Question about Trendware TRENDnet TEW-421PC 54Mbps PCMCIA Wireless Network Card 802.11g (NETWTEW421PC)
Trying to get a laptop on aol
Hi
We are trying to connect to Aol by laptop. We have unstalled Trendnet wireless cardbus tew-421pc and Netgear DG834g. The installation goes through ok on trendnet untill you have to click on the computer icon in the system tray. Its always red and not green, and when going into the infrastructure mode its always scanning and there are no drop down boxes and the channels are changing. Also Netgear says No Cable or Router detected. We are using windows xp professional, we have been all through the process of going into internet connections, highlighing the network but still cannot connect. Its an absolute nightmare as we are totally stuck.
Any help appreciated please?
Regards
revlac
  • 1 more comment
  • revlac Feb 13, 2008
    Hello Jeff
    Thanks for your reply. The netgear DG834G is version 4.3 and the the card reads 802.11g wireless Lan pc card, IEEE 802.11g compliant, DSSS at 2.4 ghz ism band, tew-421pc H/W:B1.1R if this helps.
    We have our own computer set up using windows xp professional along with aol 9.0vr and the netgear DG834G. We got our daughter this laptop (second hand) and the trendnet card came with it.
    The laptop had windows me installed on it so my husband wiped it down and put xp professional on instead. Everything loaded up and it did work great for afew weeks.
    Then last week my husband decided to change his password with aol and thats when everything messed up. I contacted aol help team and they guided me through what to do regarding fixing our computer and we managed to sort that out but my daughters laptop just cant get on the internet now.
    We wiped everything down again and loaded back xp.
    As i said before i keep going through the process that aol have told me of going into internet connections etc: they also said that i had to load in order aol, trendnet then netgear.
    They seemed to have installed ok but the netgear gets so far and then says "no cable or router detected", so we are all baffled as to what to do next.
    Hope this info if of some help.
    Regards
    Helen
    Hi Jeff
    I have just disabled the trendnet on th laptop, also i cannot find local area connection on there, our computer has that but the laptop does'nt. But yes the desk top appears to be working ok.
    Helen
    Its an Advent 6410
    model no: A440
    and I think the manufacturer is Gericom
    Scholar:
  • 70 Answers
The first problem has nothing to do with your ISP. If you are. Even unplugged from the phone line on the back, the Netgear would still function as an access point, switch, etc. BTW-the Neatgear has an ADSL modem built into it. Are you trying to use an additional modem as well, if so, remove it. Then see if it works.
Connecting to your ISP is the second problem but if the first one is fixed I predict the second one will go away...
Do you have radio signal (wireless signal strength)? This only has to do with the card and router connecting together MECHANICALLY. If not, the Tendnet may be set to a single frequency and should be set to automatic (or at least match the frequency).
Check to see if the SSID (Network Name) are the same on both devices.
Is the Netgear's firewall enabled?
Is the Trendnet enabled?
Have you tried re-installing the drivers?
Are you aware that AOL requires you to use thier software to log-on?
When using DSL there should be a dialer program installed?
There are too many diagnostics so for time and length sake no instructions are give, but if you are not familiar with any the "tests" above I will be happy to guide you through them if you ask one or two at a time. You may reach me at fixya@pcsports.org. One piece of info I would like to know is: which version of the Trendnet are you using (either starts with an A, B or C)? The Netgear will have a V2, V3, or V4 after it. If there is none, it is simple version 1.
Get back to me soon so I can help you through this.
Posted on Feb 12, 2008
  • 1 more comment
  • Jeff Sapper
    Jeff Sapper Feb 12, 2008
    Did forget one thing you need to look at...
    The DHCP server on the Negear must be enabled as well as the obtain IP on the Trendnet. This is called Dynamic Addressing-the wireless card asks the Netgear for an IP address.
    Jeff
  • Jeff Sapper
    Jeff Sapper Feb 13, 2008
    Does the desk top work ok?
