCE: Arcitec razor 1050X will not cut whiskers
You are certainly not th first person who hasn't been happy with the Arcitec model. If it never worked well for you from the beginning, there is nothing that will make it work now. It's a shame that you've waited past the 45 day return period.
Your old shaver, 6885XL, was a "Quadra" model. These were a popular model type that is now discontinued. If you still have it, it may be able to be repaired. If you would like to replace it with another Quadr model, you will find one at shaveroutlet.com. See link below
http://shaveroutlet.com/shavers/norelco-7886xl-quadra-action-shaver-factory-refurbished-p-534.html
This model is virtually identical to your 6885XL except that it is a newer version
Posted on Oct 13, 2010
brector3
  • 1612 Answers
SOURCE: I have a Philishave 990 - it is over 10 years old,
You will find the correct replacements for model 990 at shaveroutlet.com. See link below
http://shaveroutlet.com/specials/norelco-philips-hq4-plus-replacement-heads-also-fits-eltron-p-248.html
Posted on Oct 15, 2010
brector3
  • 1612 Answers
SOURCE: how to remove batteries from a philishave razor
You will find the correct battery type for model 6863XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. Take off back cover to access inside. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Posted on Dec 20, 2010
How to get replacement heads for philishave cool skin HQ6761
Compatible blades can be found at shaveroutlet.com using the link below
http://shaveroutlet.com/philips-norelco-hq7-gentlecut-shaving-heads.html
Jun 28, 2014 | Philips Philishave Cool Skin HQ6760/HQ...
Tip
How to use an electric shaver
If you are a using an electric shaver for the first time, I hope that this article will get you going. Proper techniques will ensure the best, closest shave possible. Maintaining the razor by properly cleaning and recharging it will also ensure that the razor works correctly and does not malfunction during use. Proper care and maintenance of the electric razor will also ensure that the razor will last for years to come. Consider this article as a shaving-best-practices template for your first electric shaver.<br /> <br /> Firstly, clean your face and dry it. Electric shavers do a better job when your face is clean. Turn the electric razor on and begin shaving against the direction of hair growth, moving the shaving head linearly and in circles. Circular motion Stretch the skin with your other hand to make the hair stand up straighter so the razor blades shave closer.<br /> <br /> After shaving, turn it off and rinse the cutting heads under warm water. You can also use jet clean system once a week to clean your shaver. Make sure that you charge it for the time specified in user manual. Overcharging may cause damage to the battery.
on Mar 03, 2011 | Health & Beauty
What is an electric shaver?
Not like shaving razors, electric shavers work by shearing the whiskers, the hair enters the perforated metal heads of the shaver and is cut by the moving blade inside.
Feb 06, 2013 | Health & Beauty
I NEED TO GET A NEW HEAD FOR MY PHILLIP 12 m Razor
In the UK, philips philishave HQ8150 replacement heads is Norelco HQ9 replacement shaving heads.
Dec 10, 2012 | Philips Philishave HQ8150 Electric Shaver
I need new shaving head can i get it in bhopal and what would be the cost
In the UK, Philips norelco HQ56 replacement heads for Philishave Micro Action HQ 4806 electric shaver blades parts.
philips HQ56 replacement heads UK
Nov 19, 2010 | Philips Philishave Micro Action HQ 4806...
I have taken out the heads to clean and put them back and n ow it wont shave me
Remove the head assembly again and check to see if anything is out of place or missing. If not, try reinstalling the shaver head assembly and give each individual head a light push and spin to try to get the drive connections to line up with the razor.
Then turn the razor on and off quickly for a second or so to let the razor align itself with the shaver heads. If this doesn't resolve the issue, then my first reaction is that you're missing a part(s) that might have fallen out when cleaning.
Give it a try and let me know if it resolved the problem.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Philips Philishave HQ7780 Electric Shaver
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
