you can upgrade up to 2GB (DDR2) Your computer has 1 memory slot you remove the memory and install a new one. you can use either 2GB 800MHz DDR2 Non-ECC CL6 SO DIMM or 2GB 667MHz DDR2 Non-ECC CL6 SO DIMM
HP Pavilion 9694C memory upgrade specification, Pavilion 9694C maximum memory, memory speed, and memory upgrade options.
Upgrade memory on HP Pavilion 9694C upto a maximum of 256 MB PC100/133
SDRAM DIMMs, with maximum 128MB per slot in 2 memory slots. The
HP Pavilion 9694C takes the PC100/133 SDRAM DIMMs Memory Type.
Pavilion ze4910us Memory SpecificationsStandard Memory
512 MB (removable)
Maximum Memory
1.0 GB
Memory Expansion
2 sockets
Memory Comments
PC2100/2700 DDR SDRAM SODIMMs
CPU Type
1.4GHz Intel Celeron M 330
Model Comments
400MHz FSB
Memory Upgrade for
HewlettPackard Pavilion ze4910us Laptop, the HewlettPackard Pavilion
ze4910us Laptop takes the PC2100/2700 DDR SDRAM SODIMMs Memory Type, and
comes installed with 512 MB (removable) of
Memory. You can upgrade your HewlettPackard Pavilion
ze4910us Laptop to up to a maximum of
1.0 GB Memory, the system has 2 sockets to install
Memory, already with 512 MB (removable) standard Memory
installed. For best Laptop performance use the maximum amount of allowed
Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop.
I assume you are upgrading the RAM (Random Access Memory), the Ram is also called a memory stick because it looks like a stick, the stored data is kept on the Hard Drive, if that is upgraded then yes you will loose the memory, but not if you upgrade the Ram
According to the specs of this motherboard, it only supports 333, 266 and 200 MHz DDR SDRAM. It does not support 400 MHz DDR SDRAM. This motherboard has only 2 memory slots, each can accommodate a 1 GB memory module. Higher capacity memory modules are not supported by this motherboard. No BIOS upgrade is available to provide support for 400 MHz DDR SDRAM memory modules.
Computer Memory Information
Upgrade Questions Troubleshooting Memory Diagram Upgrade Help Buying Tips · Memory definitions. MEMORY ABCs. Memory, which is commonly referred to as RAM
Installing PC computer memory
Additional information and help with isntalling PC computer memory. ... Installing a PC computer memory. Question:. Installing PC computer memory.
Determining type of hardware within computer
Reference, Issue / Question. Memory, Information and help with computer memory. CH000149, How to determine system resources / RAM available?
Buying tips on computer memory.
How much memory should I get? This question really depends on the type of computer user you're and what type of programs you plan on running on the computer
