Question about Apple Studio Display 17" CRT Monitor
Rolling display image
Image keeps rolling as in old televisions that were corrected by adjusting the horizontal hold.
  • 84 Answers
You will need to take your monitor in for repair or buy a new one. I could get into the specifics about WHAT exactly causes this type of failure but bottom line is the same.
Posted on Feb 11, 2008
I have 2 lg repair the same trouble vertical horizontal rolling
Vertical or frame rolling indicates adjustment of the frame hold is required or perhaps there is a synchronisation fault.
Breaking of the picture in the horizontal plane is caused by the line hold requiring adjustment though the symptom can be connected with interior or exterior signal problems or perhaps a power supply fault, especially where both the line and frame are affected together.
It is probably a task for an engineer or at least someone with access to the servicing instructions.
Feb 25, 2015 | LG Televison & Video
Horizontal hold needs an ajustment
Horizontal rolling is your problem I thinks. In modern TVs there is no horizontal hold control like they wer in old one. All the adjustments are digital, that is related to a very accurate crystal oscillator frequency, and its cound downs. Therefore if your TV is not so old, its main Ic may be faulty, or horizontal synchronisation pulse does not reach the appropriate pin of that Ic. First check it, and if it is ok, replace the Ic.
Oct 18, 2010 | Durabrand DU1301 TV
Vertical rolling of picture
psess the volume  up and down button together on the front pannel of the tv and then shut off the tv and it will stop scrolling.
Jan 05, 2009 | Akai LCT3201TD 32 in. LCD Television
53 Hitachi Ultravison TV : Getting Horizontal lines rolling up
this is called viedo noise
you will need to replace capisitor Cc10 its Value is 1000uf @ 16v the cap is a filter On Sw +9v Line , on pin 20 of Ic01, ( or corma Jungle IC)
Dec 30, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Monitor problem
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Picture keeps rolling
do you have cable to the set or are you on rabbit ears if on ears adjust antenna for the strongest signal.
Mar 27, 2008 | Sony KV-32S16 32" TV
Vertical Hold Problem when connecting DVD Player
they have different resulutions they can synk
Nov 18, 2007 | JVC AV-32432 32" TV
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Apple Studio Display 17" CRT Monitor Logo
192 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
