Question about RIM BlackBerry Pearl 8100
Hp 6915 Hi I recently bought a second hand pda but when i try to use bluetooth i am being asked for the passkey code. Is there any way of overriding or changing the current one. Thanks, Brian.
Were do i find the passkey code so i can pair with a nokia???????
Posted on Apr 13, 2009
  • 46 Answers
What r u pairing? you need the code for what u r pairing or possibliy reqesting u to make a code up
Posted on Feb 11, 2008
I don't know my passkey for bluetooth on my iP-max2 or where I can find it
Passkey is the pairing code generated to authenticate a bluetooth device when it is connected for the first time.
If you have connected the device before and has not removed it, you can send and recieve files directly when your bluetooth device is in range. On the other hand, if you have removed the device or trying to pair it for the first time, it is necessary that you enter the passkey.
For that you need to follow these simple steps:
  • Have the device in range.
  • Open Bluetooth devices sheet on your laptop.
  • First, click on bluetooth settings and see that your computer is discoverable by other bluetooth devices. Enable it if necessary.
  • Close the dialogue box and click on 'Add Bluetooth Devices'.
  • It will show a list of all available devices.
  • Select the device you need to connect.
  • It will automatically generate the Passkey for that device.
  • Enter this passkey in the device and you are done.
I hope it will solve your problem.
Please don't hesitate to ask anything else related. I am following up.
Always at your service.
Regards.
Oct 24, 2010 | Acer Computers & Internet
Just bought the bluetooth and its asking for a passkey. idk if that passkey comes from my phone or the bluetooth, and how can i find out what that passkey is
go to the menu on your phone select manage connections set up bluetooth then you'll see search listen, etc. position on search don't press yet
get your ear piece ready: press the on button and hold it until you see a solid blue light (not blinking but solid) if it blinks try again until you get a solid blue light (it takes about 5-8 seconds) when that happens go to your phone and press search it will look for devices (it may find several) look for your earpiece model and select it
it will ask for a code or passkey, type 0000. Then it's going to ask if you want to bond or pair click yes and it will connect
check on the connection manager again and your bluetooth should be on and connected.
if it works for you, don't forget to rate me
thx
Jun 03, 2010 | Jabra BT160 Wireless Headset
I just bought a solidtek ask-3462 bluetooth mini keyboard. Followed all the instructions but cant seem to connect. Please advise I cannot get the Solidtek Bluetook Super Mini keyboard to connect with...
I just went through this 30 minutes ago.
When you are asked for the passkey, click on generate passkey or choose one for me.
a passkey will appear on the computer
enter this passkey on the keyboard then press enter.
they should connect and pair properly.
Apr 12, 2009 | Solidtek Bluetooth Super Mini Keyboard
My HP Ipaq 6915 goes off at 60% battery level or when i try to connect to wi fi, and switch off my bluetooth. At 85% battery power level i cant make or receive calls. It just loses network connectivity,...
The batteries from Ebay that are from China have lots of issues. I use an HP 6945 phone/pda and had the same issue with my original battery. I tried a cheap battery and it died within 2 months. I ordered an HP original battery and have been using it again full strength for 7 months. The new battery works bluetooth, wi-fi and gps as well as phone down to about 15% before I recharge. The HP batteries are more expensive but they are worth the extra price.
Buddy
Corporate Computer
Over 21 years of PC and printer service/support
Mar 10, 2009 | HP iPAQ hw6915 Smartphone
Printer will not connect with bluetooh
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
Jan 04, 2009 | Office Equipment & Supplies
Charging pin of my ipaq damaged
hi
I can fix your sync&charge connector very fast in our lab.
you can send your device to us and we will charge you by paypal and return it to you in less than one week.
thanks
Gery
ipaq Lab
Nov 27, 2008 | HP iPAQ hw6515 Pocket PC
Aspire 3000 laptop
Normally you setup a passkey or use 0000 or 9999 as a passkey.
The question is, does that pop up when you try to connect a USB device? Do you get that when you try to install the dongle? (That shouldn't happen). If you are trying to connect a PDA or cell phone, you setup the passkey for the connecting device on the computer then type it in to the PDA or mobile phone. If you are trying to connect a bluetooth headset, then you use whatever code is from the manufactorer. Normally this is 0000 or 9999.
Hope this helps!
Oct 18, 2008 | Adapters.com Bluetooth USB Adapater, USB...
Passkey code for bluetooth connection
most printers don't need one. what passkey is it asking for?
Feb 21, 2008 | HP DeskJet 450wbt InkJet Printer
T 305 passkey
Yes, I agree with joeypants77. Brilliant the passkey is 0000. I just bought a blackberry bold and it did not accept the Motorola T305 without a passkey and it workd:-)
Jan 26, 2008 | Motorola Mobility Bluetooth Hands-Free...
Connect to the internet via
Once the Socketcom Bluetooth card is inserted in the Toshiba Pocket e570 PC and the software has been loaded, the following instructions will set up the Toshiba PDA & Ericsson T39 mobile phone to connect to the Internet. Click on the Bluetooth icon in the bottom right hand corner. Click on Get Connected! Select the device under My Bluetooth phone is: In this case the Ericsson T39. The following information gives details on how to change the name of the Mobile device. Once this has been read, click on Next. The phone now has to be made discoverable so that the PDA will detect it. To do this, use the down arrow on the phone to select Extras and then click on Yes. Scroll down to Bluetooth and Click on Yes. Select Make Discoverable and a message on the phone will appear saying that the phone is discoverable for the next 3 minutes. Click on Next on the PDA. The PDA will now look for a Bluetooth device(s). Once the mobile is detected the PDA will search for the Device Name of the mobile. Click on Select and the devices will not connect and create a partnership. The following Device Bonding window should appear to create a bond between the PDA and phone. Click on Next. To create the bond a passkey must be entered on the PDA. This may be a between a 4-16 digit code. N.B. We would advise that the code be kept to a numeric sequence as the keys contain more than one letter on them, i.e. for the letter L, the number 5 key will need to be depressed 3 times. Once the passkey is entered, click on the Reply button. On the mobile, click on Yes to accept the incoming pass and then enter the same passkey. Click on Yes again to confirm. If the two values are correct, a message will appear on the phone telling you that the devices are bonded. The PDA should now congratulate you on your connection. For Internet access via Bluetooth, please follow the steps outlined below. The above instructions only need to be carried out each time a connection is required. However, the instructions below only need to be setup once. Click on Start, then Settings from the drop down menu. Click on the Connections tab at the bottom of the screen followed by the Connections icon utility. In the first drop box labelled "When needed automatically connect to The Internet using these settings" select New. Under the General tab you will be prompted to give the new connection a name, e.g. Bluetooth. Select the modem "Bluetooth Phone" and click on Next Make sure that the fields for the boxes titled Country code and Area code, are empty. The next field requires the full telephone number, including STD code, you wish to dial, i.e. your ISP telephone number. Put this in and click on Next. The next page contains a time out clause if the PDA is unable to connect within a set time. By default this should be 120 seconds. Make sure the tick box for "Wait befo
Sep 07, 2005 | Toshiba e570
RIM BlackBerry  Pearl  8100 Logo
60 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
