Question about Maytag Neptune MAH6700A Front Load Washer
Fabric Softener Won't Dispense
The fabric softener dispenser does not dispense. The soap and bleach do dispense.
  • 6 more comments
  • Todd Clayton Feb 11, 2008
    Thanks for getting back so quickly! Have gone as far as taking the dispenser out and cleaning it with an air-compressor. Before I re-install, is there anything else I can do to make sure it is cleaned out?
    You are correct. Three common hoses (hot, cold, and bleach). All hoses good, dispenser clean, and water is still not spraying on the fabric softener section.
  • Todd Clayton Feb 12, 2008
    Thanks for staying on it. I cleaned every spray hole in the dispenser shower and even gently ran wire through the three hose receptacles. As far as the "spring on the armature", the dispenser shower has no moving parts (100% plastic) and still no water getting to the "fabric softener" section of the shower.
  • slh2255 Mar 22, 2009
    Fabric Softner won't dispense. I have cleaned everything. Holes inside cavity are not clogged. I can see where water is coming out the soap and bleach holes, but not the fabric softner holes. Should I call the experts?
  • Anonymous Mar 13, 2014
  • Anonymous Mar 22, 2014
    My kenmore washer is not dispensing soap out of the dispenser
    softener dispenser will not dispense
    fabric softener wont dispense
  • 5,911 Answers
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Posted on Feb 11, 2008
  • 3 more comments
  • Jeff Rockwell
    Jeff Rockwell Feb 11, 2008
    You may check the hoses INSIDE the washer that lead to the dispenser to make sure they aren't kinked in any way. But...you said the the Detergent and Bleach dispensing works fine. I believe these are common fill hoses, but not sure. It may be worth a look if the cleaning you just attempted does not work.
  • Jeff Rockwell
    Jeff Rockwell Feb 12, 2008
    I'm not sure how your dispenser is constructed, but there should be some sort of plastic armature with a spring on it. The dispenser is driven by a small motor which turns the armature and selects the appropriate section of the dispenser to be activated for water to dispense into. Sometimes the spring comes off and the armature won't move. Could this be the case with yours?
  • Jeff Rockwell
    Somethng else I thought about...you said you cleaned the dispenser, but did you clean the cavity area where the dispenser came OUT of? If you remove the dispenser drawer and look inside the cavity where it is installed, you will see the series of holes in the top of the compartment that I described. These holes become clogged over a period of time and need to be cleaned out, or the water will not be able to get through to the dispenser. Has this been done?
  • Jeff Rockwell
    You've gotta have clog or something. Since you have no moving parts, I'm assuming the dispenser hoses are turned on and off by solenoids(?). Are there any electrical connections what-so-ever going to the dispenser? There has to be some method of determine WHEN the fabric softener cycle turns on. No spring loaded armature that turns the dispenser on to divert the water...hmmm...all the other functions are working. You have already cleaned the inlet ports and checked all the hoses. I'm assuming the washer fills BOTH hot and cold normally(?), because you didn't mention any other problems. (Just thinking in print, here). Look inside the washer for a tech sheet to see if there is a diagnostics procedure you can perform. Most front loaders have this sheet inside the washer attached to the cabinet wall. The diagnostics should perform a check of all the functions, to include hot and cold fill, bleach and fabric softener dispenser actions, tumble, drain and spin. I'm hoping you have a tech sheet that can provide you with some of these answers. The only other recommendation is to replace the operator interface board that controls those functions. I would hate to make an expensive move without first trying all other options.
  • Getterdun Aug 20, 2012
    Thanks Jeff. Your procedure above worked for me. I also used a metal, right angle pick tool and a slide in mirror.
The fabric softener dispenser (and bleach dispenser, same water line) on the Maytag MAH 6700 model works by time (controlled by the circuit board) and water flow from the cold water inlet valve. Check the screen on your cold water inlet. If clean, the water inlet valve may need to be replaced. They (two solenoid units together)are not repairable. If you are mechanically inclined take a look at the cold water inlet valve that has the rubber tubing running to the "bleach" dispensor nipple. It will have a water flow restrictor in it at the inlet valve. On my unit a piece of "stray" plastic was partially clogging the flow restrictor. I carefully drilled the valve out enough to remove the stray plastic. Now both the bleach dispenser and fabric softener dispenser work properly and at the correct times during the wash.
Good luck with your repair!
Posted on Dec 17, 2008
SOURCE:
Bleach dispenser
Check water flow INTO the dispenser. This happens during the
cycle to dispense the bleach evenly through the load.
Jul 22, 2014 | Frigidaire Washing Machines
The soap dispenser works but the bleach and softener dispensers do not
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener dispenser will not dispense ...still full after a load. Soap appears to be working fine. Not sure about bleach.
softener is likely hardened on the solenoid. the dispenser must be removed and cleaned.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Detergent and fabric softener dispense at the same time
Whirlpool has designed this drawer as a siphon feed and soap and softener go as 1, 2 punch followed by bleach mid cycle.
Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric Softener & bleach dispensing
The control board program has many sensors built into the unit to determine when to dispense the bleach and the softener.  LG tech documents doesn't list when these liquids are dispensed so there must be a program that matches the current operation and loads of each wash program.  That's the best answer I can give you at this time.
Jun 05, 2008 | LG WM2688H Front Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Maytag Neptune MAH6700A Front Load Washer Logo
13,234 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
