Bought aphilips dvp 5960 am finding problems in cong to my tv toget a pic on screen to follow set up procedure. my tv is a hitachi about 4 years old. i also have sky tv
  • alan533 Feb 12, 2008
    yes iam connecting dvd with ascart lead
  • 4,102 Answers
Hi are you connecting the dvd via a scart lead let me know then i can assist you further
Posted on Feb 11, 2008
  • paul proctor Feb 12, 2008
    If you are using scart lead thats strait into the telly then you need to check the leads in properly then you need to press the av button on the telly controll this will select the correct av channel make sure dvd is on with dvd in then press av you might need to press it more than once depending on how many scart sockets you have so press the av button and then let me know ok.
    Some dvd auto start and the telly picks up signal if yours dont then you need to press av in the control and this should solve your problem
Connect hp laptop to tv to watch Netflix downloaded movies
how do i hook up my hitachi tv to my hp laptop to get netflix?
Jul 23, 2010 | Hitachi 51F59 51" HDTV Projection...
PHILIPS DVP -5960
The easiest and fastest solution is to buy a power converter for the cigarette lighter or other 12v power source. It would take a lot of time and money to change the capacitors and motors on the DVD Player itself. Some power convertors work with any 12v power in your car.
Dec 08, 2007 | Philips DVP5960
Pic suddenly went dark, very dark. Images seen are oversaturated. hitachi ultrascan hd is about 8 years old. Help!
I have the same problem. I took the back cover off of the TV and blew all of the dust out and the TV started working again. But this only lasted 2 days. Now the TV is dark again.
Jan 19, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Colours red and green are out of sync
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2009 | Philips 55PP9363 55" Rear Projection...
Hitachi Class Action Lawsuit
I have a 60 inch lcd with the red cloud, bought the tv in 04 called hitachi about it and there sending my tv repair man the light engine no cost. Everyone just needs to call them again. thanks Jim
Aug 31, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Wrong Region message
This will make the player region free so it'll play anything. It worked on mine and i have the same player.
remote control :
- Press "System Menu" key to enter Set Up menu.
- Move to "Preference Page" using arrow keys to the left or to the right.
- Press the following sequence in the remote control: 135566
- A menu indicating "Region Code" will appear.
- Change region using arrow keys to top or down. Region Code = 0 will play all regions.
- Press "System Menu" key to exit Set Up menu.
Jul 14, 2008 | Philips DVP5982
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Have just bought dvp 5960 it will not play downloaded off my computer just shows unknown disc
The DVP5960 should play ANY DVD format except DVDRAM.
Do bought DVDs play ok? If so, then the problem is probably not the player.
What file type are you burning on to the disc? .AVI (DivX) & .VOB (DVD) files should be ok.
If you are using Windows Explorer to drag & drop the files to the disc, you will also need to finalize the disc.
Apr 28, 2008 | Televison & Video
Aspect ratio
Problem is solved. I unplugged my DVR from my receiver for about a minute, reconnected it, and the that solved the problem.
Dec 08, 2007 | Audio Players & Recorders
Pink Screen
There is a service bulletin for this problem - you need to reintialize the memory settings in the service menu - I have a pdf file showing how to do this.
Sep 09, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
