Question about Maxtor Hard Drive
New maxtor hard drive
I have just purchased a new hard drive. I f something goes wrong with the drive how do I know where to contact maxtor if it is still under gaurantee? I was told to go on the maxtor website and download something but I just cannot see anything regarding this. Could someone please explain to a novice, what I should do..Thank You.
    President:
  • 2,351 Answers
Try this link: http://www.maxtorsolutions.com/en/Main/support.shtml
Write down your drive information & register hardware.
Hope this helps!
Posted on Feb 11, 2008
  • 84 Answers
Check this website. It will help with regards to information about warranty of your hard drive.
How to fix a dead hard drive
Try a low level format. There is a strong possibility that your hard disk will no longer be able to perform normally even after a low level reformatting. Looks like a new hard disk is the answer.
Jan 04, 2010 | Maxtor Hard Drive
I need a complete 3200 Maxtor 200GB Personal External unit -- case and all, not just the HDD according to my friend. Is this right?? I do not have the existing case as this was discarded when it was opened...
Hi bizemail,
Well, I'm not sure why you discarded the old casing. If you recieved a replacment from Maxtor, they would require the drive and case, or your warranty would of been voided. Your not suppose to open those cases. However, now that you have, you can test the drive by just loading it your computer (desktop I'm hoping) as a slave drive. Make sure your pin settings on the other drive is set to master, and add it in. If it works Windows will find it and add it as new hardware. If it doesn't, then their something wrong with the drive. I'd call whomever you purchased it from.
Good Luck,
And don't forget to leave a rating,
Thanks
Mark
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I have tried to order replacement power cord 12 volts 2 amps for maxtor 3200.I haven't been able to find one.
This is a common problem, most of the AC cords for these devices cannot be purchased seperately.
You have 2 basic options:
1. Purchased a used model of the same model # off eBay or a similar Auction site and use it's AC cord
2. Take the drive as is into your local computer store and purchase a new External drive caddy which will include it's own AC adapter(usually $30-$50) and ask their technicians to move you maxtor drive into the new caddy. There is one thing they will need to no, what type of HDD it is, SATA or IDE but if you do not know they will be able to tell as soon as they open the maxtor shell.
Either way you should be able to access all of your files, just a question of seeing which way will be cheaper and easier for you. I generally recommend the second method as the new shell will come with it's own warranty should something fail which used parts generally do not.
Hope this helps FixYa,
Chris
Apr 30, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor One Touch 4 Plus
I have the installation program. You can contact me
Email: haulingkc@yahoo.com
Tony
May 01, 2008 | Computers & Internet
Maxtor onetouch 4 mini usb 2
You cannot download drivers/software for the Maxtor Mini at the above URL. When you select the Maxtor Mini, you're redirected to a contact form you have to fill out just to get the software. Pretty lame on Seagate's part! I'll think twice before purchasing anything else from them.
Mar 18, 2008 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Maxtor OneTouch III 500gb
One hard drive failure mode is a power circuit short. Contact MAXTOR support on their web site for a possible warranty replacement. BTW, SEAGATE owns MAXTOR now.
Feb 24, 2008 | Maxtor OneTouch III Mini Edition 120GB...
DMR E80H hard drive
DMR-E80H Hard drive problem seems to pretty common. My drive started making the famaous kerchunk noise tonight. After disassembly I see the drive is a ATA133 Maxtor drive....are you sure that you replaced it with the correct drive? I may contact Maxtor and try to get an RMA since the drive is only 3yrs old. Good Luck
Oct 09, 2006 | Panasonic DMR-E80H DVD Recorder
Maxtor Hard Drive Logo
44 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
