Question about HP LaserJet 3055 All-In-One Printer
HP laserJet 3055 network connection
How can i connect it to the network
  • 6 more comments
  • Anonymous May 03, 2008
    hi,
    please just go to the control pannel >select add printers >select for networ mode >it will give you the IP address >next >as for an test page just say yes .Then the printer is connected to the pc automatically.
    regards,
    Venkatesh
  • Anonymous May 05, 2008
    sir my printer is canected for LAN. BUT THIS NOT CONECTED PRINTER. I WILL GIVE FOR MANUL IP .THIS NOT CONECTED. NOT PING FOR IP IN SYSYTEMS
  • Anonymous May 24, 2008
    same problem
  • Anonymous Aug 17, 2008
    we cant share the printer in small home
  • g_dshah Sep 17, 2008
    I have got workgroup environment.
    All pcs are connected to 24 port switch. Have got MTNL triband router for internet. DHCP is enabled on that router. All pcs get IP address from that router. So, there is no static IP address to each PC. Now if i connect printer in network. which ip address i need to put as every time it will get a new ip address from DHCP.
  • Anonymous Nov 12, 2008
    Dear Sir,
    we are facing same problem we connect printer thru network but not show printer option only fax and scan shown we using window 2000, pls help
  • Anonymous Mar 25, 2014
    I want to find the page count for my HP LaserJet 3055
    I want to find the total page count for my HP laserjet 3055
HOW TO CONNECT HP 3055 TO ROUTER/WIRELESS NETWORK. WINDOWS XP/WINDOWS VISTA.
I have just finished successfully connecting my HP 3055 to my router and using it over wireless on 2 computers, one with windows XP SP2 and one with VISTA.
INSTRUCTIONS FOR CONNECTING HP 3055 ON XP:
FIRST CONNECT THE PRINTER TO THE ROUTER WITH A ETHERNET CABLE. FIND OUT THE IP ADDRESS OF YOUR PRINTER. By me it was 192.168.0.66
Go to CONTROL PANEL and open "PRINTERS AND FAXES". on the top left choose "ADD A PRINTER" click "NEXT".
In the "LOCAL OR NETWORK PRINTER" window, choose "LOCAL PRINTER ATTACHED TO THIS COMPUTER" and uncheck "AUTOMATICALLY DETECT"... click "NEXT".
In the "SELECT A PRINTER PORT" window click the radio button "CREATE A NEW PORT", click the down arrow and choose "STANDARD TCP/IP PORT".
In the window that pops up click "NEXT"
In the ADD PORT window, where it says "PRINTER NAME OR IP ADDRESS, type in your printers IP address, by me it was 192.168.0.66. The bottom line will fill in automatically. Click "NEXT".
In the "INSTALL PRINTER SOFTWARE" window, if you have the disk just choose "HAVE DISK" and install from there. If not, in the left column choose "HP" and in the right column choose "HP LASERJET 3050" (by me it showed up in the list, you can download the driver from here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
click "NEXT"
In the "NAME YOUR PRINTER" window, choose a name and also choose if you want to set it as the default printer (recommended) Click "NEXT"
In the next window choose whether or not you want to share the printer, and if you do assign a printer name. Click NEXT. The next window is optional if you want to make a name, you can just click NEXT and your done! Print a test page to make sure that all is fine.
Posted on Feb 19, 2008
  • 28 Answers
If you want connect the printer to the network and use as shared printer.you want to know what is "static IP address" versus "dynamic IP address', "subnet mask" and "default gateway". I started installation just by connecting printer to the network and running installation CD
Method :
setup your static IP from printer keypad, such as 192.268.1.85, subnet mask 255.255.255.0, default gateway 127.0.0.1. This is not universally OK, must be in sync with your router. When installation software wants to locate the printer, DON'T, repeat DON'T select option "search by scanning printers". Select option "defined printer address" and on teh next page select IP and enter IP defined manually on the printer keypad. That the Way Check it
Posted on Feb 12, 2008
How can i connect at HP Laserjet 3055 when the host has OP windows XP and my PC OP is windows 7 can you give me some feedback.
