Question about HP LaserJet 1200 Printer
Hp1200 error codes
Hi,I need the solution for this error code on a hp1200 laser printer. all lights on then secondary error top light and go light on. can you help me?
  • Udo Gehring
    Udo Gehring Feb 12, 2008
    I fixed it already. Scanner was faulty. Just could not remember the error codes for the 1200. Thanx anyway.
  • 28 Answers
When all light is on printer has a fatal error ( Problem with scanner section or Fuser section)
Secondary error pls tell me is it blinking
Posted on Feb 12, 2008
Formatter internal RAM or ROM error.
Posted on May 01, 2008
Error light on number of documents will not go out
Posted on Sep 12, 2011
When putting it on all lights are flashing one way ,at the same time as a results the printer doesnot want to print because one light should be on to show that it can print.
All service errors are indicated by all lights flashing as the primary notification or code. Please press the continue button to display the secondary error message or code. The secondary code indicates an area or function which has the error.
For further assistance, please contact Lexmark Technical Support.
Jan 30, 2012 | Lexmark E232 Laser Printer
All front panel are blinking- lexmark E232 printer
When all the lights on the printer's operator panel blink at the same time, the printer is displaying a primary service error. This indicates that something has failed in the printer. In order to determine what has failed in the printer, you will need to obtain the secondary error code. Please the continue button twice to see the secondary code. Once you have the secondary error code, please call Lexmark Technical support for further assistance.
Aug 18, 2011 | Lexmark E232 Laser Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
All lights are flashing
If all lights are flashing,it indicates an error on the printer. Please press the continue button to seethe secondary error code. The secondary code will indicate the another lightsequence indicating specific problem on the printer.
Jun 01, 2011 | Lexmark E232 Laser Printer
All the alarm lights on printere is flickering.The printer is not printing, no paper jam
If you see that all lights on the printer are flashing, that indicates an error on the printer. Please press the continue button to see the secondary error code. The secondary code will indicate the another light sequence indicating specific problem on the printer.
Apr 30, 2011 | Lexmark E232 Laser Printer
Hi, My Lexmark E232 printer is on but will not print. The light second from the bottom is orange. Help!!
That second from the bottom orange light indicates a paper jam. Press Continue to resume printing once all the jammed pages are cleared from the paper path. Press Continue twice quickly to see the secondary error code. See "Secondary error codes" on page 69 of the user manual for more information.
Here's a link to the manual: http://www.lexmark.com/publications/pdfs/e230/eng/ug.pdf
Mar 21, 2011 | Lexmark E232 Laser Printer
Why are all the lights flashing on my e232
Feb 11, 2011 | Lexmark E232 Laser Printer
All front panel lights blink
This light sequence means that the printer has a service error, and printing has stopped.
Please Press Continue button (green button) twice to see the secondary code. The secondary error code will help locate the problem. Please take note which light will be flashing for this will reveal what problems you have on the printer.
Feb 01, 2011 | Lexmark E250dn Laser Printer
All of the lights are blinking in unisom and the printer ill not print
If all lights are flashing, it indicates an error on the printer. Please press the continue button to see the secondary error code. The secondary code will indicate the another light sequence indicating specific problem on the printer.
Jan 12, 2011 | Lexmark E232 Laser Printer
HP LaserJet 1200 Printer Logo
2,358 people viewed this question
Ben Johnson
