Question about Dryers
Hotpoint dryer ctd40
Not heating up & then after a while high heat,time delay & on off flashes.
  • 871 Answers
Check this site. im sure this will help you find whats wrong with your dryer.
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
thanks for using fixya. ^__^
Posted on Feb 11, 2008
  • 4,102 Answers
Hi the problem you are having is more than likely going to be associated with the pcb board failing this controls the heating element and the temp sensor you will probably find a bad solder or failing component on the pcb side of the board these can be replaced but you need to work out the age of the drier compared to what else might go wrong let me know ok
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
My hotpoint ctd40 has stopped heating again, the
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Dec 22, 2009 | Washing Machines
HOTPOINT CTD40 CONDENSING DRYER not drying clothes any more.fault codes is on/off light and time delay lights are flashing after 30 seconds of switching the appliance on.the condenser unit is free of fluff...
Without actually taking meter readings I would suggest that its probably the thermostats that are fitted to the heater unit on the back of the appliance.
Hotpoint Part Number: 1703607
Hope this helps
Aardvark repairs
Nov 16, 2009 | Hotpoint Dryers
I have a hotpoint dryer ctd40, it seems to eb
either your heating element,hi-limit switch,cycling switch, thermal fuse, or missing one leg of input power i.e.120volts instead of 240 volts
Oct 29, 2009 | Dryers
Hotpoint ctd40 t dryer. wont start just ticking.
do you hear anything running?,might have broken the belt or idler wheel,motor runs but no tumble,need to look inside,warning !! unplug ,high voltage.be carefull
Sep 22, 2009 | Dryers
My hotpoint ctd 40 wont heat up
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jan 27, 2009 | Hotpoint Dryers
Hotpoint aquarius ctd40
most likely, there is a blockage in your exhaust. take it apart and check every inch from your dryer to the outdoors. i clean mine once a year, it keeps the dryer running efficiently. when lint backs up in there, the heat cannot get out and there is a sensor that will shut off the heating element when it gets to a certain temp, so your clothes will take a long time to dry
Oct 27, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint t/d ctd40
my dryer doesn,t heat up & after a while the time delay,high heat & on off button flash.
Feb 11, 2008 | Hotpoint TDL14 Electric Dryer
CTD40 Aquarius Condenser Dryer
This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Oct 20, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Dryers Logo
128 people viewed this question
Top Dryers Experts
Marvin
Marvin
