No, It is not a wireless. It was working one minute and then my son pushed program and turbo. Ever since then it won't workNo, It is not a wireless. It was working one minute and then my son pushed program and turbo. Ever since then it won't work
I have the same problem, I can move all the toggles but all the buttons and triggers dont work? What the?I have the same problem, I can move all the toggles but all the buttons and triggers dont work? What the?
The "program" and "turbo" buttons flash or illuminate constantly when xbox is turned on. All other buttons will not work, when pressed the program and turbo buttons flash. What do I need to do to fix it? The "program" and "turbo" buttons flash or illuminate constantly when xbox is turned on. All other buttons will not work, when pressed the program and turbo buttons flash. What do I need to do to fix it?
You can't post conmments that contain an email address.
It does indeed sound like a virus or some sort of malware. The good news is that you can get expert help without paying anything, or not much at least. The web site is called What the Tech and has experts in virus and malware removal. They will give you step by step instruction on how to clean up your system. The site is a donation based forum, they will not charge you anything for the service, after you system is clean you can make a donation if you wish to. Here is the link:
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
try turning the drum by hand...is it jammed? if not, then:
the motor will not turn due to a number of reasons:
1.) simply burned out copper windings
2.) switch not turning on motor or not turning on motor starting circuit-depending on design
...if jammed, then try to find the interference to turning
