Washing machine fills with water when not in use.
The drum of the washing machine slowly fills with water when not in use. Although the drain cycle can remove the water to allow me to use the machine, I would prefer to fix it in case I forget to drain it first before opening the door!
The machine works fine in normal use, and drains water normally when the wash cycle finishes.
I do not have a manual for this product, as it came with the house. Can anyone help me fix this?
  • dbaron Feb 11, 2008
    The model is a Beko WMA 10 W (7114381200).
  • Anonymous Aug 26, 2008
    Indesit washer dryer
    President:
  • 1,294 Answers
Click on washing machines above, (below FIXYA) on this site, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site. You have to replace your inlet water valves. Its simple.
Posted on Feb 11, 2008
3 Suggested Answers
  • 8 Answers
SOURCE: Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Posted on Feb 22, 2009
You have an open solenoid on your water valve where the fill hoses connect. Change the water valve and you should be good.
Posted on Jul 25, 2008
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Bosch washing machine fills with water throughout any cycle
Just a guess but could the fill valve be defective, not shutting off completely when it should?
Nov 21, 2013 | Bosch Washing Machines
The washer fills slowly with water when not in use. It drains without any problem when drain/spin cycle is used.
Most likely the water inlet valves on your washing machine have failed. You may have noticed larger amounts of water in the clothes drum when the washing machine hasn't been used for a few days, this is because the valves may still be open allowing water to drip into the clothes drum.
Here is a link to the part that you need to buy: http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Washer-water-inlet-valve--universal-item-number-AP3098982.aspx.
And a link to a video showing you how to replace the part: http://www.ultimatehandyman.org/video/appliance_repair/water-inlet-valve.php
Hope this helps!
Feb 28, 2011 | Whirlpool GHW9400 Duet Washer
Have whirlpool LSR7233B top load washer. It fills and agaites but will not drain all the way and spins slowly on slowly on spin cycle
THE BELT THAT DRIVES THE DRUM MIGHT BE WORN, THE BELT IS NOT UNDER A LOT OF STRAIN WHEN WASHING AND MAY WORK FINE BUT WHEN IT GOES INTO THE SPIN CYCLE THE WEIGHT OF THE CLOTHES AND THE WATER WILL CAUSE THE BELT TO SLIP . I WOULD START THERE FIRST
Aug 23, 2009 | Whirlpool Washing Machines
No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Jun 02, 2009 | Hotpoint WMA46 Front Load Washer
After water drains, it slowly comes back and fills in the drum over time.
Use the attached video to show you how to access the inside of the machine.Ignore the other parts other than access and re-assemly.
Apr 30, 2009 | Whirlpool GHW9150 Duet Washer
Feb 22, 2009 | Asko Washing Machines
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Jul 25, 2008 | Washing Machines
Washing Machines Logo
1,094 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
