Question about Sony KV-32S22 32" TV
Repair TV Sony KV32S22
I have Sony TV Model KV32S22. The problem that I have TV can not see te image, only I hear the sound. My friend change the reisistence of the image, bad the problem continue. he wants the electronic map of the TV and then find the problem. Can you Help me?
my email is: mjcuevas08@yahoo.com
Thank you,
Maurice Cuevas
  • 2,336 Answers
The schematic diagram can be found here: http://www.eserviceinfo.com/equipment_mfg/Sony_2.html
Need to find winrar for the program to unzip the files.
Good Luck.
Posted on Feb 11, 2008
We have sound but no picture
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
Dec 14, 2015 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
How do I fix a Samsung tv model htp5054x/xaa? I have power and I can hear audio but no image.
First trouble shooting steps is to try a different source, or at least a different cable. A bad HDMI cable can allow sound but not image. Also look closely at the screen. If you can see a dark image, it would indicate that the lighting system has failed. Check this video for some tips. Samsung Plasma TV Repair How to Repair and Replace Main Board
Sep 07, 2015 | Samsung Televison & Video
The system plays fine when playing advd but how do i get tv sound through the system
Hello
This is only some rough guidlines you can follow, as i have not worked with this spesific player before.
You need to connect a RCA cable from the tv(Sound) output. Connect the other end of the RCA cable to the AUX input on your Sony system. Now, all you need to do is to change the input setting on the sony system to AUX, you will be able to hear the TV trough the system.
the RCA cables look like this:
The coulor is of no matter, it is only coloured to ease the use. The RCA connector points on your TV will have the same colour. Remember to plug in the RCA cables into te sound output on the TV and into the AUX input on the Sony player.
Really hope this can be of help.
Kind regards
Andrea
Feb 21, 2010 | Sony DAV-SB500W System
My Sony TV kv32s22 has a problem. It has audio but no video. There isn´t oscilation of the flyback at firts it turning on but now the red led is flashing all time. I look the pin for 9 volts has 8.2V...
Just moved my mitsubishi big screen from one location to another. The tv wont communicate to the remote and the tv will not resond manually. Pls help
Jan 08, 2010 | Sony KV-32S22 32" TV
I need number of flyback from model sony kv32s22
go to www.seme.co.uk or phone on 01664 484000 give them the make and model number and they will know the part number and be able to supply you
Jul 02, 2009 | Televison & Video
"ghosts on sony projection tv
Hi friend
its colour wheel problem you should change it,,,first check if any burnt parts resistors,,,,,common problem is colourwheel,
check it...........thank u,,,,,,
May 03, 2009 | Televison & Video
Sony KV32s22
Hi: Sounds like it might be an overheating part, and the short is shutting of the set. Or it could be an intermittent connection in the pc board. Either case it would have to be repaired by a expert.
sorry.
Mar 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY KV19TR20
I found this at another site. I don't know what the "infamous" problem is, but you might consider it:
Sony TV with bad butchered soldering: (From: Repair Brief #81: Sony KV-19TR20 Color TV - No Reception).
The final example is of a Sony TV that had the infamous tuner/IF box solder problems. This is normally a fairly easy repair, especially for this particular model where the IF box (which was faulty in this case) is readily accessible without taking the whole thing to bits. Once repaired, like the RCA/GE/Proscan TVs with similar solder problems, the result is a solid reliable TV. However, the friend of a friend who had attempted to replace it, apparently used a Weller soldering gun to do the fine soldering, leaving nearly every pad detached or missing. Fortunately, only the pads appeared to have suffered and after 20 minutes and several jumper wires, this one was healthy again.
Found at: http://www.repairfaq.org/sam/tshoot.htm
Nov 19, 2007 | Sony KV-32FV27 32" TV
No picture, sound works on Sony TV
Hello, maybe there is a contact error in power supply or the deflection stage. If the resoldering does not help- here are some possible solutions: remedy Replace flyback location LP04. Entered for KV32S22 /SONY (Chassis) remedy 2 Replace IC351, Q602, Q601 (2SC4834M), R607 (1R/0.5W), R622 (10R), IC641 (SI3090CA) and Q502 (2SC5148). remedy 3 Replace tuner. remedy 4 Replace R607, Q502 and IC601. Entered for KV32S22 /SONY (Chassis) remedy 5 Replace regulator IC, R607, check C609, C610 (0.68pF) and C613 (0.0022pF/500V). remedy 6 Replace horizontal output transistor (2SC5148), IC601 (MX0841) and R607 (0.1R). remedy 7 Replace IC1701 and IC601. remedy 8 Replace Q501 (2SC5148), R607 and resolder horizontal driver transformer. remedy 9 Check and replace horizontal output transistor Q502 (2SC5148) and IC601 (MXD8411AB-F). remedy 10 Replace shorted R607. Also check T501 and Q501 for dry joints. remedy 11 Replace C608. remedy 12 Replace Q602 and D648. remedy 13 Replace Q502, Q601, Q602 and R602. Entered for KV32S22 /SONY (Chassis) remedy 14 Replace D626 (6.2V). remedy 15 Replace IC801 and R607. remedy 16 Replace horizontal output transistor and the associated damping capacitor. Check flyback transformer and SMD microprocessor as well. remedy 17 Replace R639 (4.7R/0.250W) located on G board in standby power circuit. remedy 18 Replace D600. remedy 19 Replace C502 (0.47uF/50V). remedy 20 Check D655(1N4937), D657 (1S1834) and Q601 (2SC4423). remedy 21 Check D606 for leakage. remedy 22 Check yoke between vertical and horizontal windings for S/C. remedy 23 Replace Q601 (2SC4834MNP), R607 (0.1R) and C517 (2.2uF/250V). remedy 24 Replace R611.
Apr 22, 2007 | Sony KV-27V22 TV
Televison & Video Logo
239 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
