Question about Frigidaire Refrigerators
Frigidaire ice maker On/Off switch doens't stay On
Frigidaire side-by-side Model FRS6B6EEB3, Ice Maker Model: GSI-26
Ice Maker On/Off switch behind the ice bucket won't stay in the On position. When pushed On, it pops back to the Off position
(rocker switch). The ice bucket is not hitting the button and the freezer is cold enough. Water comes out of the dispenser.
What could be causing the switch to not engage in the On position?
Thanks!
  • whatshername Jun 09, 2008
    Same Thing!! And I can't find a replacement icemaker anywhere - any ideas! thanks in advance
4 Suggested Answers
arikrom
  • 528 Answers
SOURCE: My Kenmore sidebyside fridge, model
first take the unit out clean it and check that it is not stuck or something damage there. it can be the controll / the ice container something got damage most likely the container bad.
Posted on Dec 30, 2009
  • 130 Answers
SOURCE: my ice maker stopped making ice
The simple and most expensive solution is to replace the ice maker assembly. They sell for between 50 bux on e-bay to 150 bucks at Sears. From what I have seen most ice makers fit the same category and they look like they are all designed and built by the same company!!
The main problem is the gear on the backside of the unit snaps off for various reasons like ice cubes getting stuck and causing the ejector rake to jam, thus overloading the flimsy gear and snapping it off. You can not purchase the gear however you can choose to buy a gear-head assembly for 80 or so bux.
http://www.appliancepartspros.com/part_details.aspx?part_id=3177342&pn_=8201515
shows a typical repair kit. Just enter your model number on their website to find the exact match for your ice maker.
I repaired the broken gear on mine using some structural epoxy. Here is a pic of the repair in progress, The green stuff in the center of the gear is the epoxy I used. Good Luck!!
Posted on Jan 31, 2011
woodchuck789
  • 4070 Answers
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
Frigidaire plhs3teesbe model won't make ice
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
Currently the water is leaking from the ice maker. there is ice build up in the control box its self, and its leaking from there. No sure how the water is getting in tot he control box itself so i'm...
You are right - it is filling up with too much water. If you remove the front panel of ice maker you will find a screw there that adjusts the length of time that the solenoid stays open to admit water. Turn it counter clockwise to reduce the time and amount of water entering the ice maker.
If you need new maker get them cheap on ebay. eBayeBay
Sep 08, 2017 | Frigidaire FRS23H7CS Side by Side...
My ice maker stopped making ice frigidaire model plhs269zdb1 ice maker model number is GSI-26
Dec 29, 2009 | Frigidaire PLHS269ZD Stainless Steel Side...
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Aug 17, 2009 | Refrigerators
Ice maker stuck on crush, continues to crush ice when cube button is pushed.
Remove ice bucket,check solonoid on back wall behind bucket may be stuck in up position pull down and recheck dispencer.
Jul 14, 2009 | Frigidaire GLHS66EE Side by Side...
Frigidaire side by side model:FRS26HF6BW2
Check the trap door where the ice drops through, it might be stuck in the open position, solenoid that operates the door may be bad.
Jan 27, 2009 | Frigidaire FRS26R4A Side by Side...
Crushed ice only
Behind the ice bucket is a metal housing that holds the auger motor and solenoid.  The solenoid is bad.  When you go for cubed ice that solenoid should pull up the metal rod on the ice bucket so full cubes will come out.  First check to make sure the metal rod on the ice bucket isn't somehow caught under the solenoid and not letting if move up and down.  You can take out the ice bucket and press for cubed ice.  You should hear a loud clunk noise.  If not then you know the solenoid is not working.
Oct 11, 2007 | Frigidaire FRS3R5EMB Side by Side...
FRIGIDAIRE M.N. FRS26R4CWR AND S.N. LA52921475 ICE MAKER GSI-26
Is this the original ice maker? If it is you should be able to pull off front cap on icemaker head and see a adjustment screw with a - and + signs adjust towards - tell required level is reached.. most new model icemaker have NO adjustments.. has a circuit board for a brain..lol and takes care of the adjustments
Aug 20, 2007 | Frigidaire FRS23H7CS Side by Side...
Refrigerators Logo
1,469 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
