Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Unit will not put out cleaner detergent correctly
Model F7426-900---not F7425-900 (made 11/03)
Sometimes it will dispense detergent-sometimes it won't.
Dispenses clear water ok.
Think I have solenoid problem.
Where are solenoids located and how do you get to them.
Any suggestions as to any other areas that could be causing the problem?????
Service manual available online????
    President:
  • 1,673 Answers
There are no solenoids, but the valve and seal at the bottom of the tank may be bad part #43513026.
Posted on Feb 12, 2008
Why won't my Hoover SteamVac 7000 LS spray?
Hi there! Be sure you are only using the recommended detergent for your cleaner. Sometimes it is necessary to prime the trigger to get the solution to flow. Give these quick steps a try.
1. Recline the handle
2. Pump the trigger 30 times
3. Power the unit on.
4. Squeeze trigger for 60 seconds
If the cleaner still wont dispense you may have an issue with your pump assembly. We recommend taking your unit in to an authorized service center for repair. I have included a link where you may go to locate a service center near you. Service Center Locator
Thanks!
Aug 03, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover floormate fh40160 won't dispense solution
Hi there! Sometimes it is necessary to prime the trigger to get the solution flowing. Try these quick steps.
1. Recline the handle.
2. Pump the trigger vigorously about 60 times.
3. Power the cleaner on and squeeze the trigger for 60 seconds.
The cleaner should start to dispense the solution. Be sure you are using only the recommended cleaning solution to avoid internal damage. If your Floormate is still not dispensing there could be an issue with your pump. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Hope this helps!
Jul 07, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
No water getting to brushs
Hi! Sometimes it is necessary to prime the trigger under the handle to get the solution flowing. To prime the trigger, recline the handle and pump trigger about 60 times. Then, power the cleaner on and squeeze the trigger for about 60 seconds. The solution should start to dispense. If it is still not dispensing there may be an issue with the pump assembly on the cleaner. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate one nearest you. Service Center Locator
Hope this helps!
Jun 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
It turns on, it makes the noises, the brushes are spinning, but the water/cleaner isn't getting to the floor
Hello! Sometimes it is necessary to prime the trigger to get the solution flowing. To prime the trigger, recline the handle and pump the trigger vigorously 60 times. Then, power the unit on and squeeze the trigger for about 60 seconds. The solution should begin to flow. It may be necessary to repeat these steps a few times. To avoid internal damage be sure you are only using the cleaning solution recommended for this unit. If the unit is still not dispensing we recommend taking the cleaner in to a vacuum repair center for repair. Follow the link to locate the nearest authorized service center to you. Service Center Locator
Jun 02, 2014 | Hoover Steamvac F5860-900 Vacuum
My Bissell ProHeat 2X CleanShot Upright Deep Cleaner, 9500; flow gauge will not spin and the machine is not dispensing solution with both the solution and water tank full. I have cleaned all inlets where...
No what it means are the tubes that carry the solutions are plugged and most likely full of old detergent that hardened. You will need to clean all the plastic tubing out for the dispensers. When your done using the machine always run clean water only through the dispenser and tube to flush out the detergents.
Jun 10, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Tom
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Suddenly the automatic deterent mixing system in my hoover steamvac widepath (model F7443-940) stopped from working. It does not dispense detergent anymore. What could the problem be?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766252
Generic problem for all Vacuums
Suddenly the automatic detergent mixing
Posted by btaha on Jul 10, 2008
Suddenly the automatic detergent mixing system in my Hoover SteamVac WidePath (model F7443-940) stopped from working. It does not dispense detergent anymore.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It could be the trigger assm could be broken and is not releasing the solution and or water, or the valve under the water solution tank is not releasing the solution. Please check with your owners manual in the trouble shooting manual or if you do not have a manual, call the Hoover factory cust serv and give them the brand name and model # so that they can send you a new owner’s manual. Your local vacuum cleaner dealer should be able to do a diagnosis of the problem and can give you and est of the repair. Or if the vacuum is less than one year it should be covered under the Hoover factory warranty. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Hoover 3010 FloorMate Plus not dispensing liquid
With the tank off, can you see if the rod in the handle is hitting the spot where the tank sits on, if not then there is a problem in the handle. If it is, then the reservior asm may be bad, it is what the tank sits on.
Jun 14, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Smart mix plunger bissell 1699
Check your wiring. I have a photo of the correct wiring if you'd like it for reference,
Oct 02, 2007 | Bissell 1699 ProHeat Clear View Upright...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
183 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
