Question about HP DesignJet 1050c InkJet Printer
Check Printhead cleaner Path
I have an error message coming up says "switch power off, check printhead cleaner path", I have already changed the all 4 cleaner and printer heads, yet the message still appears, and none of the guides help. Can you help?
  • luc_ky_co Apr 22, 2009
    switch powor off check printhead (1)
  • 26 Answers
Sounds
    1. Attempt to duplicate the message by turning the printer on, reloading the media, and printing several test prints.
    2. Note the movement and position of the carriage when the error occurs.
    3. If the carriage stops on the left-hand side (roughly 12 inches from the ink supply station), unplug the power cable from the printer, open the top cover and try to move the carriage to the right. Closely inspect the ink tubes for wear, and check for ink tube binding or catching on the tube guide (stopping/hindering carriage movement). If true, continue with the remaining steps below.
        NOTE: If the steps above do not describe the issue correctly, refer to the work instruction for a typical “Switch Power Off, Check Printhead Path” message (bpp90070).
Check/replace the Ink Tube SystemCheck Printhead cleaner Path - gtabtop.gif
    1. Turn the printer off.
    2. Remove the old Ink Tube System (refer to pages 8-53 of the Service Manual).
        NOTE: If the printer is installed on a Multi-roll feeder accessory, some additional disassembly is required to gain access to the printer. Instructions for multi-roll disassembly are listed at the bottom of this document for reference.
    3. Move the carriage assembly to the right side of the printer.
    4. Clean the rear tube guide assembly with a moistened lint free cloth to prepare the mounting of the Mylar tape.
      Figure 1:Cleaning the rear tube guide assembly
    5. Remove the backing on the Mylar tape and align the line on the tape with the front edge of the rear-tube guide so that the narrower section is towards the front of the printer. Do not attach the tape yet.
      Figure 2:Aligning line on Mylar tape with front edge of rear-tube guide assembly
        NOTE: Ensure that the Mylar film is perfectly aligned with the rear Tube Guide surface with no protrusions or unevenness.
    6. Carefully position the Mylar tape about 1/4 of an inch from the left-end of the rear-tube guide (do not go all the way to the end as the beveled edge will cause crimping of the tape).
      Figure 3:AttachCheck Printhead cleaner Path - c00001197.jpg tape
    7. Ensure tape is evenly positioned and any air bubbles are smoothed out along the tape.
      Figure 4:Smoothing out the air bubblesCheck Printhead cleaner Path - c00001198.jpglar tape (view from rear of printer)
    8. Carefully fold under the narrow section of the tape to the underside of the rear tube guide assembly and smooth out any air bubbles.
      Figure 5:ICheck Printhead cleaner Path - c00001199.jpgar tape under rear-tube guide assembly (view from front of printer)
    9. The Mylar tape should lookCheck Printhead cleaner Path - c00001200.jpgge below.
      Figure 6:Final installation of Mylar tape (view from top of printer)
    10. Once the Mylar tape is installed, install the new Ink Tube System (refer to pages 8-53 of the Service Manual).
    11. Following replacement, verify printer functionality.
like a bad belt.
Posted on Mar 26, 2008
  • HP Expert
  • 141 Answers
Also may be a broken primer arm on the service station or torn paper under the printhead cleaner shelf. good luck!
Posted on Sep 14, 2008
  • Michael Schaffter
    Michael Schaffter Apr 23, 2014
    Is there a way to test the primer arm outside of the plotter? There are 4 wires that go to it. What is the purpose of the primer arm anyway?
It's telling me to complete print head alignment, I thought I already did!
Try switching both your printer and computer off for few minutes and see if the error comes up again. If that doesn't work, try unplugging the printer from power point for couple of hours.
good luck!
May 08, 2015 | Canon PIXMA MP150 All-In-One InkJet...
My problem is after claibration i receive a message POWER OFF AND CHECK PRINTHEAD CLEANER PATH
Something is blocking the printhead cleaner assembly from moving forward and backward.
Turn the plotter off, open the printhead cleaner access cover (RH side) and see if you can move the cleaners to the front of the machine.
If you can move them fairly easily, then try (with the plotter still off) to move the carriage assembly (holds the printheads) to the left of the machine.
Check the condition of the carriage belt for frayed areas or missing belt teeth.
(I suspect a worn out carriage belt is causing the problem)
With the cleaner assembly to the front, and the carriage to the left, turn the plotter back on and see if the error continues.
May 03, 2011 | HP DesignJet 5500PS InkJet Printer
Error message on brother dcp 540cn 'unable to change 30' have swithched it off and checked all cables. No joy It sometimes changes to unable to change 50 help appreciated!
This is almost always associated with debris or foreign objects in the printhead path or under where the printhead "parks."
With the power off, open the cover. Inspect the printhead path for little bits of paper, push pins, paperclips etc. Note the position of the printhead.
If the printhead is at the far left, gently slide it towards the center. Carefully look under where the head was positioned for debris. Use a flashlight if necessary.
Close cover. Plug in the machine. Try it again.
Jan 05, 2010 | Office Equipment & Supplies
Error message reads "switch power off check printhead path type 2", any suggestions. I have cleaned along the track but problem persists on power up. Head alignment begins and after a short while the error...
there is an issue with your carriage assembly. it cannot move freely across the carriage rail assembly. the belt may be worn, lubricate the rail assembly or both.
Nov 16, 2009 | HP DesignJet 1050c InkJet Printer
Check printhead path error message
hi
the problem is nothing else but sofware..
you just reinstall the printer software.
Thank you
Sep 10, 2009 | HP DesignJet 1050c plus InkJet Printer
How do you clear printhead path Type (1)
Open Rh Cover , Remove All the Ph Cleaners
Pull The Tray in Which We Seat the Ph CLeaner , Clean the thin Steel Shaft With a Lint Free cloth ,Insert Ph Cleaners
Check it now if still no go
then Replace service Station
Jul 07, 2009 | HP DesignJet 1050c plus InkJet Printer
Problem with Printhead Path
Something (not sure what) is obstructing the movement of the carriage assembly. Turn off the power and remove the cleaners. Push the carriage assembly out and pull/push the belt to move the carriage assembly until you find the bind. If you've recently changed the belt or carriage assembly, make sure you properly adjusted the carriage height.
Jun 05, 2009 | HP DesignJet 1050c plus InkJet Printer
The HP Designjet 1055cm has 4 ink cartridges, 4 printheads and 4 printhead cleaners. My question is: Will the plotter still work properly if I just install the black ink cartridge along with the printhead...
I doubt it. When the printer powers up, it checks to make sure that all modules are in place and functional. If one is missing, you'll get an error message.
Dec 10, 2008 | HP DesignJet 1055cm InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
2,562 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
