Question about Miele Novotronic Premier 500 Front Load Washer
Miele Novotronic. Hi i have a novotronic w502 front loading washing machine. Most times the machine will constantly drain as soon as it fills. It always displays check inltet.. I have checked for water on the bottom tray and have cleared out all the drains. I have also checked the water inlet and filters and they appear to be fine. Very occasionly It will go through the correct cycle. Other times when it gets to the spin cycle it will constantly repeat the cycle. I am an electrician but cannot find the wiring schematics. Can anyone suggest a reason for this
  • 16 Answers
On a cotton programme, in main wash, does the water level get very high? Like as in past half way up the door??
Does then the drain pump kick in?
Of so the pressure chamber in the machine is blocked.
Turn off the mains to the appliance.
You will need to remove the front of the machine to get to this.
The presssure chamber is connected to a small diameter black rubber tube which either goes to a electronic switch on the front board or to a mechanical pressure switch in the machine.
The chamber is located next to the heating element, middle bottom part of the front plate of the outer drum. It's an odd shaped white plastic container held in via a 8mm bolt and a seal.
Remove the bolt, grab hold of the chamber and give it a gentle pull.
Once you have the chamber in your hand, you should be able to run water from the larger hole which was pushed into the seal in the drum so it runs out of the smaller hole which was attached to the small black rubber tube.
If not it's blocked.
Replace it or clean it out.
Spray a small amount of WD40 onto the seal before pushing it back home, it will help it pop back in.
You may be unlucky and it's taken out the heater element and messed up the setting for the electronic pressure switch.
You will know this by a very, low water level (like hardly none) and after about 90 mins the main wash light will flash.
Post back if you have any more info.
Good luck
Posted on Feb 18, 2008
  • 54 Answers
All miele are supplied with schematics. on washers take the top off and its on top of dispenser tray. if not there remove front panel it will be there
Posted on Feb 14, 2008
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
My Miele Novotronic W 844 Washing Machine will not completely spin dry my clothes. They are soggy at the end of the wash cycle. Help please! (My machine's settings are in German.)
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent from drain pump blocked.(Vent left front side of soap drawer. Visible when drawer removed)
Mar 19, 2010 | Miele Novotronic W1918A Front Load Washer
How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Jan 10, 2010 | Miele Novotronic W1918A Front Load Washer
Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Aug 21, 2009 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
1,012 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
