Nikon D70 Digital Camera with 18-50mm Lens Logo
Posted on Feb 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NIKON D70 I have a Nikon D70 Whilst taking a series of photographs I get through to about 40 images then the camera stops shooting and the format card display comes up on the display. If the CF card is removed the images taken are ok and can be down loaded. If the card is then replaced without deleating the images then further images can be taken until the problem re-ocurs. I have tested the camera by taking a full card of images all at once and there is no problem. The issue seems to ocur if the camera is left for any length of time between images 5 minutes etc or if the camera is turned off and switched back on again. I thought it was a memory card issue at first as it only happened with a 1 GB card but recently it has occured with a 512 card also
Anonymous
Level 2:
  • Expert 149 Answers
  • Posted on Oct 05, 2009
Anonymous
Expert
Level 2:
Answers
149
Questions
0
Helped
51283
Points
212
Problem in card holder repair or replace
3helpful
2answers
Nikon d70 keeps popping up with "CHA". Wich means
You could try formatting in on PC by right clicking the card's icon in My Computer to bring up the options, then format it on the camera as well
2answers
DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
1helpful
My nikon d70 says that file does not contain image data
If the memory card came from a different camera and inserted into the Nikon D70, the error message will appear. Just format the memory card with the D70 and the error should disappear.
Hope this helps.
Andrew
5helpful
I have a Nikon D50 with an error message "CHA"
This error indicates the following:
This card cannot be used (CHR) blinks.
Problem(s)
Error accessing memory card
Unable to create a new folder (on card)
Card has not been formatted for use on D70
Try another card
Format the card using your D70 (all images will be erased)
Check the card for visible damage or poor contacts.
You may have inserted a memory card that was been used in a different camera or the formatting process did not complete successfully.
I hope this helps.
I have a Nikon D70 and i am a photographer I shot a customers photos today. I shot the first half of the photos on this compact flash card and downloaded to my computer and then put it back in the camera...
shoot,
Is this a small capacity SD card? Like a 512mb or 1GB card?, you have to be careful not to shoot til the card is full, there's a risk of loosing data or corrupting what's on it. There are recovery utilities that can be loaded on your PC or Mac and run with a card reader to get the images back that are on the card. you didn't say what type of software you are using with the camera, is it Picture Project or Nikon's Preview software? Not just the Windows generic camera download. Also are you shooting in RAW? Let me know if I can help, I'll get you a name of a disk recovery site.
randy320sgi
Nikon D70
The "For" message means you need to format the memory card.
Copy anything you don't want to lose off of the card.
Locate the LCD Illuminator Button (next to LCD on top) and the Shooting Mode button (next to Brackting button (BKT) on back). Next to both of these button should be the word "format".
Simultaneously press and hold both buttons for two seconds. The card will format. Once done, the LCD will display the number of pictures available to be taken on the card.
2answers
Nikon d70 firmware version 2.0
u have card reader stick sd card in that formatt to fat 16 ok for cam if it had hd video use ntfc formatt ok
Nikon
The cards may have been corrupted in some way. Have you tried them in another camera or a card reader? If you have a reader, you might want to try formatting one of them from your computer.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
