Question about Palm m515 Handheld
Palm M515 hot sync problem
I've been using this item for 1 year.Now suddenly it won't hot sync. The connection to the cradle is USB. the setup only shows Com 1 option. But I never had trouble before. I've done a hard reset, reinstalled palm desktop and unconnected, reconnected USB cable between reboots. Any other help would be greatly appreciated.
Thanks!
Bill Higbee
I have a similar problem. I have 3 palm m515 and the 2 sync fine and the 3rd on the same cradle won't sync. The computer wont even recongnise it and the ensuing message is "the connection between your handheld computer and the desktop could not be established. Please check your setup and try again". What do I do?
  • Paulhood Mar 27, 2008
    what do you mean by the "lead" is this the connection to the cradle?
    Why would the firmware not work not but it did before?
  • Palm Master
  • 13,433 Answers
I would uninstall all palm software then when there are no drivers installed for the palm connect it to your pc, do you get a new hardware found pop up or not? If you don't try a difrent usb port, if you still dont. try a difrent pc
finaly if it doesnt work even on another pc then the cable or cardle is broken, or maybe the connector on bottom of the palm isnt working anymore.
let me know how it turns out.
Posted on Mar 27, 2008
    Guru:
  • 1,894 Answers
I think this is a problem in the connection medium only i think.
try some different thing.
also since u have even reinstalled the problem of software can be ruled out.
there is some kind of hardware problem for sure.
    President:
  • 1,944 Answers
It could be that something has malfuntioned which includes the cable...the connectors on the cradle or on the palm. Look and see that all pins are in it's proper position and none are twisted or missing.
  • 4,102 Answers
Hi you could either have a problem with the lead witch is the cheapest problem to solve the other problem is with the palm top itself if this is the case then you will need to send it off to get the firmware updated you cant do this yourself because you cant get the correct software to do this you might even need to put the device in recovery mode to install the latest firmware so it will need sending off to do this if you contact customer support number for your device then they should tell you the best way of doing this ok
Posted on Feb 11, 2008
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
A friend had given me his old palm m515 but i dont know how to work it i would like to print off an owner manual is that possible
I did a google search....this is what I found.
[PDF] Handbook for Palm m500 Series Handhelds File Format: PDF/Adobe Acrobat
Welcome to the Palmm500 series handheld. This handbook is ... One USB port or available serial port (serial cradle sold separately) ...
www.palm.com/us/support/handbooks/m500series_ug.pdf
Jan 28, 2011 | Palm m515 Handheld
If I did not charge my palm m515 will it still work? I just got a Palm m515 and I did not charge it for 24 hours before syncing it to the computer. It works fine on the cradle, but it will not keep a...
the m515 uses a Lithium battery .. the modern version of those batteries have a built in safety feature .. once its first activated then it monitors its own voltage .. if the voltage is ever allowed to go below a certain value then it will refuse to accept a charge ... when it tells you that the battery is dead its actually well above that critical voltage .. but if you let it sit for a long time then self discharge can bring it below the critical value .. when the battery is in that forbiden region then there is a chance that it will grow copper links through its insulator .. then when you try to charge it it could get very hot .. even explode .. so thats why the safety feature .. there are ways to jump start the battery and some people do that .. but you can see there is some risk .. the battery in that palm is not hard to change and they are not expensive but you need a very small torques driver to get the case apart .. i just took my 515 to the hardware and had them match it up with the proper tool .. there are kits available also that have a new battery and the proper tools to take the m515 apart .. of course they cost more..
make sure you have the external charger hooked up to the cradle .. it wont charge from the USB port voltage as i recall on this model..
Sep 04, 2009 | Palm m515 Handheld
Unsucessful hot sync
If this is still a prob..email me at bobzmailroom1@peoplepc.com there is a trick. Your prob is your pc
Aug 23, 2009 | Palm m515 Handheld
Palm m515 and new computer
go thru the stylus calibration .. set the clock and/or push next .. then push done .. that will get you back in operation .. click on the "Home" button until you see the "hot sync" icon .. click "hot sync" .. your user name is at the top right corner of that window .. just click "home" again to get out of that window ..
Apr 06, 2009 | Palm m515 Handheld
Palm Pilot: Connection for Hot Sync
Has synch worked before on this set up?
Jan 01, 2009 | Palm Z22 Handheld
Handspring Platinum with USB cradle
I read and followed several troubleshooting articles from the Palm OS site, including these:
34697
26460
31991
10089
26674
10092
10082
Installed Palm OS 4.0.1
30421
3447
25019
10099
36950
887
However, none of those technical articles helped much, except after going through them, my Palm OS desktop started to work after not opening up at all. Still, my Handspring Platinum would not sync with my PC.
What brought success was following these articles:
2630
1409
28618 (Part 1 of 3)
28623 (Part 2 of 3)
In 28263 (part 2) it said to reinstall certain drivers (steps 5, etc.). As soon as I did that, everything started to work just fine and has been ever since.
Jul 05, 2008 | Handspring Visor Platinum Handheld
I have a similar problem with my m515. I have 3 palms and 2 sync fine but the 3rd isn't even getting to the computer. There is no recognition from the computer that the palm is trying to sync even though I use the same cradle for all palms. The ensuing message is, "the connection between your handeld computer and the desktop could not be established. Please check your setup and try again". My settings are set Local and Cradle/Cable.
Dec 20, 2007 | Palm m515 Handheld
Palm M515 and compatibility with Vista Home Premium
I was having a similar problem with my M515.  I had originally installed the Palm Desktop from my CD, which was an older version.  When I totally uninstalled the old version and installed the newer version from the Palm website I was able to do a successful sync.  I'm using Windows Vista Ultimate and Palm Desktop version 4.1.4
Oct 24, 2007 | Palm m515 Handheld
Synch problem after installation
If your cradle is connected to a serial port, you will need to ensure that HotSync Manager is configured to use Serial Ports. To do this, follow these steps: 1. Click the HotSync Manager icon in the Windows system tray. 2. If there is a check mark next to the 'Local Serial' menu item, then you are already configured. 3. If there is not a check mark, click the 'Local Serial' option. For more information, refer to the handbook that came with your handheld. If you did not uninstall your previous version of Palm Desktop, the configuration will be done automatically.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Palm m515 Handheld Logo
443 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
