Question about Samsung Digimax A40 Digital Camera
Usb error can not open the folder containing photos , says H: access denied
  • 56 Answers
I think you need to install a driver/ The H: drive are not detected by this device. Better you change the drive location.
Posted on Feb 11, 2008
How do I download pictures from my gallery to my desktop pc
I assume you are working with an Android based Smartphone or Tablet.
Connect the device with your Micro USB (charging) cable to the USB port on your desktop.
Once connected on your device there will likely be a pop up asking use USB for. select MTP (media transfer protocol). This will allow you to access your phones Internal memory and SD card through your file explorer on your desktop.
Your phone should appear in the list of storage devices under This PC on the left had side in file explorer. Click on your phone it will open with possibly two folders. Labeled Phone and SD card, depending on where your photos are stored open these folders and look for the folder labeled DCIM. This folder will contain all your photos and videos taken with your camera.
The other folders you may want to check are Downloads, Pictures and Videos. These will contain any images or videos downloaded from the internet or e-mail attachments saved.
Find the files you want from these folders and drag them to a new folder on your computer.
Jan 23, 2017 | Computers & Internet
Tip
Removing 'Access denied' error from folders and files using Unlocker Assistant
Copying files from one destination to another is a practice that goes on a lot among PC users. Sometimes huge sums of data are moved from one hard disk to another. Now there is this error that happens a lot where, when the mouse icon is placed on a folder, you see 'folder is empty' even though you know that the folder you copied is not empty. When you try to open it, you are told that access denied. Most of the files too may not be accessible and will also give access denied error. This is a frustration that can make one think that his/her files are lost. Well, there are ways out and even though it might take time, it's worth it. The following, is a solution to this problem using the software, Unlocker Assistant;
1. First, you would have to obtain the software on the internet. It's free and you can easily search and download it in a few seconds.
2. Install it by following the instructions and you are ready to go. Now, if you are using Super Copier, Unlocker Assistant may fail to start so if you do, then uninstall the Super Copier for the time you would use the Unlocker Assistant. You can install it back when done.
3. Now create a folder on another drive with enough space, different from the one with file and folder errors.
4. Now right-click a folder (one with access denied and empty folder error) and select 'Unlocker'. Among the list of actions, you select move and select the folder you created as destination. If the moving goes through, a success message will show and state that object was moved which means everything in that folder is fully unlocked and is accessible.
5. If the moving does not go through, it will ask you if you would like to move the object the next time you restart. If so, select no. Now refresh and check the folder again and you will see that this time, it is not empty and it is accessible. Now open the folder and repeat the same thing with all other sub-folders. Now this might take time depending on the number of folders you have so you might want to ignore folders that you do not need.
6. Now after you have unlocked the folders, you come to the files in the folders. Select all the files in the folder and right-click and select move. Create the same folder name at the destination for easy recognition. All the files will moved. If the file sizes are very big, you might want to take a little at a time but if they are all small, then you may select all.
7. Now every file that is moved by Unlocker is now accessible. Pictures, movies and all other file types can now be accessed. After everything, you may then move the files back to the disk that had the file and folder errors.
That is all. You are done. Hope this was helpful.
on Mar 04, 2010 | Computers & Internet
Access Denied Error on external hardrive
You don't have rights to the folder. Right click the folder --> Select Properties --> Security --> Advanced --> Owner and then change the owner to your user. Here are some instructions from Microsoft for taking ownership. Once you own the folder then you can do whatever you want.
http://technet.microsoft.com/en-us/library/cc753659.aspx
Oct 21, 2012 | Transcend StoreJet Computers & Internet
I just bought a 650 gb transend. i was not able to copy files, give me access denied error. so i decided to quick format it and still the same problem. what do i do. thanks.
Hi, welcome to FixYa.
Do you copy your files using administrator account or others? If you don't copy it using administrator account, sometimes there's a policy with deny users to copy files in the root of the drive. Instead, try to make a new folder first, and then copy your files into the new folder.
Mar 11, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
When i try to install a critical update it was denied access by 7 zip. even after uninstalling 7 zip and installing winzip i still get the same response when trying to install updates 7 zip access denied....
Install Winrar, Here is the link
http://www.rarlab.com/rar/wrar391.exe
if you double click the file,the files will be extracted in the temp folder,so after installing winrar,right click on the file and select extract here. and try to install the update now,
Sometime when you extract files and it contains Malware or Trojan,Anti-Virus which support real time scan just block the files and the access denied message is displayed.
Scan the extracted files before installing so that you know it's Virus free.
Sometimes,even if you have administrator right,sometimes due to malware infection, you are denied access to some system hidden giles like folder under Local settings.
Dec 30, 2009 | Compaq Computers & Internet
Device driver will not install; error msg "Access Denied"
Ok so i was searching around the internet and found a similar problem with another monitor so for giggles i tried there method. This is the website where i found it : http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/d7c0e5bd-2fcf-48ff-a79b-c157014fc821/#page:3
The Second Entry has a download. Download it then extract the files to the desktop. Dont worry if you get errors when the program runs it will fix them, if they come up just press enter to keep going. Once the program completes install the driver again and it should work as it did for me.
If you cant get to that website heres the post from it:
"Ok, once again i checked updates for HP My Display/Drivers, and found this:
http://www.portrait.com/dtune/hpw/enu/support_help.html
Here is a direct link to fix for "Access Denied" issue (HP LCD Monitors & Vista):
http://download.portrait.com/DRVFix.zip
Download DRVFix.zip. The fix contains 3 files including this readme. All must be in to the same folder.
  • readme.txt - This file
  • RestoreDisp.exe - Executable required to restore permissions. DO NOT RUN THIS FILE
  • DVRFIX.exe - Run this file in Administrator mode after reading the instructions completely
To perform the fix do the following:
  1. Extract all files in to a folder on your desktop
  2. Open the folder, right click on the DVRFIX.exe file and choose "Run As Administrator"
  3. Follow the on screen instructions. When complete, you should be able to install your drivers
If you find this helpful, please let me know.
I fixed this issue manually (from registry), about month ago.
Regards
Vesa"
There you Go, KD0BGA
Apr 18, 2009 | HP w1907 LCD Monitor
Access is denied
Try to scan it with R-Studio or GetDataBack..
Oct 25, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Accessing a folder.
This will sound off the wall, but we had something similar to this happen with my last laptop, where it was "access denied" in lots of areas, and we would have to find little backdoor ways to get into control panel and document files. The problem with our computer was that it had previously crashed, and we had rebooted and reinstalled the xp, but didn't have the registration number, so it would run ok, but to get into all those access denied things (which you eventually need to get into) we had to come up with our registration number.
Did it prompt you to enter the product key when you re-installed it?
Jun 27, 2008 | SmartDisk FireLite USBFLB120 120 GB USB...
Samsung Digimax A40 Digital Camera Logo
102 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
