Question about Dell Dimension 3000 PC Desktop
No Sound I have went in and checked all my settings My speaker works, All the settings are correct in the volume controls. I went into windows media player. All the settings in audio are good. I went into my sonar home studio 6 and everything is correct. I ran a test on the system on all inside sound devices and the card itself and it says everything is running successfully. I am bewildered... All I did was unplug my system and move my work space to the other part of the room and re- plugged everything back in. and Walla, no sound. I took the speakers to my wifes laptop and the speakers are fine. The only problem I had before was having to restart the computor for the sound to activate. Plus I even tried to do a restore and still nothing. I have everything plugged in. This is totally odd. Have you ever come across this. Sure could use your expertice. Thanks Jimmy
  • Jimmy7 Feb 11, 2008
    Everthing Is working fine. The only problem is that the system speakers has reverb coming out of it. I can record with no problem in my sonar but my effects are not highlighting in my sonar, and the same reverb that is coming through the system is on the sonar. How do I activate the effects and get the reverb off the computor audio. Sorry to be a pain, If you know how I can change this it would be greatly appreciated. Thanks again Jimmy and Katy
    We have the effects problem fixed but we are still getting an echo out of the speakers when using the microphone. Can you help?
    Problem Solver:
  • 24 Answers
Carefully plug back the minijack for the speaker at the out or spk,
normally the sound card has three ports 1. for MIC 2. LINE IN 3.OUT (SPK) - SPEAKER.
carefully plug the minijack for the speaker into the third one - OUT (SPK) - SPEAKER.
in pluging it in, first put on a media clip on the windows media player and carefully plug in the minijack for the speaker and surely you will hear sound.
UZOWUANYA
e-mail: uzowuanya@yahoo.ca
Posted on Feb 11, 2008
I have an HP Laptop with Windows 7 and I have correctly set up my Logitech LS21 speakers, but the volume control does not enhance the sound coming from my laptop. The speakers work fine, but the sound is...
There are 2 volume controls on the audio output in windows 7. one is the system volume the other is the device volume. make sure that they are both at full and then control the sound volume on your speakers.
Jan 20, 2013 | Logitech LS-21 2.1 Speakers
No sound device
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 15, 2011 | AMD Computers & Internet
2.1 SPEAKERS NO SOUND. CONTROL PANEL DOESN'T RECOGNIZE ANY AUDIO DEVICE & CANNOT ADJUST SPEAKER VOLUME.HAVE NEVER HAD SPEAKERS HOOKED UP BEFORE.
That's your problem. It could be:
* the audio-device integrated on your computer's motherboard is "disabled" -- Windows cannot use it
* there is *NO* audio-device integrated on your computer's motherboard -- Windows cannot use non-existent hardware.
* Windows has not installed the correct device-drivers for the integrated audio-device.
* you have an add-in PCI audio-device, and Windows has not installed the correct device-drivers for this hardware.
Do the speakers work if the output from an iPod is connected to the input-jack on the speakers?
Do the speakers work if connected to some other computer (laptop or desktop) ?
Nov 11, 2009 | Insignia 2.1 Speaker System (3-Piece)
Saadddd.no sound????
Are these built in speakers? If so, check the speaker drivers and the application that control the speaker volume etc to see if it is actually muted.
If they are external, check the power source.
Nov 05, 2009 | Acer (90.18612.36B) Computer Speakers
We can not here our sound out of speaker or our computer and it a dell
Plug in ONLY the regular wired speakers and ONLY to the green port on the back.
Make sure they are powered up and the volume is about half way.
Ok now you need to call up ether the sound card application or preferably the windows volume control from the bottom toolbar.
Click Open Volume Control.
A box with sliders in should appear. make sure that volume control, wave, sw synth, aux, cd player, line in
are all about half way and that none of them have ticks in the box at the bottom.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else)
Now close the slider box.
Put a normal music cd in your cd/dvd player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
Double check that EVERYTHING is ok.
If there is still no sound check the control panle for any hardware issues and rectify those with the correct drivers
Oct 18, 2009 | Microsoft Windows Media Player
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
Speaker volume too loud
Have you tryed to turn down the sound volume on the media player its self as well as the the main volume?
Jun 21, 2009 | Dell 5650 Computer Speakers
Speakers are plugged in correctly, lights on but still no sound
Check your output jack again and make sure its on the green jack
and also check your speaker wires, if okay then check this;
For Windows XP;
  1. Go to Control Panel
  2. Sounds and Audio Devices
  3. On the Volume tab under "Device volume" check that sound is NOT muted
  4. Adjust volume control
  5. Check "Speaker Setup" under "Speaker settings" under the "Advanced" button
For Vista:
  1. Control Panel
  2. Sounds
  3. Select Speakers then properties
  4. Make sure device is enabled
  5. Test sound
  6. Adjust volume controls
Under Device Manager make sure that under your sound card that you dont have a yellow exclamation. Yellow exclamation indicates you need to install the correct driver.
Jan 18, 2009 | E-Machines T6420 PC Desktop
No sound output
Check the following: 1. Volume Control on the media player 2. Volume control on the operating system 3. Volume control on the speaker, AND the power 4. Check the speaker plug, is it correctly inserted to output/speaker port of audio card? 5. Check your audio setting in BIOS, is it correctly set and recognize by the operating system?
I provide general answer to general questions, if you could be more specific (like type of OS, type of motherboard, media player software, etc.) I can provide more specific answer.
Dec 25, 2008 | Computers & Internet
No sound
see if u can get master speaker wiith cables on it that died on ebay best bet what kinda are these
Jan 05, 2008 | Altec Lansing ACS 45.1 Computer Speakers
Dell Dimension 3000 PC Desktop Logo
149 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
