Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
SanDisk not recognized by computer
I used to be able to use my SanDisk flashstick at work to read files that I brought from home (just .doc, .xls, and .pdf). Now, the computer is not recognizing anything that I plug into the USB ports, whether an iPod charger or the flashstick.
The flashstick is a SanDisk micro (SDCZ6-4096RB). I tried to install a driver though I have Windows XP so the driver isn't needed.
Is there something wrong with the USB ports and is there something that I can do to re-adjust them?
  • krissyn Feb 11, 2008
    I wasn't able to access the Device Manager since I don't have administrative rights to the computer, but I've contacted my Help Desk at the office to see if they can do it for me. I have no doubt that the advice you gave is the solution, but unfortunately, I can't access it at this time.
    Thanks so much!!
    Scholar:
  • 58 Answers
Follow these steps:
  1. Go to START > Right-click My Computer > PROPERTIES
  2. On the tabs, click Hardware > DEVICE MANAGER
  3. Press the + sign next to the Universal Serial Bus controllers.
  4. Doubble-click the first one
  5. When the new window comes up, click Drvers from the tabs, and click "uninstall"
  6. Repeat step 5 for all devices
  7. Restart your computer.
After your computer restarts, plug in your flash drive and it should work.
If that doesn't work, then the USB ports on your computer are dead. You can try to get new USB hardware at a computer store to plug into your computer (THIS IS NOT THE SAME AS A USB HUB!)
Posted on Feb 11, 2008
  • Stephen Ratajczak Jr. Aug 20, 2011
    Clean the flash drive in some boiling hot water, and hot blow dry it good.
    -Biffbee
What file format do i save a word doc to my sandisk 2 gb
The USB flash drive is capable of storing any type of file. Save it as a word document (.doc) or anything else. However, if you use the drive on a computer that does not have WORD on it, you may not be able to open it. There are other programs that can read WORD documents: Libre Office, Corel WordPerfect and many other documents viewers.
Aug 27, 2011 | SanDisk 2GB microSD Memory Card
Used for years. Deleted mp3 files. Tried to reload new mp3 files by select all and drag and drop to audible folder. Message said it was full and would only load partial. Deleted partial load safely...
Sorry mate it has been corrupted and and may not work any more it seems the set up and read file that is like a operating system has been moved or deleted. The same things happens with usb drives.or has been disconnected without using the disconnect usb device icon.
Jan 31, 2011 | SanDisk Sansa m240 MP3 Player
How to copy a doc. file to the flash drive.
Ok. here is what you need to do.
1. Hook your flash drive to any of the usb slot in your computer.
Wait for the system to read it. A green arrow icon will appear in the taskbar to show that a new removable hardware device is connected. After it successfully recognized, It will display a message " The device is installed and ready to use" at the lower right portion of the windows taskbar.
Click on My Computer a new drive will appear. It is usually designated as removable drive. On this drive you will paste the copied doc files. It is the assigned drive for your flash drive.
So go on., copy all the files you need to carry and paste it in the flash drive.
Be reminded also that before you unhook the flash drive from the computer, right click first on the green arrow icon on the taskbar and stop the operation. Click stop on the flash drive. This will turn off the remaining applications / readings in the flash drive and will prevent it from crashing and file corrupting.
I hope you understand.
Please give me some good ratings as this will help me too.
Thanks.
Aug 14, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My device is not been detected by computer
You have brought in some virus into the device. try to scan and open the device and delete off any bad files that have corrupted your memory.If the device is deteccted and the files are not showing you must use search for files and open the entire files in the device.
I hope this will help. Good day
Jul 04, 2010 | SanDisk Sansa m240 MP3 Player
I cannot move a Microsoft Word file to a SanDisk 2 GB Cruzer,getting the message that "Directory or File cannot be created"...Why? What's the solution?
There is a problem with these where putting files directly on the root folder of the drive only allows X amount of files. Open the Cruzer from My Computer and create a new folder. Try dropping the Word file into that new folder and all should be well.
Hope this helps. Look forward to hearing back from you soon!
Feb 26, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Works on my mac-not recognised by other computers
the problem lies in the file system
Some choices:
Format for Mac and use PC software that can open Mac format disks like TransMac http://www.asy.com .
Format disk as FAT32, both machines should be able to use it. A problem with FAT32 is that the largest file it can hold is 4GB.
Format with NTFS and use Paragons NTFS for Mac OS X http://www.paragon-software.com/home/ntf... .
hard drives are hard drives.
You are only going to run into problems if you format it and use a file system type not supported by one of the systems.
Apr 23, 2009 | Computers & Internet
SANDISK cruzer micro 4 gb
Its not problem with your USB drive. Try formatting your, usb drive and then also clean your system from viruses using any updates anti virus software. Then this problem shuld go alright.
Sep 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzier 4.0 pendrive is not recognized by my computer
the home computer has a small chip onits mother board called disk controller. its this controller which recognises it.so the software driver is corrupt and needs reinstallation or the hard ware controller is faulty.
Jun 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Won't recognize music files
My Sansa only reads mp3 or WMA files, not mp4 files.
also, i have tried three different computers, and all of them recognize (or NOT) my player differently....
~Rebecca~
Jan 13, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Opening files on SanDisk micro 4GB
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. Let me know what happens.
cynthia
Dec 11, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
3,632 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
