Question about Dell Latitude D505 Notebook
Hardware problem, notebook is not booting
I have dell latitude D505. It is a new and it was not used few years. I plugged it in power (220v) and after 20 minutes I turned it on, and it was working, configuring windows xp for first time, creating users …. In one moment I heard something like some relay switched of something and Notebook stopped to work. Now when i press power button, the screen does not turn on. The fan doesn’t run. I think that motherboard is not booting. Only numberlock, capslock and power led are flashing few seconds, and after that everything is turned off.
  • yorgosine Feb 13, 2008
    I tried everything, even with another memory modul and it doesn’t work.
    Scholar:
  • 163 Answers
Could well be a RAM slot failure.. Try running on 1 stick of RAM and swapping the Mods around..
Posted on Feb 11, 2008
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
My Dell D505 Latitude will not power up. The 3 green lights flash for less than a second and then it switches off. It was working fine until a few days ago. Any ideas of how to fix this as all my work is...
Sounds like ether a blown power supply. That happens when the laptop battery has alittle juice left.
Try to take out the battery from the bottom and plug the laptop in the wall. If the laptop powers up you battery needs to be replaced. If it doesn't power up, you need to replace the power supply.
Good Luck,
jsgrepair@co.nr
Aug 23, 2011 | Dell Latitude D505 Notebook
Dell latitude d505 laptop power on & led glows but there is no display, no beed & also the cpu fan is not running , after few seconds thens it turns off automatically. help?
hello
i experience to repair one of those before!!! mostly the problem is in the board you need to bring it in service center for repair.
Thanks
Nov 13, 2010 | Dell Latitude D505 Notebook
Dear Sir, I have dell Latitute D505 notebook.
Try to find any friend with the same cable plug and try on it.If you not find anybody buy a new cable or find a used one HERE.
Feb 22, 2010 | Dell Latitude D505 Notebook
Latitude d505 won't display image through projector. Being used with Sanyo plc XU41 and Promethean board. Board is interactive but no help if there is no image to see! Other Dell laptops work with this...
Dell laptops normally have a 3-way toggle for the display destination: 1=screen 2= external display and 3=Both. To toggle from one mode to the next press hold the 'FN' key (lower left corner of the Key board), and the briefly press the 'F8' key. Wait a few seconds for the hardware to catch up and you should see a display through the projector. If not, repeat the 'Fn' + 'F8' combo again.
You could also try running diagnostics to verify that teh video card is working properly. To do that, sthar with the laptop off. Hold the 'Fn' key down while you press the power button. Release both as the machine begins to boot up. It should start in diagnostics mode. Run the quick test and watch for the color bars. If you see then, the video card so=huold be OK.
Good luck, And please let me know how it turns out for you.
~ Spoem
Oct 01, 2009 | Dell Latitude D505 Notebook
DELL Latitude D505
Have you tried the other fix? It often times works.
Remove the battery AND the power cord.
Hold the power button for 10 seconds.
Now plug in the power cord.
Magic should happen
Feb 27, 2009 | Dell Latitude D505 Notebook
No power at all for my Dell Latitude D505
Sounds Like From Your Description That You Need Your DC Jack Repaired/Replaced..
THe DC Jack Is the Port where Your AC Adapter Plug Plugs into on the laptop.... THis can be proprietary or non proprietary.... But Either way, the Old Faulty Jack Needs To Be Desoldered and Removed, THe Board Cleaned and a New DC Jack Soldered On.. You Will Then Be able To Power On Laptop With AC Charger and Will again Be Able To CHarge The Battery..
Nov 19, 2008 | Dell Latitude D505 Notebook
Laptop getting power but not booting up!!!
Are you referring to the caps lock key,kindly check the memory of the laptop.
Oct 19, 2008 | Dell Latitude D505 Notebook
Dell Latitude D505 Notebook Logo
132 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
