Question about Maytag MER5770 Electric Kitchen Range
Replacing smooth top
I broke the top of my stove - how do i go about replacing it?
  • 2 more comments
  • Anonymous Apr 28, 2008
    My smooth top is damage with the dots that came off can you help me
  • memy2girls Oct 14, 2008
    Im not sure what model I have because it was here when I moved in and the model number is riped off my smooth top is broken and has a big crack in it how do I replace it
  • Anonymous Feb 09, 2009
    I broke the smooth top surface of my stove. How can I get it replaced?
  • Anonymous Mar 15, 2014
    on light indicator light is broke. would like to replace it. Can it be replaced from the top.
  • 5,911 Answers
Have you purchased a new top yet? If you haven't, you can find it at repairclinic.com for about $270.00 (item #703866). Just type in your model number in the search index and you will find a pictorial part index for your range. The part isn't cheap, but it would potentially cost you twice as much to have a repair service replace it for you. If you still wish to pursue this repair, follow these simple instructions:
1. First of all, UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. Secondly, is the glass top still intact? I know it is broken, but is the glass completely busted apart, or is the top just cracked? If it busted, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cooktop. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4. On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the cooktop and leave the elements in place. Place the whole assembly face down on a soft surface (like some old towels, or a blanket) and remove the surface element assembly leaving all the elements wired together. Place the new cooktop face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place. Install the new cooktop back on the range and you are DONE.
5. If the wiring harness does NOT unplug, there are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
5. Lay the intact element assembly, with wires still connected, on top of the oven box handling the elements with care. they are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of.
7. Use care when screwing into the new cooktop. CAUTION: The scew holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
Good luck and I hope this helps.
Posted on Feb 11, 2008
How do I change a burner on a smooth top stove?
usually the top will tilt back so you can get to the elements .
Apr 09, 2016 | Kenmore Kitchen Ranges
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
Oven valve stem broke off
What is the model number of your unit?
Nov 05, 2012 | Kenmore Electric Smooth Top Stove
I broke the glasstop of my stove. Can I replace
http://www.partselect.com/Maytag-Stove-Parts.htm
just typ in your model number, and find the part you want on the diagram. you can purchase it through them, too.
Jul 31, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Since this is a Kenmore cooktop, contact a Sears store and they will assist you.
Feb 09, 2009 | Kenmore Cooktops
Broken glass top range
im sorry about that.i have replace many of those running around 400$,that a lot of money.i have see glass top stoves on sale 4 that much.and i think they all are about the same as quilty goes.God bless,tom
Jan 02, 2009 | KitchenAid KESC308LSS Electric Kitchen...
Crack on glass top stove
Hello
Welcome to Fixya
My name is Huum,
You can replace the smooth top !.
But I will tell you not to spend more than half the price of a new stove. How old is the stove and what's the model number!
Waiting your response.
Please remember to leave a rating before you leave
Dec 11, 2008 | Jenn-Air JED8430 Electric Cooktop
You said, you broke the top of my stove - how do i go about replacing it? I have a maytag smooth top stove I don't have the model number its torn off the stove was here when I moved in and now its broken and has a big crack in it how do I get a replacement please help.
This is more than likely your ranges model # MER6772 Gemini Electric Kitchen Range
Maytag will be able to replace the top once they come out!
Below is the info and help you asked for!
Thank You , Huuum
Please remember to leave a solved rating before you leave!!
Here is what you asked for!
Call the dealer from whom your appliance was purchased or call Maytag Appliances
Sales Company, Maytag Customer Assistance at 1-888-462-9824, USA to locate
an authorized servicer.
Be sure to retain proof of purchase to verify warranty status. Refer to WARRANTY
for further information on owner’s responsibilities for warranty service.
If the dealer or service company cannot resolve the problem, write to Maytag
Appliances Sales Company, Attn: CAIR® Center, P.O. Box 2370, Cleveland, TN
37320-2370, or call 1-888-4Maytag for PriorityOne Service (1-888-462-9824).
U.S. customers using TTY for deaf, hearing impaired or speech impaired, call
1-800-688-2080.
NOTE: When writing
Oct 14, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Smooth Top Electric Range
You didn't specify which type of smooth top - some, like the induction require special cookware. For the typical radiant type glass top nothing special is required.
Jan 03, 2008 | Kitchen Ranges
Maytag MER5770 Electric Kitchen Range Logo
3,372 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
