Question about Philips GoGear SA178 MP3 Player
Cannot unlock it
Gogear 1gb just shows padlock symbol breifly then turns off,how do i unlock it.
  • 476 Answers
The hold button is activated. The hold button stops buttons accidently being pressed when the player is being used during sport or exercise.
Slide the hold button towards the RESET button hole in the side of the casing.
Posted on Feb 11, 2008
The lock symbol is showing but the door can open and no functions on the oven will work apart from the clock
This is the keypad lock (symbol looks like a padlock?). Find the button that has a padlock symbol near it, hold down for 3 seconds, should unlock your keypad. This should be described in your user manual if not indicated on the touchpad.
Aug 28, 2015 | Ovens
It says it's locked; to click ok when unlocked, But it's not locked. How to reconcile?
The physical lock may be engaged on the scanner.
Turn the scanner upside down and look for a button that slides. There should be a locked padlock symbol to one side and an unlocked padlock to the other side. Make sure the switch is set to the unlocked padlock side.
When you are not using the scanner or if you are moving it, it is a good idea to engage the lock switch so that the mechanism inside is not jolted out of alignment if it is bumped by accident.
Mar 15, 2015 | Office Equipment & Supplies
How do you release the scanner lock switch on the MP990
Open the document cover of the scanner decision, you should be able to slide the release lock switch towards the hinge side of the document cover. There is a padlock symbol on each side of the switch; the side closer to the hinge is an unlocked padlock. The other side has a locked padlock symbol. If the all-in-one was on, turn it off and wait 5 seconds before turning it back on after unlocking the unit.
If the switch is in the unlocked position and turning the printer off and then on again doesn't resolve the error, the unit needs service. Contact Canon if it is under warranty. (Otherwise, decide if the printer is worth the service call.)
I hope this helps.
Oct 30, 2012 | Canon Office Equipment & Supplies
Symbol showing on display
you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual
Dec 18, 2011 | Whirlpool Washing Machines
Locked
Switch the lock symbol on the bottom of the player to unlock the little button from left to right. That should do the trick.
Apr 17, 2008 | Philips GOGEAR SA6045 MP3 Player
How to remove battery from compaq presario 2100
Hello there,
There should also be a switch to lock or unlock the battery.
It will show a little padlock. Turn it to the symbol with the padlock open, then pull the slide release and the battery should come out.
Thanks,
Lolita
Apr 11, 2008 | Compaq Presario 2100T Notebook
Philips mp3 1GB SA3114/97 padlock symbol?
Slide the padlock lever on the left side from the up/on position to the down/off position
Mar 12, 2008 | Philips Audio Players & Recorders
Unable to unlock Centrex tv model CTT6809SF
Try holding down the + symbol on bottom right hand side of controller for more than 4 secs
Jan 01, 2008 | Televison & Video
Philips GoGear SA178 MP3 Player Logo
254 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