    Give3 me a few hour to learn more tek diognostics fore both units then
    I will get back with. I only sleep 1/2 hour last night so I'll
    probably fall asleep at the computer
    In the meantime, plug the laptop directly to the switch. There should
    be a RJ-45 on both the laptop and the switch. Use a stright cable, not a x-over model. In fact you should disable
    the Trendnet. < Start<Control Panel<Newtwork Connections. Rightclick on the Trendnet Wirelss then left click "disable". Do the same for Local Area Connect except click "enable". If it already says disable, it means it enabled and visa-virsa.
    Now see if the laptop will hook up to the internet.
    What we are foing her is going through the process of elimination So If this doesn't workleave set as is and get back w/me for further directions,,,
  • Jeff Sapper
    What type of laptop, include Manufacturer and model number.....
  • 196 Answers
What is your ISP? What kind of modem have they supplied?
Do you get a connection when using a wire?
TRENDnet TEW-421PC 54Mbps PCMCIA Wireless Network Card 802.11g (NETWTEW421PC): signal strength 85% green but tx rate 11 instead o...
Im sorry but you will never get 54 on your card toughs are theoretical maximum speeds and I have never seen a system actually achieve them the actual speeds received by wireless devices are actually much lower and 11 is a normal speed wile running over wireless. Im sure this isnt what you wanted to here and I am sorry but it pretty much comes down to manufactures lieing by telling you it goes to speeds that can never be reached.
I hope this helped.
Thank you,
Norse
May 16, 2010 | Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
I have wireless laptop and fixed PC with 834g. All ok thursday, fri couldnot get connection on either machine, AOL went mad throwing up connection screens never seen before, and had to reboot to get rid...
no the problem that you are getting is from aol
check that wether you get this problem once again .
if you get this problem once again then try to call aol
on 1-800-aol
if it doesnot solve your problem you can get back to me on fixya .
thanks
techbuddies
Oct 25, 2009 | NetGear DG834G Router
Have a WRK-54G Linksys wireless router. Have a
I had a TEW-421 card for a time, and it can not do WPA encryption, only WEP. It's not a driver shortcoming, it's the hardware in the TEW-421 card.
Sorry to tell you it's a dead-end, but at least now you know.
Oct 18, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Wireless network adapter(code 10) and pci modem (code 28)
install proper driver then set ip adress .
enable wireless adapter.
Oct 07, 2008 | Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
Realtek8185 Wireless adapter
Hi Terry,
I believe it was the following...
Realtek Semiconductor Corp - Networking - TRENDnet TEW-421PC/TEW-423PI 802.11g Wireless Cardbus/PCI Adapter
Installation date: ‎2/‎5/‎2008 12:07 PM
Installation status: Successful
Update type: Optional
Realtek Semiconductor Corp Networking software update released in October, 2007
More information:
http://winqual.microsoft.com/support/?driverid=20122747
Help and Support:
http://support.microsoft.com/select/?target=hub
I just checked on Microsofts Windows Update again, and there is another optional update for the Realtek. This only partially fixed my problem - we've also had to adjust the channel our wireless DSL router uses; our cordless phone was interferring with my signal. Now that I've adjusted the channel on the router, I haven't dropped my signal once in more than 3 days. Good luck. Hope this helps.
Apr 21, 2008 | Adapters.com Genica Realtek A-8100 PCI...
Wireless Connection
Follow trhis posting as I'm working a pretty much the same prolem
trying to get a laptop on aol
Hi We are trying to connect to Aol by laptop.... More...
Jeff
Feb 08, 2008 | Computers & Internet
First use the Netgear setup wizard:-
Open Internet Explorer
Enter http://routeraddress e.g http://192.168.0.1
Click Setup Wizard (top left)
Then for With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It should search for your connection, find it and allow you to log on.
Feb 06, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Antenna connections
Well, we kind of need the manuf. and model if we are to help you here.. :)
Dec 07, 2007 | Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
Driver for a trendnet wireless card
you didn't specify the version number. Find your version here and select the download for your card. Hope this helps you. Please let me know!!
http://www.trendnet.com/downloads/info/tew-421pc.htm
Oct 28, 2007 | Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
Trendware TRENDnet TEW-421PC 54Mbps PCMCIA Wireless Network Card 802.11g (NETWTEW421PC) Logo
464 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
alex metro
alex metro
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
