Question about Refrigerators
Refrig compressor "knocks" when cycling off
Helped a So. FL friend whose frig was running continuously. It was typical lack of cleaning maintenance; coils choked with dust, hair, etc.
After a thorough cleaning, the unit cycles on/off. However, when cycling-off, there are several loud knocks or pings in the compressor area. It hums normally during cycling-on and while running.
  • 958 Answers
Could be a broken spring inside the compressor and would only make a noise as the compressor stops. nothing you can do about it. you would need to break open the compressor, replace the spring, weld it back, then charge it up again with refrigerant.
Posted on Feb 11, 2008
I own a Fogel Fridge Model # VR-17-RE-PR Recently
Richard,
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Refrigerators
At 100 deg.it does not shutoff automatically
If your talking about a refrigerator, it never will as its goal is to try and cool, and its trying. It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your frig is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Kitchen Appliances - Others
Product is about 6 years old. Used in basement. Worked great until this year. Now will run continuously but collect little water. What type of service do I need? This is a 65 pint per day Whirlpool.
There is some service that you can do ... Clean the filter and the cooling coils, regularly. Check the humidity level that you have the unit set on. It may be set to low and there's just not that much humidity in the air at this time, for it to collect. From what you said, it sounds like you may have it set on continuous cycle which could account for the lack of a lot of water in the bucket. In continuous run, the fan stays ON all the time. It's supposed to do that, so that the air is constantly moving and the sensor only turns the compressor ON, if it senses a humidity level 5% higher than what you have it set for. Try running the unit on a 1 or 2 hour cycle (if your model will do that) rather than continuous cycle.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Whirlpool 75-Pint Dehumidifier
My refrigerator keeps turning off
It could be a defective defrost timer if you have lights and NO fans running nor compressor starting you maybe able to tell if it shut off about every 5-8 hrs. Now if it shut off after every cool cycle then I would tap the refrig temp control with a firm tap if the frig starts then it is a defective operating thermostat.
Apr 09, 2011 | Refrigerators
Is the ge tbx19 defrost clock continious or cumulative?
The timer will advance whenever the cold control is on. (when the compressor is running, or the timer has advanced into a defrost cycle) When the refrig is cold enough (and the timer has not advanced into defrost) the timer will not be advancing. A typical defrost timer will count up 8 hours of compressor run time before going into a 30 minute defrost cycle. (the run time and defrost time can vary greatly from model to model)
Jun 16, 2010 | GE Profile 19.0 cu. ft. Top Freezer...
My freezer is not freezig and the refrig is not getting cold. There is a notice coming from what I assume to be the compressor in the back of the refrig at the bottom.
Check Relay and overload on compressor terminal. sometimes due to faulty relay overload tripping which makes tik tik sound. before replacing relay need to start compressor directly.
Nov 17, 2009 | Roper RT14DKX Top Freezer Refrigerator
Frig shutters and makes noise when the cooling cycle shutoff.
It is probably caused from one or more of the four rubber bushings that mount your compressor to the refrigerator frame. The bushings wear over time and causing the compressor bracket to have a little play. Then when the compressor stops it moves the frame slightly bumping against the mounting bolt causing a slight to moderate sounding clunk when stopping, Also check a lines and cords as a cord refrigeration line near the compressor or fram can also cause the problem.
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore Coldspot 69182990 - knocking noise
check te rubber mounts at the bottom of the compressor
the rubber rots after some time and the compressor moves on shutting down as the knocking could be that noise
May 20, 2017 | Kenmore Refrigerators
Our ge refrig runs constantly,freezer is freezing but the refrig is not cooling. I cleaned the dust and dirt out of the bottom and back of refrig.
See if the fan in side the frig is working It mite be on the freezer side If the fan is not working it will not blow the cold air in to the frig side
Jul 12, 2009 | Refrigerators
Refrigerators Logo
636 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
