Question about Hansol 730E 17" CRT Monitor
Resolution hansol 730E
Hello, i'm french, so don't be so strong with my english.
I installed a new monitor hansol 730E, i put resolution 60 Htz, but i've always got a "eyes nuisance", and i don't know how to do, i have a old computer windows 98 and i can't find the disk to install the monitor, can you help me please.
    Scholar:
  • 84 Answers
Interesting, have you tried perhaps a monitor screen?
Posted on Feb 11, 2008
Displays the whole desktop in half of the monitor screen
Resolution settings are too high in monitor or computer video settings. Choose Recommended settings.
Mar 30, 2014 | Hansol 730E 17" CRT Monitor
I am using Hansol 730E monitor and recently it start to make slight vibes on screen in horizontal way. I tried to change refresh rate and its no good. I tough that it is magnetic field but i moved monitor...
Being a rare tube monitor i am inclined to say it is nearing end of life. You have done the right thing by moving around unless you are moving other magnetic or power source items with it. Have you tried connecting to another computer - subbed out cables to eliminate that issue? testing on another computer who help determine if monitor or not. might be video card??/ since you are having DX issues I would start there. There is not much more you can do that is not dangerous - ie - increasing the voltage etc..
Jun 13, 2011 | Hansol 730E 17" CRT Monitor
Monitor wattage
Spec:
http://www.hansol.nl/eng/730e.html
Since the company will nor even list the power consumption, You can make an estimate by reading the voltage and the current consumtion on the label, multiply voltage by current will give you wattage, but since the monitor is not linear load but reactive load, the power factor will not be 1 but usually about 0.6.
IE, 100V X 1AMP = 100VA. 100VA X PF OF 0.6 = 60WATTS.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | Hansol 730E 17" CRT Monitor
Hansol 730e , power led on , no display
check the cable connected on your monitor, see if this is fix and secure, on the other end of the cable, see also if this is properly connected to the video card.
If there is still no display, then my suggestion is you bring the monitor to a credible technician, and see if warranty is still available.
May 26, 2010 | Hansol 730E 17" CRT Monitor
My monitor is making high frequency noise
Install an AGP card into an AGP slot .because motherboard with internal display card does not support high resolution use 8X AGP card for better result
Mar 31, 2010 | Hansol 730E 17" CRT Monitor
Problem in monitor the screen doesnot get full wide of it by control panel
Assuming your running Windows as the operating system on your computer, go into Display Properties and set the refresh rate to something other than 60 hz or default. On my XP computer this can be done by right clicking on the desktop, clicking Properties -> Settings -> Advanced -> Monitor. Anything in the 70, 72, or 75 hz range should work fine. If this does not fix the problem and the monitor is out of warranty trash it and get another one.
Nov 10, 2007 | Hansol 730E 17" CRT Monitor
Hi all.. i have a problem.
No signal means the monitor is not detecting a signal from the video card. Can you give us a little history about what lead to the problem?
Mar 11, 2007 | Hansol 730E 17" CRT Monitor
Black vertical belt in both side
This sounds as if you havent got the correct resolution of your desktop. Either there will be an auto adjust button to press on your monitor menu or you will need to Right click on your desktop>properties>settings Tab and change resolution to 1024 x 768 or similair to change the desktop size, or maybe reduce to 800 x 600 then click apply.
Dec 08, 2006 | Hansol 730E 17" CRT Monitor
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
Hansol 730E 17" CRT Monitor Logo
293 people viewed this question
Top Hansol Computers & Internet Experts
Cleverer2
ray gallant
Andre van Wyk
Andre van Wyk
Level 1 Expert
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
