Question about Uniden Cordless Phone
Use phone as a room monitor
Just wanting to know if i can use 1 of my hand sets (we have 4) as a room moniter (baby monitor). a friend thinks i should be able to, but i cant work out how to. thanks....
  • 38 Answers
You can. Go off-hook on both the phones you want to use and this is what will happen. You may may get a recorded message from your central office or just a off-hook reminder tone that will last about 30 seconds and then you will hear the talk path between the two handsets. Keep in mind when you do this you can't receive any incomming calls because your line will appear busy to the callers. Thank You. Jerry
Posted on Feb 11, 2008
Moniter output not connect
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 20, 2014 | Computers & Internet
I just bought a second hand baby monitor from graco and they have charged but the one on my room is flashing a red light and continuosly beeps why???
When mine is red I check two things, that it's sitting flat in the charger and that all plug ins on all units are in snugly. The other thing is sometimes the main unit in the babys room is turned off so make sure the switch on the side is on. Hope it helps.
Jan 26, 2011 | Graco Imonitor Digital Baby Monitor
How do I use the Anglecare Deluxe Movement sensor moniter without the movement sensor? I would like to be able to hear the audio even if the baby is not sleeping on the pad but is in the room. Thanks.
mine has a switch on the back of the base unit with three options. one of which being sound only. another being sound and movement, and the third being tic off.
Oct 19, 2010 | Angelcare Deluxe Movement Sensor & Sound...
My motorola d10 phones will not register to the base.. i have two units and i wanted to use the intercom feature but cannot get either unit to show any signs of registering to the base.
Hi, I may be late at posting a reply but I had the same problem and I'm an IT Practitioner - So Motorola don't seem to like making things easy or even giving instructions - I tired out Google and eventually came across the result myself:
1. Go To Advance Settings
2. Then Go To Registration
3. Then Go To Search Base
4. And Keep Hold Of The Page Button On The Main Unit
( You May Have To Do This Several Times)
5. The Screen A Should Display PIN
6. Enter The PIN Which Is 0000 (Unless Changed)
7. REGISTRATION COMPLETE!!!!
Also I had problems with the intercom feature - when I attempted to intercom another handset - It wouldn't ring but this was fixed by turning the room monitor (Baby Monitor) off.
Best Wishes PINDY92
May 23, 2010 | Motorola Mobility Camo Cordless Phone...
One of the parent units does not want to pick up nursery units
If you have wireless phones in the house the frequency of the phones will mess it up or if u have a wireless internet connection that will do it too.
Jan 12, 2010 | Graco Imonitor Duo Baby Monitor
Baby monoitor reciever piking up no sound or delayed sound - link light flashing
A delay may be caused by interference from other radio sources. I heard of one case where a woman's cell phone call overpowered the transmit power of her baby monitor.
Other things that can cause interference or other receiver problems:
1. monitor in contact or close proximity to running appliances or their cords. (induced electromagnetic field)
2. neighbor with baby monitor on same channel ('cross-talk')
3. distance between transmitter and receiver too far (the strength of a radio signal fall dramatically over larger distances. think of how often you lose cell phone coverage)
4. reduced power: low battery strength or cooked power supply
5. transmitter or receiver insulated from signal (if your monitor was transmitting/receiving through any metal obstruction)
May 07, 2009 | Kitchen Appliances - Others
Room Monitoring remotely
Just seledt room monitor from the menu and it will ask you which extension to open up to monitor. Then you should be able to listen in on the baby.
Aug 29, 2007 | GE 21018GE3 Cordless Phone
Get Moniter Speakers Working
Hello First of all you need a sound card on your computer with a Spk. (Speaker) or Phones (headphones) Out Jack it might be a symbol of a small speaker or headphones. You have to be sure you are getting a actual sound output signal from this sound card too. If the sound card is not working your moniter speakers would not have a signal to drive it. You also need a 1/8" Stereo 2 male stereo plugs on both ends, one end plugs in back of moniter other plugs in back of computer like I mentiond above. Make sure your Mute button is not selected on your computers volume button usally at bottom right of screen. Make sure the volume buttons are up to aprox 3/4 up also. Then for last on the moniter look in the menu i think you might have to keep pressing the menu button but i kind of forget now but its a Spk setting and volume setting in this speaker setup within the moniter as well make sure this is turned on and set at a higher volume level as well. Thats about all I can say without taking the moniter apart and checking the jack and wires and speakers. I would suggest you take it to a electronics or a tv repair or computer repair person to go any further then this. Hope you take time to read all of this I tried to put every step in here to help anyone out with this problem. Thanks for reading. Ken T
Nov 08, 2006 | Liquid Video A170E101 Monitor
Uniden Cordless Phone Logo
104 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
