Question about RCA P52771AT 52" Rear Projection Television
Just red will not work
Blue works green just started to work no is just the red don't know why the green started working
  • 61 Answers
The screen asy is bad,part number 204809,must use the generic for this part.
Posted on Mar 04, 2008
My 95 nissan pickup has light issues. I can't seem to figure out what causing the night not to work I have tested the fuse block and all leads into the illumination control switch but don't know where
According to the wiring diagram, you should have two 15amp fuses powering the headlight switch. One wire is red and the other is red white.
Power out of the switch is pink blue for the tail lights, and red with green, blue, black, and yellow for each headlight circuit.
Diagram courtesy of autozone.com
Feb 28, 2013 | Cars & Trucks
Samsung HLR5067 has no green color in picture
I know this may seem dumb but if you are using component video (the red green blue with the white and red audio cables) it could very well be that the green cable (carries the green signal) is the problem. try changing the configuration (ex: use blue to carry the green signal and vice versa) if the green starts to work and the blue stops then its just your cable.
Oct 18, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
I don't know how to successfully connect a JVC AV-27220 (a television) to HR-XVC29SU (a DVD player). I have a set of blue/red/green cables, but the colors don't match the markings on the devices....
The standard colors are : White, Yellow and Red. If you match the Red of the TV, the White of the TV and the Yellow of the TV to the same colors on the DVD player, then all should work properly. It does not matter what color the cable is, match color for color on the devices. Hope this helps and good luck from a teacher to another teacher.
Oct 29, 2017 | JVC AV-27220 TV
I would like to install a Pioneer DEH-P3800MP stereo system in it and don't know which wires connect to the stereo!
2000 Hyundai Elantra Stereo Wiring Constant 12V+ Light Green Switched 12V+ Brown Ground Black Illumination Dark Green/White Dimmer Dark Green/Black Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Green/Red Left Front (-) Light Green/White Right Front (+) Red/Blue Right Front (-) Light Green/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Yellow/White Left Rear (-) Yellow/Blue Right Rear (+) Green Right Rear (-) Green/Blue
Jun 22, 2011 | 2000 Hyundai Elantra
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
The Screen Turns Green then shuts itself off? Is this the Bulb or something else?
My sony 65Ws500 model about 4 months ago it started turning the screen all blue as soon as I turned it on. it stayed blue for about an hour then come back on normal now when I turn it on it will shut down and I get a small red light flashing 8 time then pauses and does it again 8 time then pauses then again and so on. I took back panel off. I turn on tv The blue bulb gets very bright and the green and red projection bulb goes out and now it shuts off. and the blinking starts it a code flashing but don't know the code to find out whats wrong. would someone help if u can been wife and I laid off from work 3 months now cant afford tech prices on our employment. wife and I has 2 little girls to raise. along with the rest of u parent out there and one getting employment cant offord repairs. Thank U. Adams01220@yahoo.com
Feb 13, 2011 | Sony KP-65WS500 65" Rear Projection...
03 monte carlo ss power seat wont go down. how to fix?
i have a 2003 monte carlo and the wires came out of the plug under the seat. im trying to put them back in so my seat will be able to work. there are 12 wires that make up 6 connections. i need to know what wires go together. the wires are red with blue strip, red with green strip, red with white strip, yellow with blue strip, yellow with green strip, yellow with white strip, light green, green, peach, blue, light blue, and yellow.
Jun 08, 2010 | 2003 Chevrolet Monte Carlo
Putting in a alpine deck into my cirrus
Constant 12V+ Pink/Yellow Switched 12V+ Red/White Ground Ground/Back Strap Illumination Orange/Brown Dimmer Black/Light Blue Antenna Trigger Orange/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Light Green/Green Left Front (-) Light Green/Purple Right Front (+) Light Blue/Green Right Front (-) Light Blue/Purple Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Blue/Light Blue Right Rear (+) Dark Blue/White Right Rear (-)
Dark Blue/Orange
Mar 28, 2009 | Alpine CDA-9847 CD Player
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