Posted on Oct 19, 2011
But any body help me how to find out the IP its adress
Posted on Jul 11, 2008
I was using my 3055 with my networkin set up but suddanly my computer stoped reconizing the printer and the light in my router which use to be green turned to yellow pl. guid.
Posted on Mar 04, 2008
  • 102 Answers
SOURCE: HP LaserJet 3055 scan over network.
If you have installed the printer using Add printer and faxes then you have just install the printer drivers which will allow you to print over the network.
However if you want to scan over the network than you have to install the complete software of the printer .
If you do not have Software CD than you can download and install the software fom Link below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=1140780&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
Democritus
  • 120 Answers
SOURCE: driver cd for hp laserjet 3055
Drivers can be downloaded at the link above.
SOURCE: HP LJ 3055 Toolbox Not Connected
It sounds like a Firewall configuration issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=378056&prodTypeId=18972&objectID=c00192126
Ports 5225-5226 need to be open on the router and on your machine.
Posted on Nov 13, 2008
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
marlen56
  • 110 Answers
SOURCE: PCL XL error in hp laserjet 3055
information about the cause:
PCL XL error pages that print from an HP LaserJet 1200, 1300, 2200, 2300, 3200 or 3300 series product when a PCL 6 printer driver is in use typically indicate a communication issue. Sometimes this issue is caused by an incompatibility between the Enhanced XL language and the software application.
You can find the solution for this error here:
(It's a long instruction page, I advise to copy the sections that refere to your OS to a separate document, so you don't miss any step)
URL to HP service page:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1161389&prodTypeId=18972&prodSeriesId=1161389&objectID=bpl10637
Posted on Aug 29, 2009
HOW TO CONFIGURE LASERJET 3055
USB: Run the cd, when its asked for connecting connect the usb cable, do rest..Network. Menu>network setup>TCP/IP>enter IP address>save it.connect network patch cable, take configuration page through printer menu settings, verify the IP address save or not> go to system 1. Run the CD select network as network printer> system will detect the printer go for rest of the process..
2. Through system> start> settings>printers& faxes>add printer wizard > select as local printer> select create new port in dialog box> select TCP/IP> type configured IPadress> do rest of the run process..
Jul 11, 2012 | HP LaserJet 3055 All-In-One Printer
Please advise what cables are required for the HP 3055
To connect to the computer directly a standard USB cable. To connect to a network you will need an Ethernet cable. To connect to a phone line for faxing, you will need a standard phone cord to go from the printer to a standard household phone jack.
I hope this has answered your question
Sep 01, 2011 | HP LaserJet 3055 All-In-One Printer
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
Scanning from the network
Dear Friend,
Install the printer driver on your computer and than download fix scan utility from Hp.com. After installing fix scan utility You will be able to scan.
You have to do the same on every computer from where you want to scan.
Regard
Under Trainee
Dec 17, 2008 | HP LaserJet 3055 All-In-One Printer
Hi SaveWetland!
Without being able to see your machine, I'm going to make an educated guess at your problem. Many times, when a printer is used over a network, only the printer driver itself is actually installed on each user's machine. Utilities, such as the HP Toolbox, may not be installed. If your network administrator allows it, you could download and install the complete printer software package off the HP website, which I'm highly confident would solve your issue. If not, I'd advise you to contact your IT person and have him/her install the complete package for you.
Good luck and I hope this helps. Please let me know, and also provide a rating if you deem it appropriate.
Bob
Oct 15, 2008 | HP LaserJet 3055 All-In-One Printer
Envelope Formating Using Word 2003 & HP Laserjet 3055
The problem occurred when I used network but not direct connection. It turned out I had the wrong driver for the network connection. I learned this through HP's online troubleshooting tool.
Sep 30, 2008 | HP LaserJet 3055 All-In-One Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
Hp 3055 all in one
ok DO check my link to setup the network
http://www.fixya.com/support/t391229-hp_laserjet_3055_network_connection
thank you
Dec 14, 2007 | HP LaserJet 3055 All-In-One Printer
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
13,054 people viewed this question
Ben Johnson
