Question about Antec TruePower Trio 550 (TP3550) 550-Watt Power Supply
P/S replacement in Gateway 2000 model year Tower
Have purchased an Antec EA-500 p/s to install, have made all connections but one, The Gway motherboard has a unique connector and Antec p/s has no modular connector to fit, I have old OEM p/s and can change out mod connectors but I need to know what is required on the flat verticle pin plug on the motherboard it is next to the ribbon connectors on the motherboard, white in color and has these flat pins in a row, 6 of them.
Hate gateway.....Had a time keeping this computer running, Now I need to get it back up and running and I need help,BAD. Any assistance will help identifing this modular connection and what voltage is required....Thanks
  • 593 Answers
Gateway may have a unique non standard pinout for its P/S. I would match up the colors in sequence on the new PS and see if the old harness had the 6 pin connector and graft them into the new harness. The colors are standard for voltage.
Posted on Feb 15, 2008
I bought a HP 6710f Pavillion desktop, running windows 7, and found out it only has a 250 watt power supply. I turned around and bought an Antec Greenwatts 500 watt ATX 12v v2.3 psu to install for future...
Presuming you mean the Earthwatts 500:
Should work, though the Earthwatts has the 24 pin ATX instead of the 20-pin.
http://www.atxpowersupplies.com/manuals/Antec-Earthwatts-EA-500D-user-manual.pdf
You just need to snap the 24-pin connector apart to make it work as a 20-pin. It can be snapped back together for future motherboards.
The Bestec is just a standard ATX power supply
Mar 23, 2011 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Gateway PC into Antec enclosure?
Hi:
You should be able to transfer your motherboard to the new case, but some things to check before you do:
How do the power switches and front audio/USB connections work for the old gateway? Are they standard or vendor specific? Are the optical drives in the gateway standard, or do they have special fronts on them? I have done what you are wanting to do several times, and often you need to replace OEM optical drives, and sometimes the motherboard headers don't match up with a builder case, so you do the best you can.
Dec 11, 2009 | Antec Aria - MicroATX Cube Case W/Power...
I need help installing a cd drive in an Antec Sonata III 500 computer case. How do I do it?
Unplug the power from the computer. Open the case cover. Carefully remove the placeholder on the front of the case where you wish to install the CD drive. Make sure you have the proper ribbon cable for the type of drive you are installing and that you know where to plug it into the motherboard (consult your motherboard manual).
Use the screws provided to secure the drive to the chassis rails (make face of drive flush with front of case). Attach an available power supply connector to the new CD drive. Close the cover.
Dec 04, 2009 | Antec Sonata III 500 - mini tower - ATX ...
New build worked for about 10-15 minutes. the shutdown. Phase LED blink once. Fans appear to start to move, then nothing. Gagabyte P55-UD3R, Antec 500 PW, Antec 300 tower
if you cannot get into the BIOS setup, remove and re-install the processor and memory modules. make sure that no foreign materials can be found on the metallic contact point of the processor, memory modules and their sockets. does anything appear on the display or absolutely notihg at all?
Oct 04, 2009 | Intel Motherboard
Antec sp-500 power up?
Hi oldgunny, I think you would be better to shoot it befor opening it. The only serviceable part inside is a fuse and if this was blown then it would not start at all, so regretable as it may be you will need to replace it.
Regards mistyman
Dec 18, 2007 | Antec SmartPower SP-500 (ASKU37152)...
Antec TruePower Trio 550 (TP3550) 550-Watt Power Supply Logo
96 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Julie Endres
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
