Question about Labtec Pulse 485 Computer Speakers
Speakers fried a regulator
Myspeakers burnt one of the regulators. and the amount of power going to the woofer and satalite speakers seems to be far more than what it should be. what could be the problem and can i solve it?
  • 56 Answers
Replace the reguletor & change the satalite speakers. If not solved for more assistance ask me 7-8 days later.
Posted on Feb 11, 2008
Static on HK395 satalite speakers
It might be beacuse of some sort of wireless interference like a cell phone.
Mar 10, 2014 | Dell HK395 Computer Speakers
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
I need replacement crossover because they got burn
The crossover in these is very simple and if it is burned, likely your speakers, maybe both, the woofer and tweeter have been damaged and need to be replaced. Test the speakers before changing the crossover. You MAY NOT notice the damage until you start driving the speakers again. The voice coil of the woofer is a common thing to fry, and while it may not open up, often it becomes unbonded to the coil form and rubs the magnet pole pieces. The tweeter/horn often wipes out the diaphram or blows the element open. Some of these are piezo horns and they can sometimes survive. These are rated at 100 Watts and if your amp can deliver over 50 watts you have to be careful to not put too much power into these. I have several of the Kustom 10 inch ones and several of the 15 inch ones... Also I have two 15 double stacks and they all seem to use the same crossover. Believe me, the crossover is far from what I would call "special" like the advertisements say. As an electrical engineer I was very disappointed. Anyway, test your speakers as they may be the worst of the problem.
Mar 27, 2011 | Kustom KPC12M / Phonic MAX 1000 Spkr & Amp...
No power in my altec lansing S100 121i 2.1 speakers
troubleshoot the transformer and try to replace the Opamp (UTC458) on the circuit board. the Opamp might be broken and shorting the circuit and fry your transformer. goodluck.
Jun 26, 2010 | Altec Lansing 121i Computer Speakers
My sub woofer will stop working if i put the bass up to loud, ill have to turn my car off and on to get it to work again. What could be the problem?
Seems like your power amp for the sub woofer may be going into protect mode/thermal overload when you push the volume too much. Therefore it shuts down. I am surprised the speaker hasn't blown yet.
As far as turning car off/on to get it to work, it's as if your car is the power switch.
Amp and speakers may not be wired correctly, as you want to make sure your amp/speaker ohm measurements are within a specific range for the amp and speakers work together properly. You may have it wired for a 2 ohm load, and maybe your amp can't do 2 ohms all day long.
Apr 09, 2010 | Kicker Comp DC12 2-ohm Enclosed Subwoofer...
How to connect a 4 ch amp to 4 speakers and sub-woofer
http://www.audiosavings.com/content/ebay/SubWiring.html
this link will help u understand the wiring & how too wire your speakers...
as far as speaker ohms & amps go, 4 ohm speakers should be wired too 2) two ch. amps.
hope i was of sum help.
Jul 14, 2009 | Car Audio & Video
Altec lansing AVS 500 IC
The amps are 8-pin CHN 4558CN [K1D142] and 8-pin PHIL TDA8199 [LD8136] The Voltage Regulator is a 14-pin LM324N There is a 3-pin LM7812CN 12-volt regulator... They are in the sub-woofer housing which is held in place by tape so it can be pried off if done with care. Hope this helps. If you have all the cables and wires in place I would appreciate knowing the connection sequences (someone cut all the wiring to the set I have.)
Jan 22, 2009 | Altec Lansing 621 Computer Speakers
Fried Woofer
The problem are worsen that before. It is wisely to replace both left and right amplifier
IC, but make ensure that the power supply feed a good amount of voltage to amplifier,
Also a strong good signal. Be sure to measure it.
r_ic7
Jun 22, 2008 | Alesis M1-Active MkII Main / Stereo...
Labtec Pulse 485 Computer Speakers Logo
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
