Question about LG RH266 Recorder
Finalization problem2 LG HDD/DVD Recorder RH266 I can record from HD to to DVD but finalization menu doesn't appear. It did appear once but with finalization blanked out and has never been seen since..
After transfering video from HD to DVD, before you press the "Menu" button. please make sure you you press "DVD" button on your remote to tell the machine you want the menu for "DVD" first.
It confused me at first :-)
Hope this helped
Posted on Jul 24, 2008
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
I mislaid my operations manual for LG rh266 hdd/dvd recorder
Try the manufactures site for this if not available , I have found most manuels available on Bit torrent hope this helps ..Regards Vortash
Mar 18, 2009 | LG RH266 Recorder
LG RH266 DVD Recorder no sound
Hi .. It sounds like the problem you have is incompatabilty I assume that you haven tried Phono connections instead of scart , as this sometimes cures this problem .. or when purcahsing a scart look for the Miirrored type this means that the inputs and outputs are reversed this also sometimes cures the problem as some scarts put output to output and input to input ect when actually it should be output from tv to input dvd and so on ie wrong scart and there are a few of the cheaper type that have this problem .. if you have no luck using the phono let me know .. Regards Vortash
Jan 07, 2009 | LG RH266 Recorder
DVD - Video Finalization rejection
1. The message can appear if the disc has already been finalised.
2. The disc may be faulty.
3. Try copying again from HDD to another disc. Performing a copy and finalise together by using 'DVD Video Creation' from the Edit menu can be more successful than doing each step separately.
4. When you transferred from your video camera, did you use firewire? If so, did you record at the maximum (default) bitrate of 14+ ? If so, you must copy (rate conversion) to the DVD at a maximum bitrate of 9.2, which is the maximum for the DVD playback standard.
Jan 01, 2009 | Toshiba RD-XS34 DVD Player/HDD Recorder
Dvd finalization
I turned off the Colby recorder then turned it back on and inserted the DVD and chose the edit button on the remote controller. The correct menu with the close and finalize choice became available.
May 26, 2008 | Coby DVDR1280 DVD Recorder/HDD Recorder
Recording problem with LG RH266 Recorder.
If the DVD is copy right protected then it won't record. By this I mean, you can't simply rent a DVD at Blockbuster and transfer it to the Hard Drive (use a computer to do this instead). Try using a DVD that is not protected, like a home video or a cd with MP3s
Feb 26, 2008 | LG RH266 Recorder
Record at once on dvd?
No direct record from TV to DVD on this model, yes it is very annoying...
Jan 16, 2008 | LG RH266 Recorder
Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
Jan 05, 2008 | LG RH266 Recorder
Lg rh266 recorder
When you put your disc in and its ready for copying over through Dubbing - when you see the quality ie xp - just press right or left til the FAST sign comes up. it maynot always come up if the recording time is any longer than an hour or less than 30 mins.
pg 47 of your manual
Regards Chris
Dec 20, 2007 | LG RH266 Recorder
make sure you set dubbing speed to sp ,short play,thats the default setting,then go to start up menu and finalize disk
Oct 11, 2007 | LG RH177 DVD Recorder/HDD Recorder
LG RH266 Recorder Logo
142 people viewed this question
Computer Repairing
Computer Repairing
