Question about GE Profile Prodigy WPSE4200A
Washer not spining
Washing machine is washing and rinsing ok but kicking into spin you can hear the water pumping out but not spining could it be the bushes if so where do you find them on washer
  • 5 more comments
  • sylvia123 Feb 11, 2008
    problem fixed thanks took motor to repair shop they tested motor was ok then told them hubby had put one shirt in to wash they said put motor back on could be because with it being light the machine would not recon anything in wash /i puta normal load of washing in works like a dream thank for help anyway
  • Nanjes Feb 25, 2008
    My washer is not spinning. I was told to take the back off and replace the belt. How do I get to the belt?
  • Anonymous Jul 05, 2008
    Machine will wash, but will not spin at all, please help?
  • Anonymous Aug 23, 2008
    Machine washes normally until the spin cycle, then operation is intermitent. It won't spin a normal load at all, ususally spins a very light load, but not every time. I've replaced the belt, but that didn't fix the problem.
  • Anonymous Dec 02, 2008
    my washer won't spin the clothes, If I wash a light load then maybe it will spin the clothes It won't spin a heavy load at all.
  • Anonymous Jan 31, 2009
    I have a GE Profile washer that would drain but not spin. The motor worked and the drum would spin by hand from underneath with the belt off. I bought a new belt and when I replaced it I noticed a roll pin ( that goes through the shaft on the motor and engages the clutch ) had sheared. That was the problem.
  • Anonymous Mar 28, 2014
    the washer spining & dont wash
I took the bottom panel off the washer. I don't know what i'm looking for?? Help!! The washer won't spin. the belt and motor are ok..
Posted on Sep 14, 2008
I think there is problem in your water outlet pump problem first of all you check water is come out or not from machine
Posted on Feb 11, 2008
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
WHY ON MY MAYTAG EPIC WHEN IT GETS TO SPIN IT JUST MAKES DRAINING NOISE AND WATER WONT DRAIN?
Sounds like your drain line is clogged. You may also have stuff clogging a water filter just before the pump, or the water outlet coming from the drum.
It could also be a problem with the pump, but until the drain line is opened up, you still won't be able to empty the water from the washer.
Aug 11, 2014 | Maytag EPIC MFW9700S Front Load Washer
Washer WPSR3100WOWW Will wash but not drain and spin... Stops at the rinse Cycle
Christina,
Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
Oct 12, 2013 | GE WSXH208A Front Load Washer
My washer fills with water on starting a load but then it does nothing won't start spining to empty water
If the machine loads ups with water and does not stop then the water level sensor is fautly . But if the inlet valve stops on fill up but there is no spin of the motor or thereafter there is no spin/rinse or drain then the program controller / drain valve/pump must be checked.
Jun 14, 2011 | Washing Machines
Washer will not drain. I can hear the motor or pump spining.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 22, 2010 | Kenmore Elite 45986 Front Load Washer
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
My washer stops after rinse and kicks out will not spin
You have a bad motor. Your motor turns in ine direction to wash and the other direction to pump and to spin. Sorry.
Please rate solution
Aug 24, 2009 | Whirlpool Washing Machines
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine not spining
You may have a problem with the rotor position sensor. This sensor is situated on the motor windings and should really be replaced by a qualified tech.
Nov 04, 2007 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
631 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
