Question about Panasonic SC-HT520 System
My dvd player cant be played
My unit displays apprear "DVD H02" , what should i do now??
any help much appreacited
  • 56 Answers
It is the region mater of your dvd player. The region of Your dvd is not matched with your Player. You need to change the settings of dvd to region "0"(Zero) means region free.
Posted on Feb 11, 2008
Problem playing dvd with panasonic sa-pt660 keep getting an H02 error message?
Thousands of annoyed customers of Panasonic, Yamaha, and Denon DVD Player owners have encountered the infamous H02 / H07 /H03 erors and many others on thier players or maybe the "No disk" error even though a disk is in the drive. Well many people have spent hundreds on repair or bought a new unit. But i am here to tell you that it is okay to open up your dvd player and mess around in side. If your DVD player comes up with one of these errors the first thing you might want to try is to open up your DVD player by removing the screws on the side and the back (depending on the model), then plug the dvd player into power outlet with cover removed. Stick a disk in and press play and give the disk a little push. Most of the time the Spindle motor is dieing out when you get a H02 error. In this case that little push may get your spindle motor to rev back up back into action. And if your as succesful as me then hopefully you have just fixed your H02 error for free without doing much work. I just got a Panasonic HT95 Reciever/DVD player to play all disks again by giving the motor a little "kick start"
Jan 05, 2011 | Panasonic Televison & Video
Dvd will not play. H02 appears. Have reset to no
H02 is a fault code, though I don't know what. It code be either an electrical fault or mechanical problem. A mechanical fault might be easy to spot so take off the top cover and see if anything is broken, otherwise I suggest a service manual will come in handy.
May 21, 2010 | Denon DVD-800 DVD Player
Error H02 for panasonic dvd s35
My Panasonic DVD Player Model S55 does not read the DVD disk. I get a H02 then no disk reading on the display.
Jan 17, 2010 | Panasonic DVD-S35 DVD Player
Technics dv290 system
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Sep 06, 2009 | Technics SC-DV290 System
PANASONIC SA-HT800V
Ouch - This generally one of two things.
1 - Run up speed is not sufficient due to motor wear.
2 - The laser head sits within a 'plastic' runner, which wear down slowly, causing the laser to be misaligned - therefore not reading adequately.
Depending how adventurous you are feeling - you could dismantle the unit - and 'space off' the laser unit (Single piece of paper) this will lift up the laser.
Or you may be able to adjust the calibration power of the laser using a variable pot (unlikely to be available as these are generally hard coded nowadays - and not physical pots)
Aug 15, 2008 | Panasonic DVD-LA95 Portable DVD Player
Discs cant be played..
More information:
Your DVD HO2 error problem appears to be Panasonic specific: Go to this link:
http://www.hardwareanalysis.com/content/topic/55214/
Feb 11, 2008 | Panasonic SC-HT880 System
Disc cant be played
You need to cannge the region code of your player make it region free by useing region code "0"(Zero). change it from settings/ similer option.
Error message when playing any DVD in Hi-fi
Feb 28, 2007 | Technics SCHD560 CD Shelf System
Panasonic SC-HT520 System Logo
133 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
