Question about Reddy R155D Utility Heater
RC150F this unit would only run when unit was warm...changed fuel...cleaned tank..replaced....ignitor plug...fuel filter...now it doesn't seem to want to draw the fuel...ANY IDEAS??
  • 552 Answers
Http://www.desatech.com/manuals.cgi?oldpro=Construction+Heaters&products=Construction+Heaters&Manual=&Model=RC150F&Type=Show+All&x=75&y=11
Check out this link. There is a detailed owners manual and other info.
Posted on Feb 11, 2008
B2300. What are the probable causes of DTC P0132?
Use an ohmmeter to check your spark plug wires all have very close to the exact same resistive value
Nov 19, 2015 | 2004 Mazda B-Series
My truck runs fine until it gets warm and then it starts to lose power but if you shut it off and start it back up it runs fine for a couple minutes. I have changed the fuel filter, plugs and plug wir
u could have alot of trash in ur fuel tank so i would change ur fuel filter again or just take it off and see what comes out of it .if its clean fuel come out of it then ur fuel pump is getting bad
Jan 25, 2013 | Chevrolet Silverado 1500 Cars & Trucks
2006 triumph america cuts out, seems to lose power, run on 1 cylinder, have had 20,000 major service, carb serviced, tank checked (no debris). Cold, warm, or after rideing hard the problem can crop up
IT sounds like fuel starvation has it got a vacume petrol tap if so it could be that not letting petrol through sometimes or the vacume pipe is split or kinked or squashed
Dec 10, 2011 | 2006 Triumph America
The bike has sitting for 19 months in the garage and it doesn't start with one try, it doesn't seem to be running on all cylinders either. what could cause this and how could I fix this?
my guess is your fuel has gone off drain tank and replace fuel with at least 95 octane (do not use E10) you also may need to replace fuel filter which is under the tank and clean carby bowls
Jul 30, 2011 | 1996 kawasaki ZX-6R Ninja
Cub 1550 with kohler courage. Runs fine and then loses power, runs erratic and starts to backfire. Cleaned carb and fuel pump and ran fine for 30 minutes and then problem started again. When this occurs,...
Replace fuel filter after cleaning tank thouroughly, to clean tank remove fuel line at carb. Drain all fuel then leave line loose until you flush tank with carb. Cleaner then blow out tank with compressed air. Now install new fuel filter and check your fuel can for trash and water better yet just add fresh fuel.
Aug 12, 2017 | Garden
I have a 98 subaru lagacy wagon. It hestitates
My 98 Subaru has this same problem. I changed the filter and had the injectors cleaned and flow checked. I think that as the electric fuel pump (that is on the sender unit that is in the fuel tank) begins to wear out, the output of the pump drops off and can't keep up with engine demand during exceleration. I think this is why the car is hard to start with only a partially filled fuel tank. When the tank is not full, the pump is not "helped" by the weight (head pressure) of the fuel in the tank. I may be crazy. I will be changing this pump soon. I found one at my local Auto Value in stock for $130.00. Be glad you have a Subaru because you can take the sender unit out of the tank from inside the car. Other manufacturers make you remove the tank.
Let me know if you have any new developments.
Wes
Jan 16, 2010 | 1998 Subaru Legacy
Only runs for 15 seconds.
Testing a photocell is a simple procedure
How to test a photocell
Dec 15, 2008 | Heating & Cooling
Reddy R155D Utility Heater Logo
210 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
