Question about EliteGroup P4M800PRO-M478 Motherboard
Processor My processor cannot switch on after power failure.What could be the problem?
I don't hear the fan come on at all.
Is there a solution?
Posted on May 12, 2008
    Novelist:
  • 77 Answers
I presume you mean "automatically switch BACK on after a power failure". As in, power goes off on local AC grid, computer of course, goes cold, power comes back on, and you want PC to resume (reboot) automatically. If that is what you are asking, here are the possibilities:
1. If you have a "momentary on" start button (as most newer model cases have) you cannot do this simply by leaving switch "on" because it does not remain in continuity. It must be pressed manually every time the computer shuts down.
2. Your BIOS may be the best and simplest means of getting what you want. In BIOS, you will find a setting that allows the computer to restart after every power outage.
3. There is also a software-related setting available in Start Menu/Settings/Control Panel/System. Select "Advanced" tab, then "Startup and Recovery" and make sure "Automatic Reboot" is checked.
4. Now, all that being said, just to answer your question as I presume you meant it, I want to advise you this is all a bad idea (and in fact, it is the reason most newer PC start buttons are "momentary on" as indicated in number one above). Why is this such a bad idea?
When the power goes off, there will always be a big voltage spike, and another even BIGGER spike when it comes back on. Worse, if the power went off on your grid due to an overload, when it comes back on it may either "machine gun" (off/on several times from heavy load, each one with a larger voltage spike) or come on low, below voltage tolerance, fluctuate wildly, and slowly reach proper voltage levels. All of these events are VERY hazardous for your PC, and even with a median surge suppressor, any of these events can damage your PC power supply AND/OR your CPU or other components! It would be far wiser to buy a "UPS" (uninterruptable power supply) which is a unit that plugs in between your AC wall current and your PC. The UPS has a battery and power inverter inside, that changes the 12VDC battery power to 120VAC (or 220VAC if you are outside USA). This device remains vigilant 24 hrs a day, and lets your computer continue running even when the power is off to your house/neighborhood. Of course, it has time limits, can only sustain this power for a specified number of minutes or hours depending on the size/price of the UPS you buy, but this is sufficient time to cover most power outages.
Posted on Feb 13, 2008
    Problem Solver:
  • 17 Answers
Be more specific. Is the PSU powers on, Do you have any LED's on, any fans spinning, any sounds out.
Posted on Feb 12, 2008
No lights on AC unit but fan is running.
Possible that the processor has failed and it seems to give a through circuit to the fan which runs when power is switched on.
You can check the voltage on the processor IC and if absent then you must check the DC voltage on the circuit board. If there is no power then it is the failure of the power supply section and if not the processor is the suspect.
Sep 27, 2013 | Fedders Heating & Cooling
Dell 2400 desktop pc will not turn on. Mother board flea led light does turn on.Tested power switch and wiring okay.I did swap power supply pack from a good working 2350 Dell pc same problem any...
Try to remove all components all drives (hard drives, cd/dvd roms, floppy drives, etc), all additional cards (modem, video card, sound card etc), remove the memory. Just leave the motheboard, proc and power supply. Before disconnecting everything completely discharge power by holding down the power button while the computer is unplug from the power. It should clear the flea light on the motherboard.
Test it again with just the motherboard, processor and the power supply. If still no power then most likely it is the motherboard since you already put a known good power supply. Motherboard has higher failure rate than the processor. You can swap a known good processor if there is.
Jul 25, 2011 | Computers & Internet
MY PRINTER PIXMA MX310 SWITCH DOESNT TURN ON AND THE ALARM SHOWS. thier is no lcd displayed WHAT DOES ITMEAN?
Possible that the power supply is faulty as there can be a link failure to the display, Also it can be a failure of the display drivers, Possible fault in the display sub processor or even the main board.
You need to cross check and confirm with voltage checks on the power, display and main board.
May 04, 2011 | Canon PIXMA MX310 All-In-One Printer
Tv does not come on with off on switch or remote. Set completely dead. VCR doesn't run either. Fuse is OK and circuit board looks like new. Nothing looks overheated.
Quite possible that the fault is relative to the power supply of the TV. So it is important that the voltage is measured of the output in the SMPS - switch mode power supply.
If there is no output the SMPS is faulty , failure of driver or frequency oscillator.
Please check the link below:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Once the power supply is restored the voltage feed to the processor and sub sections must be checked, for failure of any regulator or fusible resistors
Jan 19, 2011 | Televison & Video
How do I troubleshoot my motherboard on my HP Pavilion a1020n. This is my motherboard PTGD1-LA.
A) Power Supply.
One of the leading causes of computer failure.
LED lights come on? Fans spin, or spin a few times, and stop?
Bad Power Supply. Weak voltage power rail.
1) ALL of the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is. (Older Processors such as Pentium II's for example, use less)
No Processor operating = No Signal on the monitor.
No video signal.
But if you do think it's a problem with the Ol' Goldfish 3, look at the Electrolytic Capacitors on the motherboard.
1) http://www.capacitorlab.com/visible-failures/
Sep 22, 2010 | Computers & Internet
Monitor will not power on and led light is off.
It is possible that the fuse has failed and has cut off the power. If so there sould be a failure in the smps- switch mode power supply- which has to power the low tension DC voltages. If you are confidentt open the rear sie and use a multimeter to check for fuse failure , if so check for short in the smps. replace the driver or capacitor or the rectifier. check for any short also on the surge protector. If the DC comes out then we have a serious issue and could be failure of the mother board. you will need to check for microprocessor failure, LCD driver/processor faulty. You will need to be proceeding in this flow chart. Helpful? Good day
Jun 25, 2010 | LG L196WTQ Monitor
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
When cpu switch on processor & power supply fan runs, no display
if you have swolen capacitors you are on the road the failure
buy a new mb and save yourself some time.
hope this helps
Dec 30, 2008 | EliteGroup P4IBMS Motherboard
Safety of mother board and processor
Connect any good cabinet which involves a good power supply comprising of smps (Switching Mode Power Supply) again it also consists of four cables yellow (12v), Red cable (5v) and other two black wires of ground check the voltages with a voltmeter then you can avoid burning or failure of product .
Note : Ask your electrician to provide better earthing to your computer
Feb 19, 2008 | Intel Motherboard
No picture on my laptop
Jackboy is right. When did the picture fail on you and what were you doing? Can you see any picture at all even the smallest trace?
Dec 24, 2007 | Computers & Internet
EliteGroup P4M800PRO-M478 Motherboard Logo
62 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
