Question about Technics SUV500 2-Channel Amplifier
Technics SU-X955 amplifier. which speakers ?
Hello I have had the above amp since 1989 and have been using Mordaunt Short MS30 speakers for the last few years. However I often need to replace the woofers or tweeters presumably due to the incompatibility. Can anyone recommend some suitable speakers to replace the Mordaunt Shorts.
Thanks you very much
Dan
Helo you have to use speaker of the same wattage you have now chage crossover to get new clear digital soud
Posted on Feb 11, 2008
On my Technics SU-G90 where do I connect the subwoofer
Some amps have a single RCA socket for a powered sub. If it has not got one of these then the amp has no output for a powered sub. If so then you can only use a none powered subwoofer, which will connect via the speakers of the amp, see the subwoofer manual for how to do this.
Feb 18, 2014 | Audio Players & Recorders
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
Sep 23, 2012 | Audio Players & Recorders
Integrated amplifier for Mordaunt-Short Avant 908i
Use an amplifier with NO MORE than 150 Watts per channel or you be buying new speakers. At this power level don't expect booming bass boost without damaging the speakers. The Rotel generates 130 per side which is very near the safe maximum for those speakers... and the specs look good. If you are not satified with the sound, the speakers are LIKELY the problem. Look at getting good commercial speaakers instead of CONSUMER grade speakers. Go to a music store dealing with bands and musicians and view the products they have to offer. Consumer speakers often fail when people turn up too much bass. At high listening levels hearing damage can result.
Aug 02, 2012 | Audio Players & Recorders
Speakers for Technics SU X933?
check given link for speakers
http://www.fixya.com/myhome.aspx#Answers
Jun 05, 2012 | Technics SU-G75 Amplifier
Hi I just got a Technics SU V2 amp and can't get sound from the speakers. What size speakers would suit this amp? What is the correct method to connect the speaker leads to the back of this amp,...
Being a 500W amplifier, you need to connect speakers with 300W each. The correct method to connect speakers is red terminal of speaker should be connected to red terminal of amplifier & black to black. The left side to left side speaker & right to right speaker. There may be main & remote terminals. Main speakers are the speakers at local place of the amplifier & remote for remotely placed speakers. I do have Technics SU-V85A which is somewhat similar. Enjoy! A nice piece to listen.
Oct 22, 2011 | Technics SUV500 2-Channel Amplifier
Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Dec 05, 2010 | Technics SUV500 2-Channel Amplifier
Technics SU-G95 Amplifier and no sound on left speakers
Usually this is a defect in the output amp IC. If you have no experience with repairs of these types of units, have it checked by a service shop. If the output AMP IChas failed, it will cost about $75 for a replacement. This unit uses an RSN3306P IC .
Dan
Mar 14, 2010 | Technics Audio Players & Recorders
Su-v55a technics amp cuts off when volume up to 2
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
Technics Integrated amplifier su-v85a speaker volume fluxuates and speaker left shuts down some times what is the problem?
test you speaker maybe there is a bad connection some where is the spk. box its self ,try changing speakers left to right .
it the spk. are ok open amp see all the connections within the amp .
if this dose not work contact me by mail: starilaz@net.hr
Oct 12, 2009 | Technics SUV500 2-Channel Amplifier
Technics SUV500 2-Channel Amplifier Logo
1,650 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
